6 or 12 degree HID flood?
Ride the Road
Bikes: Surly Cross-Check; hard tail MTB
I've narrowed down my light choices to a 12 or 6 degree flood on a 13 watt HID. I'm mainly concerned about visability in low light traffic conditions (rain, dusk), but I'd also like to clearly see where I'm going on semi-lit streets as well as on a pitch-black MUP.
Which do you think will better do the trick. My Cygolite HID just died (after a miserable 18 month life), and I have not been able to find any technical information to tell me what that was. If you know the answer to that, it will give me a frame of reference.
Thanks.
Thanks.
Seņior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
I've got a 6 degree spot, but I've never seen the flood, so I can't help you much. I think I might go for the 12 degree if I did it again. Here's a picture I took of my 6-degree model (trailtech)
Bikes: Bruce Gordon BLT, Cannondale parts bike, Ecodyne recumbent trike, Counterpoint Opus 2, miyata 1000
LongTimeCommuter
Bikes: Too Many
Thanks.
Thanks.
<https://www.batteryspace.com/index.asp?PageAction=VIEWCATS&Category=743>
They sell replacement HID bulbs. I've bought batteries from them, they seem honest.
They also have a HID light for around $120, assuming you already have a battery.
Ride the Road
Thanks to all who helped. I picked the 13W 12 degree flood. I checked with Cygolite (my POS dead HID) and they said it was also a 12 degree flood. I think that's about right.
I really appreciate the pix of Itsjustme's 6 degree spot. But that seems just too narrow to me for urban riding. But hey, to each his (or her) own. If it works for you, great. I think the spot would be most helpful on rainy days nights/early mornings when I need to be able whether that bloth in front of me is a hole, an oil slick, or just a discoloration or shadow. But, the flood seems like a more useful general purpose light.
P.S. Mods, this is the second thread about my light search. I started it because I wanted to discuss 12 degree v. 6 degree floods. Sorry if that was a mistake. I'd have no objection if you merged this thread into the first one.
Seņior Member
I actually wanted the 12 degree flood, but they mis-shipped me the 6 degree one. I didn't mount it on my bike for over a month, by which time they wouldn't take it back.
So be sure to check to see which one you have before you run out of time.
In reality lighting pics never seem to be accurate; the eye doesn't see how the camera does. The light to the side is brighter than it appears there, it's just that the spot in the center is very very bright and tends to de-accentuate the side lighting. I have no problems seeing stuff on the periphery; in fact my wheel casts a strong shadow, and washboarding and potholes are very well defined.
Bikes: 2 many
Bikes: 2 many
I ended up with the Trail Tech 13W lamp 12 degree flood. I'll post again in about a week when everything arrives to see if it works.
I have a 16 degree spread bulb. I though I would get the wide beam for off road, and just live with it on road, and see what happens. Because the bulb is symmetrical the wide beam also is wide in the direction of close to the front tire and far down the road at the same time. Not just right and left. Even on a road ride I like to see far away, and still be able to see the the ground nearby just in case I have to swerve around something. I don't see this mentioned much.
I'm pretty happy with the wide beam for road riding.
Ride the Road
Originally Posted by 2manybikes
That seems like a good light for the $$ to me. I'll be interested to hear about it.
Here's what I ordered from batteryspace.com:
Trail-Tech Individual 13W MR11 Eclipse HID Light Assembly for HID Lighting DIY
12 Degree flood
Part#: HM-HIDEHID-X
11.1V 7.2 Ah Li-Ion Battery in Water Bottle + Smart Charger for HID / Halogen Bikelight
Part#: CH-UNLI72C09
As I said above, I got the Trail Tech switch bought from the manufacturer. I believe it's the one on this page, except mine is blue.
I had to solder the female connecter to the switch cord, and I'm far from a master at that, so let me know if that could cause this problem. I don't see how it could, but if I knew what was really wrong, I wouldn't be posting this. Also, the battery has not been fully charged.
Fortunately, the light works off old NiMH battery from my POS Cygo-Lite HID system. That has a switch that works. But I'd really like to swtich to the Li-Ion battery if I could.
Also, someone said that I don't need a switch with a low battery indicator. Is that correct? If I don;t need it, how do I know to turn off the light before I damage either the battery or the light?
I used it going to work this morning in the dark and home from work in the rain. I connected it directly to the Li-Ion battery. It's really bright. Now, if I can just get a switch that works.
I'm almost there. Everything works on my DIY HID except the one part I got straight from the manufacturer. Any thoughts on what might be wrong? When I plug the battery directly into the light, it works. When I plug the battery to the light through the Trail-Tech switch, it works, but it won't turn off. I called Trail Tech. They said to send it in and they would take a look at it.
12 Degree flood
Part#: HM-HIDEHID-X
Part#: CH-UNLI72C09
12 Degree flood
Part#: HM-HIDEHID-X
Part#: CH-UNLI72C09
https://forums.mtbr.com/showthread.ph...ight=TrailTech
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
BTW I thought I'd just chime in, you should be able to adjust the focus a bit by changing the distance from the spark to the back of the reflector. If you were making a homemade unit, you might even be able to have the entire bulb assembly in like a damper assembly that has a knurled end threaded on the back of it that allows you to dynamically adjust the focus.
Bikes: 2 many
Bikes: 2 many
I would also like one "Supercooled LED" headlight. I could pick those up at the factory on my bike in two days, provided I have enough ammo.
Heh believe it or not, if I use the machinist we have at work, I can probably design it and have it built for the same price as your edison.
I would like to place my order now for one "Slvoidlights adjustable focus HID with flip down glare shield" before they are all sold out.
Ride the Road
I think if you just wait a little longer you will get the switch problem worked out. There seems to be a pretty good chance it really is a switch problem. Hang in there untill you talk to Trail Tech about the switch. I think you're almost done.
There was an issue with some batteries giving off too much initial voltage after a fresh charge and destroying the HID bulb connected directly to it.
Seņior Member
I have that light hooked directly to a battery. It's simply a question of voltage. The ballast in the light ideally wants 12.8-13.5 volts. TrailTech lists 14.8V as the max. I'm running mine on 12.6V straight into the light. I've had no problems with this setup.
Before, I ran a 14.4v, unregulated, into the light. a 14.4v NiMH puts out > 14.8V for > 1 hour at load, and I fried the HID. But if you use a 12V pack you won't have this problem.
If I was doing it over again I'd get a 12V NiMH and be done. I didn't go with LiIon because LiIon shuts down in cold temps, which is mainly when I need the light.
Work: the 8 hours that separates bike rides.
DNPAIMFB
Bikes: Titus El Guapo, Misfit diSSent, Cervelo Soloist Carbon, Wabi Lightning, et al.
The switch on the TrailTech lights acts as a voltage regulator so that it doesn't fry the ballast, which is built into the HID capsule itself. In cars, the ballast is pretty sophisticated, and can smooth out fluctuations in current, but the ones that are on bike-sized lights are less so.
To have a HID bike light where you could adjust the beam like you can on a Mag-lite [turning it to adjust the focus of the beam], you would want to do it with a projector/lens arrangement instead of changing the position of the reflector. That would also allow you to introduce a cut-off shield if desired.
Bikes: 2 many
Probably less.
Too late for me!
Ride the Road
Thanks to everyone. I think I'll just use my old Cygolite NiMH battery (which has an internal switch) until I get the switch back from Trail Tech.
Ride the Road
Trail Tech said the switch worked for them. So I'm back to no switch. I just ran the light directly into the battery, and it was brighter than a car headlight. I timed it, and it ran for 7 hours 20 minutes before the battery died. I used a volt meter to check it just to make sure it didn't drop below 9 volts. It was 10.7 volts before I started my ride this morning, and died en route.
I think I'm just going to get a simple $5 switch from batteryspace. Once I get it fully hooked up, I plan on trying to add a rear LED to it. This is getting addictive.
But for roughly $275 (including the mistaken $35 purchase of a Trail Tech switch). I have a 13w HID that's as bright as a car headlight and runs for more than 7 hours on a charge. I am pleased. Thanks for all of your help.
Bikes: 2 many
