Campagnolo Crank Crack......
Chrome Freak
Bikes: 71 Chrome Paramount P13-9, 73 Opaque Blue Paramount P15, 74 Blue Mink Raleigh Pro, 91 Waterford Paramount, Holland Titanium x2
I was cleaning my 72 Paramount, the one that has the $5 bike swap meet Campy NR crank spider. I noticed what appeared to be a crack on both sides where the crank arm blends into the spider. I know these are famous (or rather infamous) for this, and I recall reading somewhere if they are not too deep they can be filed or ground out to eliminate the stress of the tearing aluminum.
This particular crank set may be too far gone, but I have another with a miniscule crack. I think that one is still salvageable, but am definitely interested in hearing from those with more knowledge and experience than I have.
Remember, the crank pictured is the worst one. The first photo is viewed from the outside, the second from the inside.
As always, thanks in advance for your advice!
1971 Paramount P-13 Chrome
1973 Paramount P-15 Opaque Blue
1974 Raleigh Professional Blue Mink
1991 Waterford Paramount
Holland Titanium Dura Ace Group
Holland Titanium Ultegra Triple Group
ot.net slave
Bikes: Salsa mtb * 3, Intense mtb * 1, Abeni SS rd * 1, Salsa road/touring * 2, Trek Damn one * 1, Vintage/projects * many
a semi-related quasi-anecdote - there was a bulk lot of 50+ cracked strada cranks on ebay a couple of years ago. Went for next to nothing.
- Joel
- Joel
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
pretty typical for a campy crank (hope the cycling gods don't
strike me down for that), that particular area is a stress riser
and that is a well documented crack.
I believe that filing the edge so it isn't so sharp relieves it?
do a search of CR archives lots of threads about that.
marty
marty
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
Gios my baby
Bikes: Gios 96, Mercier 72, Peugeot 74 X 2, Sears full suspension High rise banana seat, Kona 94, CCM Rambler 70s.
Crap, can't correct Campy crank crack. Can complain, couldn't continue cycling creatiing crumby criterium casting creepy kunundrum thus circumventing century.
Knows Bigfoot's Momma
Bikes: yeah; got a couple...
nice lugs baby!
nice lugs baby!
Bikes: Early Cannondale tandem, '99 S&S Frezoni Audax, '65 Moulton Stowaway, '52 Claud Butler, TSR30, Brompton
If that is the worst crack, fix it. Grind out the crack, check with a crack penetrant that you are down to uncracked metal, if not, grind again. Round out that region to minimise stress raisers and ride. Done that several times (to different cranks, including a Suntour Superbe but most commonly Campag).
presto, pronto, prego!
Bikes: Dave Lloyd custom, Brands SLX, Visser Vainqueur, XACD ti custom, Hewitt Scandium, Presto 1972, and more ...
File out with a rat's tail file, until the crack is gone. in this case the crack seems too long already to do that. Filing out was also done before a crack was there, as preventive measure.
Chrome Freak
Are these post-'78 cranks?
Chrome Freak
Attempt filing it, use a find file, and sand smooth. Might try a chain saw chain file. The very late Super Record cranks changed the way material was distributed at this region. The very very early cranks machined this regional "crack zone" away.
The cranks I have seen first hand that have failed big time failed at or near the pedal hole and at the shield logo, usually with visible localized polishing from toe straps or ankles first.
interesting, I just checked a bunch of my cranks and see very small cracks on them. The pre 72's look pretty good and savable with a bit of filing. the 84s look smoothed out in that area and okay, the 77's seem to be the worst (and the shortest at 170mm) and I have yet to check the 1980 180mms.
Edit: These are all record crank sets and all different lengths so I was curious to see deiferences.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
Chrome Freak
I got a carbide grinding bit for my Dremel today. I will give that a go and polish it out then check for cracks. I don't have any dye for finding the crack, but I likely can improvise with a Sharpie and a little more polishing. I also have one of those jewelers loupe things to get a better look.
I have two other cranksets on bikes. One has very few miles on it and the other one has seen lots of miles.
I am just glad I noticed it before disaster struck.
feros ferio
strike me down for that), ...
Guest
Posts: n/a
Originally Posted by John E
I recently cracked a left Campag. Veloce crank on the shoulder of the spindle eye.
Also curious...has anybody continued riding above mentioned cracking Campy cranks?
Do they eventually fail at those cracks? Or are the cracks merely cosmetic?
Just wondering, because I have a set w/cracks (not on a bike) and had been hoping to use them eventually.
Thanks for any input in that regard. Dr. D
feros ferio
Or overtightening?
Was that due to wrong crank/spindle combination?
---- Dr. John
Chrome Freak
Well, I played around with the Dremel last night. I used a carbide grinding bit. I think I got through the crack, though it needs more cleaning and polishing than I had time for.
I did use the jewelers loupe to look at the cracks, and a that magnification they look like the Grand Canyon. So far, 4 out of my 5 Campy crank sets have the cracks to varying degrees.
Crap.
Crap.
Unique Vintage Steel
Bikes: Kirk Frameworks JKS-C, Serotta Nova, Gazelle AB-Frame, Fuji Team Issue, Surly Straggler
Looks like my 86-ish Campagnolo S.Record crank has some minor cracks as well. I'll be breaking out the dremel next week to clean them up. I tried to take some photos but being night and having to use the flash they were difficult to see in the photos. Though they don't look nearly as bad as the 70's Strada posted above.
yup, Campy cranks with cracks left and right. I'm going to take a dremel to mine, they don't look as developed as those you have there.
