Mountain bike Fixie conversion
Bikes: Tomasso Imola w. Carbon fork, motobecane 550ht, diamondback response sport 05
I don't think you read through the posts.
A magnet is not suffice because it does not tell you the grade of the material. This is important to know for corrosion prevention.
My response about the track nuts is with regards to Bat56's most recent post.
I have been working on mechanical devices since I was 12. I have put together and taken apart many things and have a deep mechanical background.
What exactly am I throwing money away one? If you can't be specific then please stop clogging the thread and allow for constructive conversation to take place. It's defeating the purpose of using a forum.
Your cog is slipping.
I don't have a fancy engineering degree and can tell whether a frame is steel or aluminum without having to perform a series of tests.
Because they're overcomplicated.
Yet you don't posses the common sense to know that a 1/8" chain will fit on a 3/32" cog.
You're again missing the point. It was to tell what corrosive properties the material could have. It also helps when you're going to sand down those welds to know what you're working with.
And the weld bead does not tell you what material you're working with. It tells you how it was welded and how good the person is at welding. I know because I weld.
Also you're not being helpful with your responses. You're being confrontational which is not the post of a forum.
Dude, you need to get over yourself. These are all things that are of no importance in converting a low-buck MTB to fixed gear. And yes, it is easy to tell whether a frame is aluminum or steel by looking ath the welds. Aside from that, even on my Dodici Gara - which has smooth welds - I can tell it's made of aluminum just by tapping a fingernail on the down tube.
By the way, you misspelled misspelling.
Dude, really? You're building a bicycle, not a rocket ship.
I would kindly ask that you stop posting on this thread if you refuse to be constructive and educate yourself on the full text of this thread.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12781 Post(s)
Liked 7,696 Times
Then find the magic ratio. Get a SS chainring and cog an spacers. Live to ride. Live to ride.
I've converted a REALLY crappy MTB to SS before, but with parts on hand. I couldn't fathom spending real money to do it. I snapped/bent two rear axles on mine. 7-speed freewheel axles are sooo easy to bend/break when you jump a bike. Go freehub if you can.
Which is exactly why I am asking what the issue is with the chain fitting with respect to the width of the cog and not in the pitch of the cog teeth. A response to why this is the case would be helpful.
Dude! I have a bike that is using a 1/8" chain on a 3/32" cog and chainring. Guess what? No problems. What are you not understanding about that?
A 3/32" chain will not work on a 1/8" cog and/or chainring (because they are quite obviously too wide) but the other way around is just fine.
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
I'm gonna need to see some hardness test data, and perhaps the corrosive properties of said chain.
Likes For Nagrom_:
Bikes: everywhere
Liked 7,696 Times
I apologize, I did say that my 1/8th chain would not fit on my 3/32 cog. I mis-spoke. Clearly. The chain should fit this. I have tried placing my 1./8 chain on my 3/32 cog and I am having an issue of the pitch preventing the chain from sitting nicely on it.
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
You could have a very worn out cog if this is the case. Pictures would really help.
I actually just laid my chain length tester on the chain and realized that many of the links are severely stretched. I guess I should have test fitted the drive train with a better chain.
Just put a new sram 3/32 chain on it and it fits nicely all around the cog.
Thanks.
Thanks.
Bikes: everywhere
Liked 7,696 Times
Now, how about some pics???
aspiring dirtbag commuter
what most people here are trying to warn you about is you will likely spend more on your conversion than you could on an entire complete new bike if you factor in price of the components plus monetizing the time spent getting everything working together properly.
if you just want the nicest possible bike at the lowest possible price i'd probably agree; but if you are doing this as a learning experience you should absolutely go ahead and spend whatever you feel is justified, just don't be shocked when it ends up costing more than you thought it would/should.
you sound like you did enough research this ***** is actually pretty damn simple. you have the internet's official blessing if you show us some sweet pics when you get it built!
Bikes: everywhere
Liked 7,696 Times
I'm so dying to see pics of the sweet Pacific conversion. He put up that twatter pic link but his account is super secret so I can't see pic.
Maybe entire thread is a fishing for followers mission...
OP, start posting with common sense and a non-confrontational tone. So far your thread sucks, big time. Post some questions that, in the scheme of your conversion, actually matter and we'll all be glad to help. Otherwise, I'm gonna start posting about helmets and get this mother shuddown.
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Fixie Infamous
Quoted: 54 Post(s)
No need for helmets. Humans skulls score higher on the Rockwell hardness test.
