Presta vs Schrader Valves
#51
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4340 Post(s)
Liked 2,985 Times
But they exist because tubular tires don't come with Shrader valves, and tubular tires are far superior to clinchers.
Clincher wheels come drilled for presta valves for people who want to pretend they have tubulars.
#52
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
A week or two back I was trying to figure out why the joint at the base of my thumb hurt so much. Finally figured out it was because I'd misplaced my tire levers and put the tire back on with sheer determination and a random piece of plastic.
#53
Quoted: 2342 Post(s)
Liked 2,843 Times
FWIW I find the screw on heads, like the Lenzyne better for both presta and scraeder...but the flip lever on a joe blow did ok also
one on my shop pump
the one on my pump I carry on the bike again lenzne
one on my shop pump
#54
I still don't understand what you are complaining about. There are 700C tubes that are schrader and there are 700C rims that handle them. So why not get them if that is what you need? Although I did have some issues with a couple, It only required five dollars worth of parts to solve, hose and chuck. I don't take any special care with them.
The bikes I rode for 45 plus years were schrader. They had wider tires. The bike I started riding circa 2010, the Raleigh, had presta. I don't like or dislike them any more than the other. I do like that there is a nut on the presta's stem. There were several time that my kids rode on nearly flat tires and the tube with schrader valve went down into the rim. But none of these experiences is enough to put me off on either. I can adapt easily and don't believe that industry must provide my perfect solution.
I am happy with rim brakes, but look where the industry is now. My next bike which I'll get in three weeks will be disc. It has presta valves on it, but if the industry decided to change it, I wouldn't care. I can competently use either and have the inexpensive equipment to use either.
And for the record, misspelling presta is probably a slap to the person that named them IMO.
You completely misunderstand me and perhaps others too but I can not speak for them. I don't mind if anyone uses PrestI or if anyone uses Schrader. I do not fault anyone either way. I am posing a question for my own information because I want to learn, especially about historic practices. "What advantages does using PrestI Valves have?" What are they. One way of getting to this is to provoke debate and even poke a little bit to expose it. Maybe it is integrity of the rim. But I have a hard time buying this. Show me otherwise. My misspelling of PrestI, intentional,unintentional is a way for me to take out my utter frustration on what these valves have caused me. Even if it had been my fault. Which I do not think it was. It is a healthy exercise. But it was all in fun which may have been lost.
#55
I once lent my pump to a fellow with a similar hangup as the OP. To whit, when he released the chuck and heard the air escaping at 110 psi he was convinced the pressure in the tire had dropped and insisted on pumping it up again. After he did it four times, I explained that none of the air was coming from the tube, since the presta valve closes instantly, it was just the air in the hose.
I'm not sure if I convinced him, he seemed to have a high degree of confidence in his mental model, but I took my pump back and he rode off. Maybe it was @mjac?
#57
I am am curious about one thing, this is how I learn things.nWhy do you use a small hand pump, albeit with a Lenzne head to pump up a tire to 115-120 psi when they have compact Co2 systems that will do it in seconds. I do not understand this from a size perspective and a pumping perspective.
#58
One rim was drilled for Schrader, one rim was drilled for PrestI. I drilled the PrestI rim for Schrader.( because I hate PrestI) I do not know the throat opening of the rim. I have never measured it. But it accepts my 23-25mm tires. In no way in my mechanical judgement did I compromise the integrity of that rim by drilling it out slightly for Schrader. Not in the least. There is still plenty of metal on the sides of the valve along the rim flat,plenty. Bead seats just fine around the Schrader Valve, in fact I would say easier because the valve isn't sliding up and down.
#59
Interesting idea and I may try it, but not sure I can indent my tire far enough.
#60
You are absolutely right - the advantage is debatable.
#61
Quite the contrary, I am shedding light on long held misbeliefs. It is just that no one can admit their past practices do not hold up to logical scrutiny. You can lead a horse to water but you can't make him take some.
#62
It's MY mountain
Liked 2,985 Times
#63
Why do you have to be swayed to what you consider following the crowd? The presta vs schrader isn't a big issue for anyone here. You are the one that is having problems with it.
The industry doesn't have to provide the perfect solution at any one moment. They just have to provide what most people will buy. The industry does provide you with the option to have your bike with your valve of choice. Albeit you may not get the rims you want.
#65
It's MY mountain
Liked 2,985 Times
FNG
Likes For DiabloScott:
#66
Given my narrowest tires are in the 40's I'm the wrong person to ask.
But I'd think that a rim for a 23 or 25 tire would be under 20mm in width at which point drilling for a Schrader cuts out at least half of it. It would also seem to require the valve to tube seal to pinch into a very narrow inner width.
Granted, the inner web of beam like structural members often does have lightening holes in such a position.
#67
As for valves, I agree with you -- to each his (or her or whatever) own. And why do we have presta valves at all? I've long thought it started with tubulars and when people started using clinchers on narrow rims they wanted a valve that would work with their pumps.
As for pumps and presta valves, I had a Zefal pump for years and it worked fine on presta valves. I either lost it or it was stolen and the Zefal pump I bought to replace it is supposed to be for both presta and Shrader but I can't get it to work on either. Topeak Road Morph does the trick,though.
Have a Silca floor pump that I bought back in the 80s and the Shrader piece (little prong to depress the valve) broke years ago but it kept working on the prestas. Then, the bushing finally wore out and it wouldn't seal. Replaced with an official Silca polyurethane bushing and now I can't get the presta valve into it so I replaced the head with a Lezyne reversible chuck and it screws on to both presta or shrader and works like a charm.
Bought an SKS pump not too long ago supposed to come with what they call an EVA head -- either presta or shrader, shove it into the same hole and go for it. But, it came with a two port head, one hole for shrader, the other for presta. Presta works ok but the Shrader end wouldn't work. Bought an SKS EVA replacement chuck and all works fine though I don't pump shraders with it because the Lezine chuck works so well for that.
Now that makes sense. Tubular Tires all came with PrestI Valves and when Clinchers came out they could use there pumps that they had for there Tubulars and wanted something familiar. But it was just a carry over from Tubulars that made people feel racy. That is what I am talking about. Something carried over with no real purpose and people just keep on doing it and don't know why. Just because that is how it was done in the past even though it was an entirely different tire. I do not agree with that.
I do not know the proper spelling,I just learned of this, but the "Lezine" head sounds like the only way to go. You are the second person to bring it up.(he spelled it differently I believe) I assume you buy just the head and install it on your existing pump. I can look it up but do you know the general costs? That screw on head would be flawless. I have a descent pump with a descent head on it but flip levers have always given me trouble. They actually hurt my hand. This thing should work like a dream and solve that problem completely. The guy posted a picture of it and it really looks good. That flipping of the lever is the worst thing about pumping up tires. Got to get one...Thanks,mjac
#68
The answer to your question is "No - I didn't mean tubeless". and by the way, your ability to troll us will improve when you can talk the talk.
FNG
FNG
#69
Girly - PrestI...That simple. Just making fun. You have to have a special valve that serves no purpose. At least no one has been able to provide one.
I get that you don't like presta valves. I've heard that when God made shrader valves he realized right away what a terrible mistake he had made but rather than fix it, he decided it would be easier to just make people that liked them.
As for your attempt to insult people for fun by implying that presta valves are for sissies, it isn't very funny and it's not really effective as an insult. I don't know why you do it. But, I don't know why you like shrader valves either.
Likes For desconhecido:
#70
Mad bike riding scientist
Quoted: 6227 Post(s)
Liked 4,231 Times
Just the opposite with me. I lose less air disengaging a Schrader then a Presti. I had to re-pump a Presti tire last night because I thought I lost too much air disengaging. And invariably I will lose all air in the tire while engaging. Or if you do get it engaged with air in the tire the pump is hard to get started. All in all a PIA.
The advantages of the Presta valve is that it is a one way check valve. Any pressure in the hose over the internal pressure opens the valve and lets air into the tube. When the pressure in the hose equals (or falls below) the pressure in the tube, the Presta valve closes. Rinse and repeat as necessary.
Schrader valves, on the other hand, have to be held open throughout the pumping process. If air is leaking out of the hose or chuck (a common occurrence), there is air leaking from the tube. You could make them work like a Presta valve but the “cracking pressure” or the pressure needed to open the valve is much higher in the Schrader valve. It’s on the order of 25 psi. In other words, to open the valve requires 25 psi higher than what is in the tube to open it.
This is why I started this thread. I want a Lenzne Head,period. I have a pretty good GV Pump with the best flip handle on the pump head I have ever had. But I have to place my thumb directly over the head, which is double sided, to get it over the valve and bury it, then brace that hand against a spoke while flipping the handle with the thumb on the other hand. It can be painful. How does this work. You buy just the head and install it on your pump or do they also make a pump and it would be better to buy the whole pump? Probably just the head. I can look it up, but what is the cost and what is the best option?
Additionally, carbon dioxide diffuses from the tire very quickly. They can experience significant pressure loss in 24 hours or less. They are for short term use.
Stuart Black
Stuart Black
#71
Quoted: 1062 Post(s)
Liked 665 Times
What I've heard is that the smaller hole is preferable for very narrow rims. It's also possible that with care, you lose less pressure as you remove the pump head, which would be a potential issue with narrow and high-pressure tires.
I've personally had Presta tubes fail at the base of the stem, but have never had a Schrader tube fail in that way. Others have had better results with Presta tubes. Reliability is a hard thing to pin down because it can depend on user technique, or on the condition of other parts such as the hole in the rim itself and the quality of the pump head. A burr in the hole could bode ill for tubes.. Likewise for a futzy pump head. On the other hand, a design that's more sensitive to user error may be regarded by some people as a less reliable or more delicate design. The distinction may factor into the choice of parts for bikes that are used in less well controlled environments, such as by beginners, or in shared use.
A little bit of your own personal spittle on the pump head might help. Inspecting the inside of the valve hole is advisable.
Personally, if I had rims drilled for Schrader and was able to achieve satisfactory pressure, I wouldn't see a reason to use a Presta tube. If a bike was made that way, it probably has wider and relatively lower pressure tires anyway. I live with having both kinds of valves in the family fleet.
With many kinds of bike components, history has given us multiple standards with no clear winner, and extensive anecdotal advice about which one is preferable. Making your own choice in the face of conflicting advice is part of the fun.
#72
If you are losing all the air while engaging or disengaging the pump head from a Presta valve, you are doing something very wrong. The pump chuck should slide over the valve without even releasing air. When you disengage the pump, you should just pull it off.
Schrader valves, on the other hand, have to be held open throughout the pumping process. If air is leaking out of the hose or chuck (a common occurrence), there is air leaking from the tube. You could make them work like a Presta valve but the “cracking pressure” or the pressure needed to open the valve is much higher in the Schrader valve. It’s on the order of 25 psi. In other words, to open the valve requires 25 psi higher than what is in the tube to open it.I
The Lezyne head is the worst head for Presta. The whole point of a Presta valve and a Presta chuck is to not have to screw it on. The second worst design is the flip lever head. It’s not needed for a Presta. The chuck slips onto the valve and is held by friction. The best chuck for Presta is a Silca chuck or cheaper variant. It’s a simple mechanism that is highly effect and avoids the problem of pushing down on the pin of the Presta valve.
Because carbon dioxide canisters are single use. Have 2 flats and you are walking home. Pumps never run out of air...as long as you can breathe, they work. If you can’t breathe, you have bigger fish to fry.
I thought the Co2 was double use. I have to rethink this. I did feel there might be an issue with it being a different gas. I just did not know what it was. Turns out it is a lighter gas and dissipates. So it has draw backs. I did not know any of this and went out and got an inexpensive one because it was compact. Live and learn.
#73
Lezyne is the spelling and the chuck that I bought with a hose from Amazon is about $19. The have small pump that will mount on bottle bosses, I believe, with the double ended hose for about $25. One thing you need to know about the Lezyne double ended chuck. It has a pressure release valve for use with presta valves only. If you push it while a shrader valve is connected, it will likely release air as the shrader valve, because of its inferior design, cannot be inflated just with air pressure alone. The spring loaded valve must be depressed. Isn't that depressing?
Schrader inferior? PrestI week base. Schrader strong base. That is it. That simple. No one, I mean no one, has told me one advantage PrestI has over Schrader. That is all I am asking. What advantages does PrestI have. I know of one the Schrader has.
Lets make one one thing perfectly clear. I am not insulting anyone and never will. I am not implying anything about people who use PrestI Valves. That is an inference other people have made. It does not matter to me what valve people use, that is their preference and I have no right to question that. I am making fun of the valve out of the utter frustration of lost rides,time and expense because of them out of frustration in a fun way. Little PrestIs. I don't like them. So I make fun of them. Not the people who use them and they can come on and defend their use of them.
#74
Liked 4,231 Times
Right now I have a pretty good pump called the GV but it is of the type you say is second worst design for PrestI. It has a barrel head with a Schrader head on one side and a PrestI head on the opposite side actuated by a lever. It is a pretty good design but the lever is hard to engage. When I put the PrestI head over the valve I have my thumb over the top of it(the Schrader end) to shove it on. When I shove it down air pours out of the Schrader end where my thumb is. Usually letting all the air out of the tire. So I assume the same thing is happening when I release it. Everyone says no. I don't know. I do not have these issues with the Schrader. Hence the frustration. I was told the Lezyne Head works well with PrestI and Schrader. You say no. That is why I am here. To find out. I am not using PrestI valves, I do not like them. I do not like the lever on the pump head. So I would like to use the Lezyne on the Schrader Valves.
The issue you seem to be having is that you are jamming the head on to the Presta valve as far as it will go. You don't need to do that. All you need to do is to clear the threads for the valve cap and throw the thumb lock. The valve shouldn't come in contact with anything inside the chuck. It doesn't need to and it's detrimental to keeping air in the tube. Let the valve work like it is supposed to...as a check valve. No need to hold it open.
The problem with the Lezyne (and many other pump chuck designs) is that it sacrifices the simplicity of the Presta valve for no reason. The Lezyne head needs to be screwed into place. It's fiddly. "Smart heads" (which aren't, really), have a soft pin that pushes on the Presta valve which is also not needed. The Silca chuck simply slips on and slips off. There's nothing inside the head that even touches the pin on the Presta valve. Slide it on and pump the tire. Slide it off when done.
The Silca is a bit expensive...$40!!!!...but there are others that work just as well without costing an arm, leg and first born child. The SKS adapter
is usually less than $10 and works as well as the Silca without the name.
Carbon dioxide is actually the heaviest of all the naturally occurring atmospheric gases. It's also a huge molecule in terms of the bond lengths. Oxygen, nitrogen and water are all fairly small in comparison. The issue with it diffusing out of rubber isn't the size but the way it interacts with the rubber. Oxygen, nitrogen and water vapor...in order of rapidity...diffuse through the rubber via small channels and holes in the rubber and are rather slow to do it. Water can't really get out of the rubber at all because of it's molecular shape and the electron configuration.
Carbon dioxide, on the other hand, doesn't just diffuse through the rubber, it actually dissolves through the rubber. It doesn't weaken the rubber but it makes a kind of solid/gas solution and zips right through. It has a lot to do with the electron configuration and the shape of the CO2 molecule.
All of the gases with the exception of water (which really isn't a "gas") will diffuse from the high pressure system in the tire to the lower pressure outside the tire. CO2 just does it better than the other gases.
Stuart Black
Stuart Black
#75
Quoted: 1572 Post(s)
Liked 644 Times
The question was rhetorical. The post was really an observation.
