Tire Bead Jack Required with Third World Tires
You don't need fancy tools. An old leather toe strap is all you need....and strong fingers. Gatorskins and any Challenge "Open Tubular" tire is arguably the most difficult tire to mount initially. No problem.
Start working the tire on the rim and when it gets difficult, attach the toe strap on one side and tighten the tire and tube down. Now work the bead into the rim from the other side.. Leave mounted on the rim over night and then inflate slowly checking the bead and tube.
What the toe strap does is hold the tire and bead in position while you work the rest of the bead onto the rim. This is better than ANY other tool because you don't risk putting a mount crease/hole in the tube causing a flat.
This is the old-school tried and true shop method used for the last 100 years.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
My advice would be to HTFU.
Likes For Rolla:
Bikes: Cannondale Carbon Synapse Road, Cannondale T2000 Touring, Vintage Mongoose IBOC Pro MTB, Vintage Peugeot 12spd racer, Old rusty Schwinn Manta Ray I neglected as a child, Diamondback Haanjo EXP Carbon & Metro, Specialized Roubaix Pro, RaleighSC Tandem
Quoted: 225 Post(s)
Liked 39 Times
Just an FYI, I've been changing bike tires and messing w/bikes since childhood...
Likes For michaelm101:
