Compact Crank Overload
Old 07-19-05 | 04:29 PM
ggg300's Avatar
Burnin' and Lootin'
FSA ^^^ getting a lil crazy...
Do you all think we should get a sticky for the topic? If so would you add anything to the following?
This is about all you will need to understand the idea and use of a compact crank.
Compact Crank https://www.sheldonbrown.com/gloss_cn-z.html
A double-chainring crankset with that permits the use of smaller chainrings than will fit with the common 130 mm B.C.D.. Most "compact double" cranks use the old standard 110 mm B.C.D. which permits the use of chainrings as small as 33 teeth (more commonly, 34 or 36 teeth.)
Compact crank sets usually come with a 50 tooth chainring, and will normally go with an 11 or 12 tooth top sprocket in back.
110 mm B.C.D. double cranks with full-sized (52-42, 52-40, etc.) were common in the late'70s and early '80s, but they had become nearly extinct for double chainrings. The rebirth of this format, with smaller rings, was pioneered by Tyler Hamilton who used one of these in the 2003 Tour de France https://www.tylerhamilton.com/home1.html
The basic idea behind the use of the compact as it relates to top speed and low speed:
https://www.slowtwitch.com/mainheadin...r/gearing.html
How to counter some one who thinks you’re weak for getting a compact:
1. Oh ya…..My 50/11 is bigger than your 52/12.
2. Oh ya…..Your “standard crankset” with a 52/39 is really a normalized compact crank because old standard was a 52/42 for a double.
3. Oh ya….How are your knees?
4. Oh ya….sticks and stones may….
5. Oh ya...I can make my compact go from a 34/50 all the way up to 42/52 if I wanted too....https://www.bikeusa.com/components/chainrings.html by just getting the right ring set.
seems like 50/34 is not as cool as the 50/36 for some :https://www.bikeforums.net/showthread...=291496&page=2
You can get Ringset for the 110 crank at:
.... https://www.bikeusa.com/components/chainrings.html
.... https://aebike.com/page.cfm?PageID=30...ory=203&type=T
.... https://www.speedgoat.com/catalog.asp?cat=50
A few BF threads on the topic:
Lowest gear: https://www.bikeforums.net/showthread...=compact+crank
Review: https://www.bikeforums.net/showthread...=compact+crank
Who uses them: https://www.bikeforums.net/showthread...=compact+crank: https://www.bikeforums.net/showthread...79#post2092279
Best Value: https://www.bikeforums.net/showthread...=compact+crank
V.S Triple: https://www.bikeforums.net/showthread...=compact+crank https://www.bikeforums.net/showthread...20#post2178520
Pride: https://www.bikeforums.net/showthread...=compact+crank; or some just don't get it https://www.bikeforums.net/road-cycling/160270-50-36-chainset.html
some smack talking... https://www.bikeforums.net/showthread...=172843&page=3
Can my standard crank go compact? https://www.bikeforums.net/road-cycling/124072-no-one-makes-50-34-replacement-chainrings.html
50/34 vs 50/36 and other issues https://www.bikeforums.net/road-cycling/288462-dissapointed-my-compact.html
What you’ll pick up after reading some of the BF threads:
1. There is and always will be a double vs. triple argument.
2. Flatlanders just don’t get it.
3. sydney will let you know what is compatible with a compact crank. edit...RIP...miss the man!
4. Even Terry Morse the Climbing Fool has one.
5. Some want the compact b/c:
a. It is lighter
b. It “shifts better” than a triple
c. There is less to think about in terms of which gear one should to be in.
d. It was the cheap way to get triple like gears without an expensive upgrade for a bike that is a double.
e. They ride a lot of hills/mountains
f. Other reasons or a mix of the above.
ggg300 is offline
Reply
Old 07-19-05 | 05:47 PM
Fox Farm's Avatar
20 Anniversary
Bikes: Time ADH01, Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Actually, Tom Ritchey started to offer his Ritchey Logic compact crank set with a 110mm spider 5 or 6 years ago. The funny think was that the first generation of this offering came with a 53 38 set of chain rings. While living in Michigan, I swapped the 38 for a 42 and was very happy. After moving to the Rockies, those came off and a 50 34 set of rings went on. I would say that Tyler and or his mechanics simply popularlized an existing concept.
Fox Farm is offline
Reply
Old 07-20-05 | 10:31 AM
ggg300's Avatar
Burnin' and Lootin'
online place to get a CC
https://aebike.com/site/page.cfm?Page...ory=181&type=T
https://www.excelsports.com/new.asp?p...jor=1&minor=13
https://www.performancebike.com/shop/...tegory_id=5122
https://www.nashbar.com/subcategories.cfm?category=81
https://www.qbike.com/category/cranksets.html
https://www.westernbikeworks.com/htmlpages/DEPWR.htm if you want one that no one has...
ggg300 is offline
Reply
Old 07-20-05 | 10:40 AM
ggg300's Avatar
Burnin' and Lootin'
Some say that the shifting for a compact is not as good as with a reg. double, but a lot of us will tell you that you can use a reg double derailleur, but if you want to be pick-e there are 3 Front Derailleurs to pick from:
IRD Compact Front Derailleur:
https://www.excelsports.com/new.asp?p...=33&site=qbike
Full Speed Ahead Front Derailleur C-16 Compact
Campagnolo Chorus CT Compact Front Derailleur
https://gallery.bcentral.com/GID49468...erailleur.aspx
some BF on the Campy https://www.bikeforums.net/road-cycling/160783-campy-compact-front-standard-derailleur.html
ggg300 is offline
Reply
Old 07-20-05 | 11:03 AM
ggg300's Avatar
Burnin' and Lootin'
Bicycle Mechanics and the compact crank:
Issues - Compact Crank on a FREEWHEEL Ultra7? https://www.bikeforums.net/showthread...=compact+crank
52/36 chainrings?
Ttriple Crank To Compact Conversion
spreading FD cage for compact crank
Compact Cranks and Front Deraileur
https://www.bikeforums.net/showthread...=compact+crank:https://www.bikeforums.net/showthread...16#post2082816
https://www.bikeforums.net/showthread...67#post1433267
https://www.bikeforums.net/bicycle-mechanics/158923-compact-crank-needs-right-derailleur.html
Trek and the file...https://www.bikeforums.net/road-cycling/175506-compact-cranks-trek-oclv-braze.html
53/39 to compact conversion question
chain rub w/ FSA compact crank
Issues with 10 speed:
https://www.velonews.com/tech/report/...es/7844.0.html
big arms https://www.bikeforums.net/bicycle-mechanics/168270-does-any-company-make-177-5mm-180mm-compact-crankset.html
ggg300 is offline
Reply
Old 07-20-05 | 11:16 AM
ggg300's Avatar
Burnin' and Lootin'
Best overall overview with pics:
https://www.roadcyclinguk.com/news/ar...AN/200/v/2/sp/
a ride worthy of a compact https://www.sport-adventura.com/Riding%20the%20cols.htm
ggg300 is offline
Reply
Old 07-20-05 | 12:04 PM
ggg300's Avatar
Burnin' and Lootin'
FSA's website for a gear comparison
https://www.fullspeedahead.com/downlo...comparison.pdf
and
for your do it yourselfer
https://www.sheldonbrown.com/gears/
what a BF chat about gears looks like https://www.bikeforums.net/showthread...=114657&page=1
ggg300 is offline
Reply
Old 07-20-05 | 12:09 PM
ggg300's Avatar
Burnin' and Lootin'
Cycling Cadence a reason for more low gears:
https://www.beginnertriathlete.com/cm...?articleid=433
https://www.trainright.com/articles.a...splay&uid=2091
ggg300 is offline
Reply
Old 07-20-05 | 12:17 PM
ggg300's Avatar
Burnin' and Lootin'
Why Hamilton went Compact?
https://www.bike-zone.com/tech.php?id...003/news/jul28
"The lower gears helped Hamilton stay seated on the climbs, and recover enough eventually to break away from the peloton on the first slopes of the Col de Soudet and take out a stage win."
ggg300 is offline
Reply
Old 07-20-05 | 12:20 PM
ggg300's Avatar
Burnin' and Lootin'
PEZ-Test: FSA Compact SL-K MEGAEXO & K-Force Cranks
https://www.pezcyclingnews.com/?pg=fullstory&id=2976
"Interesting Point #1: North American interest in compact cranksets got a big resurgence after Tyler’s 2003 TDF, but these things have been huge in Europe – and especially Italy - for years. Turns out the Gran Fondo set have been running compact cranks for a while, and we’re not talking a bunch of granny rollers here – these are the cycling nutters who train hard like we do, all for the purpose of humiliating the guy from the next town over in one of these several thousand rider “races” that often run up to 250km."
ggg300 is offline
Reply
Old 07-20-05 | 01:09 PM
ggg300's Avatar
Burnin' and Lootin'
First to go CF on CC as claimed by...
https://www.bikyle.com/PinarelloHistory.htm
ggg300 is offline
Reply
Old 07-20-05 | 01:15 PM
ggg300's Avatar
Burnin' and Lootin'
Shimano has also formally announced the "FC-R700"
https://www.competitivecyclist.com/za...RSET_VERSION=1 Some owners want a 36t ring for that crank but can find one by shimano via FC-R700...you have to go to FSA or other makers for the 36t...
and not to be out done mid level campy....https://www.bikeforums.net/road-cycling/155867-veloce-now-has-compact-crank-06-a.html
ggg300 is offline
Reply
Old 07-20-05 | 01:37 PM
ggg300's Avatar
Burnin' and Lootin'
Crank Sets BB and weight
https://weightweenies.starbike.com/li...type=cranksets
https://weightweenies.starbike.com/li...bottombrackets
ggg300 is offline
Reply
Old 07-20-05 | 01:52 PM
ggg300's Avatar
Burnin' and Lootin'
FSA FAQ re CC?
https://www.fullspeedahead.com/fly.as...ut=tech&cid=66
ggg300 is offline
Reply
Old 07-20-05 | 01:55 PM
ggg300's Avatar
Burnin' and Lootin'
ISIS VS. MEGAEXO
https://www.fullspeedahead.com/fly.as...ut=tech&cid=57
ggg300 is offline
Reply
Old 07-21-05 | 12:08 PM
ggg300's Avatar
Burnin' and Lootin'
A Funny by velocipedio on the topic:
"if you need a low gear [for your standard double], get a 12-27 cassette. if you need a lower gear than that, go for the compact crankset. if you can't get up a hill with a 34/27, then you are either cycling in the himalayas or dead."
ggg300 is offline
Reply
Old 07-21-05 | 01:06 PM
galen_52657's Avatar
Bikes: 2001 Look KG 241, 1989 Specialized Stump Jumper Comp, 1986 Gatane Performanc
Are you selling compact cranks???
galen_52657 is offline
Reply
Old 07-21-05 | 01:33 PM
ggg300's Avatar
Burnin' and Lootin'
Hay galen. How is it going?
Na just gone a lil nuts on the topic b/c it I am kinda sick of seeing it asked about over and over again. I can't find anything to add to what is here. I guess I am done.
ggg300 is offline
Reply
Old 07-22-05 | 12:33 PM
cyclezen's Avatar
OM boy
20 Anniversary
Community Builder
Bikes: a bunch
[QUOTE=ggg300]Do you all think we should get a sticky for the topic? QUOTE]
Definitely! should be sticky
cyclezen is offline
Reply
Old 07-22-05 | 02:45 PM
ggg300's Avatar
Burnin' and Lootin'
[QUOTE=cyclezen]
well that make two votes for a sticky! feeling good!
I know that most BFs don't have the Attention Span for a thread like this, but got to give it a try.
ggg300 is offline
Reply
Old 07-22-05 | 05:52 PM
20 Anniversary
Bikes: Cannondale CAAD5 w/campy chorus, Orbea Zonal, Guerciotti
42/21 is as low as you need to go...
No wait - that was what I rode in 1985...
Arizona-Cyclist is offline
Reply
Old 07-24-05 | 08:57 AM
ggg300's Avatar
Burnin' and Lootin'
Things do change...the 12t and the 11t cog really lets us play with what we have up front.
ggg300 is offline
Reply
Old 12-09-05 | 12:33 PM
ggg300's Avatar
Burnin' and Lootin'
https://cycle.shimano-eu.com/catalog/...=1134153393557
its here...BF on topic...https://www.bikeforums.net/showthread...71#post1905071......review....https://forums.roadbikereview.com/showthread.php?t=46628
some issues with getting the crank and the bearings...https://www.bikeforums.net/road-cycling/175294-shimano-compact-crank.html
ggg300 is offline
Reply
Old 12-09-05 | 03:14 PM
20 Anniversary
Bikes: Ron Cooper, Time VXSR, rock lobster, rock lobster, serotta, ritchey, kestrel, paramount
the question is: what is more popular threads about compact cranks or shmano vs. campy? i think everyone is bored with shimano vs. campy and cc is the next best thing to post on.
fogrider is offline
Reply
Old 12-09-05 | 04:44 PM
55/Rad's Avatar
Former Hoarder
20 Anniversary
Bikes: Steve Rex, Seven Axiom, Felt Z1, Dave Moulton Fuso
So, I'm thinking of going with a compact. Where can I find information that will help me decide?
Good job ggg300.
55/Rad
55/Rad is offline
Reply
