Studded Tires Okay on Dry Pavement?
Here in Omaha, we will have times when the roads have snow and ice. Then, there will be times when the roads are clear. And there will be a mixture of clear roads and snow-covered bike trails.
Can I put studded tires on my bike and (still) ride when the roads are clear?
My legs hurt
Bikes: Vaya, Brompton, '73 Schwinn Super Sport, Cresswell Fold-it, '81 Trek 610
yup. It will just be noiser, and there will be more rolling resistance (compared to non-studded). Won't hurt the tires any provided they have carbide studs.
I might add, just make sure and break them in properly, no fast braking or acceleration for the 25miles or so, this will allow the studs to bed into the tire
then there should be no problems, just increased rolling resistance and a popcorn sound from the studs riding on bare pavement, just leave them on all winter till spring(as long as they are carbide studs)
on the bright side....when you take them off in spring you when be amazed how much easier and faster you are from building up your
strength during the winter
one last thing, if you haven't purchased yet, I might recommend Schwalbe Marathon Winters
I have ridden Nokian 294 Extremes for the last 5 years and just bought a set of marathons. I rode them yesterday in our first snowstorm and even with the resistance they rode way nicer than the extremes, close to a standard slick when I had the psi up higher
Plus you can adjust the psi higher for almost no resistance and lower psi for more studs in contact and they initially look like they will last many winters
I wouldn't use them off trail, that's what i use the extremes and ice spikers for, but for commuting and city roads these are fantastic
also good studded carbide tip tires are expensive but if broken in properly will last many, many years so the cost is spread out
ride for a change
Bikes: Surly Cross-check & Moonlander, Pivot Mach 429, Ted Wojcik Sof-Trac, Ridley Orion. Santa Cruz Stigmata
We have a lot of days like that too. It's cold as hell but the roads are bare. Keep them on. Conditions change rapidly and You never know when you will encounter ice and what not. As others have stated as long as they are carbide they do not wear down and should last you many seasons.
I purchased the tires listed on the link below. This is my first year of winter cycling, so I don't claim to know what I'm doing.
https://www.modernbike.com/itemgroup.asp?IGPK=2126177347
Thanks for the answers. When I get the tires, I'll mount them immediately. Hey, I'm an old man trying to burn calories. Added resistance doesn't bother me a bit! :-)
Quoted: 4227 Post(s)
Liked 2,491 Times
It's ok to run studs on pavement... but I still think it's best to have two wheelsets, one with studs and one with regular tires. Every winter is different, no reason to run studs for months at a time...I only use studs when I feel it's neccessary.
Still spinnin'.....
Bikes: Fisher Opie freeride/urban assault MTB, Redline Monocog 29er MTB, Serrota T-Max Commuter, Klein Rascal SS, Salsa Campion Road bike, Pake Rum Runner FG/SS Road bike, Cannondale Synapse Road bike, Santana Arriva Road Tandem, and others....
+1
I even advocate two extra wheelsets in extreme climate areas that can vary significantly day-to-day like the Rocky mountains or northern midwest areas. I have one set with Nokian Extremes 294s for seriously bad conditionsor seriously icy conditions, but they will slide around on bare, dry asphalt to the point that they can be dangerous, and they have extremely high rolling resistance,especially when climbing. Another set has Nokian Mount and Ground 160s for less extreme condtions and most road use because they have far less rolling resistance and slide around less on dry asphalt, and if I don't change them on dry days I don't feel like I'm riding into a 25mph headwind when I actually have a 10mph tailwind.
+1
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 459 Times
+2 on the Marathon Winter's. Most of my winter riding is on dry roads, but I live in an area with many natural springs which seep onto the road in colder weather. I use them so I'm not surprised by spots of ice. There is more rolling resistance, much like riding on a cinder path, just all the time. Once you get used to it though it is not a big deal. Then again, because the early darkness, I'm usually using a bottle generator as well which adds more resistance. No biggie because I ride for fitness and I just get more of it.....
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
In the right lane
This is the 4th winter for my Nokians, riding on mostly dry pavement in the winter. Guessing conditions very similar to Omaha.
My legs hurt
I tried the two wheelset thingy one season. I guess I'm just too lazy, or bad at planning, because it seemed like I always had the wrong tire mounted.
I've overcome this deficiency with a cunning plan: two bikes! Then I just grab the bike with the right tires...
Paul
Anyone tried out the 45North studded tires yet? Have a pair waiting for me at the LBS that will be mounted Friday.
right after the announcement by 45North that they were going to offer the Husker Du and snowstudded tire they said the studs were steel, but I was looking several weeks ago online and online shop listed the studs stainless steel
carbide will last for many, many years, stainless I assume should last years.........regular steel studs will wear down after a season if you ride on pavement..I know, my first pair were cheapie innova knockoffs and the lasted less than the winter season..the next year I bought a set of Nokians 294's and after 5-6 they still have many years left on them
otherwise a very nice looking winter tire
This was posted in the sticky about making your own studded tires a few years ago. You can leave the studs off the middle of the tires and just have them at the edges. Then you can ride on dry pavement without the studs coming into contact with it. If you do need the studs, just let a little air out of the tires.
I don't use studs myself, but thought that's the way I'm going to try first if I do want to use them.
So...what is the recommended MTB tire? Nokian 294? Don't know if I want to go the steel route when carbide will last me longer.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 337 Times
In my experience, the studded tire are slower on a clear pavement than they are on a surface with light mixture of snow and ice. Thus, riding them on the clear pavement is a drag. When the situation is uncertain, a good compromise might be to put the studded tire only on the front. A further option for a compromise could involve Continental TopContact Winter. They have no studs but protect better against slipping on ice than regular tires.
Still spinnin'.....
The Mount and Grounds have much less rolling resistance and if the roads are really icy, but not so bad that it keeps car off the road I just drop the pressure down to 40-45psi and go on my way. Its nice to have a choice, but if I had to pick just one set I'd probably take the Mount and Grounds because under normal winter conditions they work fine. The Extremes are really not necessary until conditions are so severe that most people won't even consider going outside, but I want the adventure.
My experience with Schwalbe Marathon Winters is about the same as the Mount and Grounds, but I wouldn't even consider any of the other brands (i.e., Innovas and many of the cheaper brands carried by REI et al) because they either use steel rather than carbide studs or they just don't have proper distribution of the studs.
Quoted: 840 Post(s)
Liked 337 Times
Quoted: 539 Post(s)
Liked 44 Times
I guarantee you, where I am there is *definitely* reason to run studs for months at a time.
These seem to be on overkill for someone who just starts riding in winter. Let me explain. Extreme 294 are meant for really tough conditions. There are plenty of milder conditions when you already need studded tires. You put on tires such as Extremes when everything is stacked against you. Someone experienced in winter riding will eventually need the Extremes, but before your skin thickens this much you need to get an experience riding under conditions calling for milder tires. If money is not a factor, sure, but some milder tires should be a higher priority.
Hey, I just saw the tires on sale and bought them. They were the cheapest studded tires I found on the Internet.
The more rolling resistance, the better. I'm just looking to maintain a level of fitness until the warm weather returns. In the summer, my typical road ride is 75 miles. With the cold, I don't want to be out for that period of time. If I can get a fitness benefit out of my 20-mile winter rides, then great!
Maybe these would be better?
https://www.biketiresdirect.com/produ...w-stud-26-inch
Less studs but have carbide (as mentioned to be the best). I keep to the paths that are, eventually, shoveled, and have no plans to go deep into inches of snow.
Snow studs are the old Schwalbe studded tyres. Marathon Winter are the new replacement for them - many-more studs and I believe the Snow studs are steel rather than carbide.
