Trying to identify this Track Bike....
Quoted: 823 Post(s)
Liked 1,396 Times
One of the most useful tools you can own in the vintage bike world is a set of digital calipers. I bought mine for a whopping $10 from Harbor Freight and words cannot express how much they have improved the experience of messing around with old bikes. When you get the chance, go score yourself a set of them.
Quoted: 7354 Post(s)
Liked 2,488 Times
zhee TAHN
Went back to shop and seat post is 25.8mm so there it is. I could make out the lower case letters of Gitane on the frame and the logo on the front....so it appears I have a bike somewhat cobbled together....
Quoted: 823 Post(s)
Liked 1,396 Times
25.8 mm seat post in a metric gauge frame means about 1.0 mm tubing wall, 'cause there's gonna be about .1 mm of slack to allow movement, typically. So comparable to plain gauge 531, or the nameless plain gauge stuff in my lovely old Liberia. So someone went to the trouble to fit a nicer crankset and wheels to it, which leads me to suspect it will be yet another exhibit in the long chain of items proving "The French have a way with gaspipe."
Whats with the gears on both sides of the rear hub, one is larger....
Oh OK it was on the smaller of the two when I removed the chain.
verktyg
Quoted: 1036 Post(s)
Liked 1,239 Times
Parfait!
Give the man a cigar!
In 1973 I went to work part time at the shop where I bought my first Gitane. The manager had a masters in French and forced us all to learn the proper pronunciations of cycling names and words.
@rustystrings61 - you're steeling all my thunder!
I have some tubes from a crashed Gitane Gran Sport that I dissected years ago. They measure 1.5mm wall thickness but they're probably top and down tubes so 1.0mm would be correct for a seat tube that takes a 25.8mm seatpost.
Very few French bikes were made with straight gauge Reynolds 531 main tubes. It was produced in 0.7mm, 0.8mm and 0.9mm wall thicknesses and mostly found on lower end Brit bikes.
@DMC707 - "yes. Its a real track bike, not a converted road bike. Even the lower line track bikes have cachet and are scarce"
By the end of the 1950's the popularity of bicycle track racing had died out in the US. There were only a handful of tracks left around the country by the 1970's so the sales of REAL track bikes was limited.
When the fixie fad took off, fixie fools were paying insane prices for entry level 10 speed frames and bikes to drew and convert to FG bikes. REAL track bike sold for crazier prices - they still do on eBay!
Gitane Track Standard bikes cost us about $50 wholesale plus $9 motor freight from Mel Pinto Imports.
@roadbikeChris - BF members are more than happy to spoon feed new folks but I suggest that you also do some Google searches for BF threads for some of your questions. The results will go back 10+ years.
For example I just did a quick Google search for "bike forums gitane track standard" and came up with dozens of links to older threads that you can glean a lot of information from.
"Give a man a fish, and you'll feed him for a day. Teach a man to fish, and you've fed him for a lifetime."
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Thank you. I have been doing some searches as I have very little knowledge about bikes period. Everyone has been very generous in providing this rank amateur some good information!
Velominatus
Bikes: 1986 SBDU Raleigh, 1984 Raleigh Corsa, 1980 Allin Stan Butler Special, 2 x late 1960s Roberts, 1978 Philbook, 1964 Allin Belgique, 1959 Allin Stan Butler Special, 1951 Higgins Plus Parfait, 1951 Hobbs of Barbican, 1913 Centaur Featherweight.
Quoted: 195 Post(s)
Liked 37 Times
So my take is that with the upgraded chainset and wheels that makes it a pretty good bike! I am very happy with the $50 I spent.
Quoted: 586 Post(s)
Liked 612 Times
I'm the guy that suggested you post the bike here on C&V. You can see I wasn't wrong.
The bike is not high end, but the cranks are awesome and the wheelset is above average. The hubs and rims are great. Make sure they are cleaned and lubed properly and trued up. They should last you like, forever if you maintain them.
Good luck with the rebuild. I suggest upright bars over drops. Drops look better to many people, but those of us over 50 like to sit up a little straighter.
Yes! I am 59 but I will try it as is and then make a judgement.
Quoted: 4521 Post(s)
Liked 6,413 Times
You need to take this on, we will help and walk you through if you can commit.
It can be challenging but the skills can be priceless and very rewarding.
I would have stopped right there, any shop that "needs" a tool likely doesn't know how to be sure they get the right one or make sure they use it correctly now days on C+V.
I did youtube how to get the chain off : ) I appreciate the extension of a willingness to help me do the work. I do need that!
verktyg
Liked 1,239 Times
Gitane Professional Piste track bike
Slightly of topic but I just made an offer on a ~1968 Gitane Professional Super Piste track bike with a Reynolds 531 frame and Campy components.
I'll probably pick it up this afternoon (Friday the 13th )
verktyg Pictures at 11:00....
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Tychom
0
09-11-12 05:46 AM
