Electrical tape as rim tape?
Bikes: '07 Trek 520, '09 Gary Fisher Triton, '04 Trek 8000, '85 Trek 500, '84 Trek 610, '85 Trek 510, '88 Trek 660, '92 Trek 930, Trek Multitrack 700
Quoted: 19 Post(s)
"When I hear another express an opinion, which is not mine, I say to myself, He has a right to his opinion, as I to mine; why should I question it. His error does me no injury, and shall I become a Don Quixot to bring all men by force of argument, to one opinion? If a fact be misstated, it is probable he is gratified by a belief of it, and I have no right to deprive him of the gratification."
T. Jefferson
T. Jefferson
Quoted: 1814 Post(s)
Liked 923 Times
Friction tape is readily available. Maybe cheaper than rim tape, but don't see any advantage otherwise.
Packing tape will end with similar sticky mess to electrical tape- I avoid that stuff.
How about Tyvek with spray adhesive?
Quoted: 1074 Post(s)
Liked 295 Times
On MTBs, well, on anything with decently wide tires, I've used two layers of electrical tape with no issues whatsoever.
Since there's been no issues, gunk removal isn't much of a concern. Compared to the time I'm likely to spend on the root cause that prompted tape removal in the first place it pretty much becomes a non-issue.
Thin tires/ higher pressures, you need better stuff.
But all electrical tapes aren't created equal, there may well be some that perform poorer than others. Not that I've met any that's been critically poor for bicycle use.
I have used the filament-reinforced stuff too. It tends to wrinkle a bit, but it's as strong as you may ever wish for.
The current favourite is a monofilament banding tape from stokvis called MOPP or something like that. Thin and slippery, can be stretched into the middle channel w/o drama. Use two layers. Haven't been on long enough for me to be able to say anything about removal. Works with tubeless setups.
Haven't had any problem with Velox, but I can't really see its greatness either.
Previous favourite was a Park-blue textile unbranded tape. Thinner than Velox, which is an advantage, and otherwise just as good.
Hi everyone, I'm looking for advice about whether electrical tape is a reliable substitute for cotton rim tape. I installed new tires for a friend yesteday, but the fit was so extremely tight that I was initially unable to mount the tires. So I removed the cotton rim tape and replaced it with electrical tape, dusted the rim with talcum powder, and was then able to mount the tire with only a minor struggle. Is this a reliable solution? If not, what else should I try instead? Thanks in advance for your advice.
Still available. https://www.homedepot.com/webapp/cata...gry=Search+All
Cat 6
Quoted: 500 Post(s)
Liked 184 Times
Medical tape has been my go-to when the bike-specific tape is not at hand.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Bikes: 1997 Specialized M2Pro
On a related note: I try to get white or light-colored rim tape, since that makes it easier to check that the tube isn't where it shouldn't be after fixing a flat.
Bikes: 2012 GT Transeo 3 2014 Cannondale CAAD 10 105
Quoted: 26 Post(s)
FYI best source for 'friction' or grip tape is hockey or lacrosse stores. frequently used to wrap sticks (i've probably got 15 rolls of the stuff in my garage ranging in size from 1/4" to 2" width
Quoted: 1530 Post(s)
Liked 718 Times
The trick is to use a name-brand tape like Nitto or 3M , and apply pre-stretch to prevent it blowing into the nipple holes. General tip: to minimise the creeping of stretched tape, finish with a few inches unstretched... but this is under a pressurised tube, and you put three layers (doubled up the ends) around the valve, right? I cut a little x for the valve hole. I've put up to 160psi (seating a stubborn tyre) up against it.
This works because if you have decent tape it'll stretch until it's about 70% of its original width, and then suddenly get a lot less stretchy, but still retain much of its strength. The cheap stuff will stretch a lot more and break too easily, not to mention having crappy adhesive that allows the tape to creep sideways into the holes. The adhesive on the better tape generally leaves little residue too.
Quoted: 659 Post(s)
Liked 7 Times
I posit that two layers of electrical tape is not only perfectly reliable, but even superior to the hallowed Velox, simply because it's much thinner and thus doesn't get in the way of the bead during un/mounting.
Liked 718 Times
Probably lighter than almost anything else too.
Also, that fibreglass-reinforced stuff is a real mongrel to remove when it gets old.
Disclaimer: obviously, it's no good for single-walled rims.
Bikes: Diamondback Apex/GT fork (modded)
I've used everything from nylon-reinforced packing tape (works well) to 16mm movie film (also works well). Currently I'm trying three layers of ordinary 3M transparent tape on one MTB rim, and duct tape on the other. Around here, thorns and goat-heads are a bigger worry.
Gorilla tape is excellent - (super duper duct tape)...you can tear it very accurately linearly to get a strip of exactly the right width. The width is retained throughout the lengthwise tear. It is also very tough.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 33 Times
Don't be a cheapskate and just forget all the other stuff and go get proper rim tape from your LBS! Just not worth doing so with a wheelset that you might ride everyday.
Otherwise we'll tell you to use the paper you take off the sticky strips on envelopes or the freebe paper measuring tape from IKEA or use the left over propellant in spray cans to air up your tires next....
Chombi
Chombi
Bikes: 1981 Bianchi Limited 650B conversion (sold), 1985(?) Guerciotti retro-roadie, 2018 Specialized Allez Sprint, 2012 Specialized Crux, mid 80's Focus MB-400
Quoted: 67 Post(s)
Chombi
Chombi
S'Cruzer
