Removing and reusing decals?
Old 11-28-06 | 05:25 AM
I read here somewhere that you can remove decals with acetone. Does this destroy the decal? If not, how do you store the decal until needed again, and what (glue?) do you use to apply it with? Thanks for any other tips you may have.
McDave is offline
Reply
Old 11-28-06 | 07:19 AM
Bikes: old,older.and very old
That would destory them---decals are a one use part--no resue,that's why we need people like Mike of Velography or Nick of Lloyds.
frameteam2003 is offline
Reply
Old 11-28-06 | 08:06 AM
These guys are?
Adiankur is offline
Reply
Old 11-28-06 | 08:30 AM
lotek's Avatar
Titanium Club Membership
20 Anniversary
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Originally Posted by Adiankur
These guys are?
producers of fine repop decals.
btw it's Velographics
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
lotek is offline
Reply
Old 11-28-06 | 08:42 AM
iab's Avatar
iab
Sheldon Brown Memorial - Registered
15 Anniversary
These guys are?
https://www.velographicdecals.com/
https://ourworld.compuserve.com/homep...YDS/decals.htm
and some more
www.beldecal.com
https://www.vintagetransfers.it/listbici.htm
https://stores.ebay.com/Cyclomondo
iab is offline
Reply
Old 11-28-06 | 10:34 AM
Don't use acetone anywhere near your bike, it will propably eat into the finish. True decals are not removable. But stickers, vinyl or foil will come off with the careful use of a heat-gun or hair dryer. Then can be remounted with photo-mount spray or contact cement.
Otis is offline
Reply
Old 11-28-06 | 10:55 AM
Mariner Fan's Avatar
59'er
Bikes: LeMond Maillot Jaune, Vintage Trek 520 (1985), 1976 Schwinn Voyageur 2, Miyata 1000 (1985)
What do you mean by True decals? Painted? As long as the decal wasn't clear coated it should be removable with a heat gun.
Mariner Fan is offline
Reply
Old 11-28-06 | 11:36 AM
coelcanth's Avatar
hunter, gatherer
he means the old water-slide type transfers
which are basically brittle bits of paper
coelcanth is offline
Reply
Old 11-28-06 | 02:43 PM
which are basically brittle paper bits
Yes, water-slide or those rub-on varnish over type. Where the substrate is not solid enough to remove. A "sticker" being a heavier substrate (vinyl, etc) with adhesive that will stay intact, even if the adhesive is softened or removed.
Otis is offline
Reply
Old 11-28-06 | 08:12 PM
Grand Bois's Avatar
I plan to try to remove the headbadge sticker when I have my Peugeot painted and then have the painter reapply it. It's a foil sticker and I think I can remove it by applying heat from a hair dryer. I have the new decals for the rest of the bike.
My Chevy truck was plastered with vinyl graphics at the factory. I took them off with a hair dryer as soon as I got it home.
Grand Bois is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
