Anyone here actually run quick release axles on track ends?
Old 06-27-06 | 08:19 PM
Does anyone do this? Does your wheel slip? I'd like to hear any firsthand information that anyone has.
notfred is offline
Reply
Old 06-27-06 | 08:36 PM
Yep on my mtb. It doesn't slip but I have surly tugnut on it so Its not that suprising
I know people who use one with dremeled out vertical dropouts ala sheldon brown without any problem. Really the differnce in force the qr has to withstand between mostly horizontal droupouts and trackends is pretty minimal.
If it did slip on a brakeless fixie though it would probably do so while you where skidding so you may not want to mess around with it. chain tensioners are relatively cheap and are nice for adjusting tension too.
Incidentally tracknuts are used on the track mainly because qr could be dangerous if it hooked in someones spokes and you don't need to do quick tire/wheel changes anyway.
dutret is offline
Reply
Old 06-27-06 | 08:44 PM
dlavi's Avatar
20 Anniversary
I do on my Quickbeam no problems. But it is set up as a singlespeed not a fixie
dlavi is offline
Reply
Old 06-27-06 | 08:52 PM
I ride a qr rear on a couple of ss mtb conversions, one with horizontal drops, one with vertical ones. No problems.
Sheldon says no problem at https://sheldonbrown.com/fixed.html
"Rear Wheel Installation
When your install the rear wheel, there are basically three things you need to adjust simultaneously:
* The wheel needs to be straight.
This basically means that the tire needs to be centered between the frame's chainstays. If you get it centered between the chainstays, it is properly aligned.
* The chain tension needs to be correct. (See previous section )
* The axle nuts or quick release skewer need to be tight."
mascher is offline
Reply
MrCjolsen's Avatar
Bikes: Surly Cross-Check, '85 Giant road bike (unrecogizable fixed-gear conversion
Once again, a warning that really only applies to brakeless, yet one that we all sheepishly heed.
Geared bikes used to come with horizontal dropouts. The Bianchi Volpe and the Castro Valley both still do. And they have quick releases.
So what is the issue? Obviously the quick release is strong enough to have withstanded the stresses placed on it by a road bike. Why not a fixed gear? As long as I pay attention to whether my chain is flapping in the breeze or not, and as long as my chainline is nice and straight I don't think I have much to worry about with a quick release.
If I have brakes, that is.
MrCjolsen is offline
Reply
Old 06-28-06 | 06:27 AM
SamHouston's Avatar
Good Afternoon!
Bikes: Various by application
Anyone who begins using QR on their track bike or fixie to avoid being unwittingly coercerd into using bolts by the man has my whole-hearted support.
SamHouston is offline
Reply
Old 06-28-06 | 08:04 AM
Given the fact that there is more force applied to the quick release on a geared bike with horizontal dropouts, no it won't be a problem. I'm guessing that the forces applied on a track bike are only a fraction of the ones which are applied on a geared bike. Make sure the quick realase is tight, and it is good and steel.
BostonFixed is offline
Reply
Old 06-28-06 | 08:18 AM
fixedpip's Avatar
asleep at the wheel
Bikes: Custom Richie Ditta Track Bike, Eddie Merckx Corsa, Marioni Custom Pista, Dolan Cyclocross
IMHO you're always better off converting a quick release rear to a solid axle, because:
I've ridden a QR rear on a track for training. The QR would slip and require readjustment every now and then. This is without any real abuse and I'd seriously doubt you could skip and skid on one with much confidence. This could have been just a worn out/cheap QR or paint issue but it really was no fun.
I've also broken 'cheapo' qr axles on a singlespeed before. Solid axles are just a little beefier.
Its much easier to service a non-qr wheel as you don't need to allow for axle flex (this a pretty pathetic excuse though).
But I think the perception that it could slip, would probably play tricks with your mind, thus ruining your ride as you'll just keep checking your chain tension
fixedpip is offline
Reply
Old 06-28-06 | 09:11 AM
Cynikal's Avatar
Titanium Club Membership
20 Anniversary
Bikes: Too Many
The only thing I would add is that to use a good QR like a shimano or equivilent. The good steel ones tend not to slip.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Cynikal is offline
Reply
Old 06-28-06 | 09:47 AM
spud's Avatar
i am sure that i hate you
Bikes: 'Cha-ruzu Fosuta Orusan Kein' Fuji Track (2005), Schwinn Tank MTB (?), Fuji Royale (1979)
whats the advantage of running a QR on a fixed gear?
putting the pi back in pirate!
It’s an upstanding member of the solar system
Apply the laws of earth and make it a victim
Of Proposition 187
spud is offline
Reply
Old 06-28-06 | 09:52 AM
the same as the advantage anywhere else. Its easier to remove the wheel and may be slightly lighter.
dutret is offline
Reply
Old 06-28-06 | 09:58 AM
What are the disadvantages?
Reply
Old 06-28-06 | 10:08 AM
SamHouston's Avatar
Good Afternoon!
Slightly more theft vulnerable
Can be kicked open, caught on yer shants (joke)
Relies on a multi faceted mechanical device where only threads are needed.
Isn't really faster is it>? Not for wheel adjustment & tensioning, not for me anyway, the wrench is a better handle.
Not track legal
Personally, lower profile components suit my aesthetic needs & wants better, bolts look keener for me. I use allen keys on geared bikes, that or lockable skewers, not just the work bike either. To me a road bike looks much better with allen key skewers than QR
edit- I do like the wingnut style QR from back before I was born, but only if the rest of the ride were tricked out with similar antique components
Reply
Old 06-28-06 | 10:19 AM
It's definitely faster for me with the correct dropouts: pull to release, push to tighten again compared to loosen two bolts... tignten two bolts How is tensioning any slower with a qr? you put the wheel in place and clamp it shut as compared to putting the wheel in place and holding it there until you get the drive side bolt tightened.
Either way its not really a big difference outside of race situations. I really just did it because my wrench kept falling out of my bag and this way I can just leave the wrench at home.
dutret is offline
Reply
spud's Avatar
SH sums up my thoughts
Of Proposition 187
spud is offline
Reply
Old 06-28-06 | 10:53 AM
Aeroplane's Avatar
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
I ran a QR for a while, and I think as long as it's steel and an internal cam type, it should be fine. I did break a crappy AL external cam one, and that was a long walk home.
Aeroplane is offline
Reply
Old 06-28-06 | 12:17 PM
el twe's Avatar
crotchety young dude
Bikes: IRO Angus; Casati Gold Line; Redline 925; '72 Schwinn Olympic Paramount
My friend has an old Bridgestone RB-1 (I think) that some one welded track ends on for a fixed gear trainer. It has a Surly flip-flop with a QR. Not a bad idea for that situation (training), but for shreding around on the streets, I give it a big "ehh."
Originally Posted by CardiacKid
I explained that he could never pay me enough cash for the amount of work I had put into that bike and the only way to compensate me for it was to ride the hell out of it.
IRO Angus Casati Gold Line
el twe is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
