powercranks - any one use them?
Old 07-14-05 | 05:16 PM
markhr's Avatar
POWERCRANK addict
at the risk of being flamed to death by Raiyn (flinch - braces for impact) amongst others
As a powercrank virgin I thought, given my lack of coordination in other areas (can't catch and can't kick - hence I play prop), there would be a fairly steep learning curve but...
Suprise 1 - I am a smooth pedaler - even managed to crank them up to 150rpm+ for a couple of seated sprints.
Suprise 2 - while they definitely work more muscles (back, stomach and inner thighs - would you believe) they're not as hard work as expected.
Now I just have to practice my starts and stops before I brave London traffic with them.
Anyway the point of all this is to find out how many others have used powercranks and their thoughts on them.
Thanks
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
markhr is offline
Reply
Old 07-14-05 | 05:19 PM
genec's Avatar
genec
Thanks
What are powercranks?
genec is offline
Reply
Old 07-14-05 | 05:28 PM
Sprocket Man's Avatar
Prefers Aluminum
Bikes: Wife: Trek 5200, C'dale Rush Feminine, Vitus 979 Me: Felt S25, Cervelo Soloist, C'dale Killer V500, Miyata Pro (fixie)
If you've never been to slowtwitch.com, check out that forum. They had a long thread about Powercranks which included a lot of posts by the inventor of the device. I'd love to try them, but after dropping >$1,000 on wheels and accessories this year, I'm afraid that's not going to happen for me
Sprocket Man is offline
Reply
Old 07-14-05 | 06:13 PM
markhr's Avatar
POWERCRANK addict
Genec - have a look at www.powercranks.com
Sprocket Man - yeah, while I was doing some research before purchase I came across that and some of the archived bike forums stuff too. Some of the opinions expressed were quite strong.
markhr is offline
Reply
Old 07-14-05 | 06:46 PM
genec's Avatar
genec
I can see how they would work... I found rollers to be quite good at smoothing my stroke.
Lotsa bucks though.
genec is offline
Reply
Old 07-14-05 | 08:23 PM
catatonic's Avatar
Chairman of the Bored
20 Anniversary
Bikes: 2004 Raleigh Talus, 2001 Motobecane Vent Noir (Custom build for heavy riders)
god their explanation is excessively wordy.
Sounds cool though.
catatonic is offline
Reply
Old 07-14-05 | 08:39 PM
Guest
Guest
Posts: n/a
Anyone willing to ride powercranks on the streets is all good in my book.
Dood, you are good! Keep me informed on how it works for you out there.
I've used powercranks for short intervals of time, and I might get them at some point down the road.
Powercranks on rollers... that might be something too...
Koffee
Reply
Old 07-15-05 | 05:26 AM
markhr's Avatar
POWERCRANK addict
catatonic - the verbiage is pretty painful to plough through but then again who ever heard an MD simply say uuuuuuhhhhhmmmm, you're sick, take these.
Koffee - thanks, don't know about good wait and see (watch out for that bus oops too late). I just want a running substiute so cycling to work on these should do the trick
anyway peeps there must be more of you out there so please share your experiences - good/bad/other.
markhr is offline
Reply
Old 07-17-05 | 12:10 PM
catatonic's Avatar
20 Anniversary
true, but they covered so much irrelevant crap.
They should have just said:
"Proper pedaling motion is a perfect circle amade with both feet at a 180 degree relative point in rotation. What this product does is ONLY transfers power when both feet are in their proper places int hat rotational pattern. This will help with pedaling technique through both positive reinforcement, as well as the tactile feel of either transferring power, or not transferring power. It does this via a special clutch....which works liek this....."
He didn't have to breeak it down into basic physics and the history of the crankarm
Reply
Old 07-17-05 | 02:08 PM
phidauex's Avatar
Spoked to Death
Bikes: Salsa La Cruz w/ Alfine 8, Specialized Fuse Pro 27.5+, Surly 1x1
To those who aren't sure what they are... Powercranks are crank arms that are each equipped with a ratcheting mechanism that allows each crank to drive the chainrings, but not drive the other crank. Normally when you push down with one leg, you are lifting up the other. With power cranks, when you push down with one leg the other crank remains still. "Pulling up" on the upstroke is no longer an option, but a requirement. The idea is that this will prevent biomechanical laziness, so to speak, and provide a powerful training aid.
Its interesting, like a sort of extension of the fixed gear concept, removing aspects of the bicycles function in order to prevent biomechanical laziness, and get your body working on muscles it doesn't normally use.
Sounds neat, but not 800$ neat.
peace,
sam
phidauex is offline
Reply
Old 07-19-05 | 08:45 AM
Guest
Guest
Posts: n/a
When are you going to start riding with the powercranks? I was thinking about ya today during my ride!
Koffee
Reply
Old 07-19-05 | 09:07 AM
cab horn
20 Anniversary
Bikes: 1987 Bianchi Campione
I disagree. With fixed gear you can cheat because the rear wheel will push the pedals over for you because of your forward speed (or backwards). With powercranks no such thing exists. The real benefit of fixed gear is that you MUST be pedalling all the time everywhere (unless you take you foot off the pedal).
operator is offline
Reply
Old 07-19-05 | 09:41 AM
markhr's Avatar
POWERCRANK addict
Koffee - thanks I'm going to try cycling in to work tomorrow. The practice on the turbo and stop/start practice on the soccer field at the back of the house seems to be going ok.
Something I have noticed, not scientific/measured/accurate, it seems that I get 2-3kph extra for the same perceived level of effort. Hip flexors are pretty stiff though.
markhr is offline
Reply
Old 07-19-05 | 10:49 AM
Eggplant Jeff's Avatar
45 miles/week
Bikes: Jamis Aurora
Yeah seems like they're excessively sure of themselves too. I can see why there are so many strong opinions...
Definitely a painful site to have to read just to figure out what they are.
Eggplant Jeff is offline
Reply
Old 07-19-05 | 04:03 PM
Guest
Guest
Posts: n/a
Those powercranks do make you work the hip flexors more than you usually would with cycling.
Good luck. Report back!
Koffee
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
