My homemade front disc wheel
Old 04-26-07 | 06:27 PM
pelotonracer's Avatar
Up and comer
(cover)
Some info here: https://www.bikeforums.net/road-cycling/291845-did-personal-best-tt-double-disks.html
pelotonracer is offline
Reply
Old 04-26-07 | 06:28 PM
Raiyn's Avatar
I drink your MILKSHAKE
20 Anniversary
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
You do realize why the pros don't use full discs in the front right?
Raiyn is offline
Reply
Old 04-26-07 | 06:29 PM
tubescreamerx's Avatar
climbing
Bikes: Ridley Excalibur, Ridley Crosswind
could you provide close-up pics of the zip ties? also, is there anything to secure the edge of the disk to the rim/spokes? wouldn't it be better to have another set of zip ties near the rim?
tubescreamerx is offline
Reply
Old 04-26-07 | 06:32 PM
Up and comer
I already closed the disc, as in, I put the other side on already... I would be a pain to take it off again to show you the insides.
Oh, and I think I tied this wheel up with fishing line. I used zip ties for the rear.
Nothing is attaching the edge of the disk to the rims. Although, I was thinking I could put some plasticine around the edge to stop the wind from getting in. Or, if I wanted it to be a permanent disc, I could just use some rubber cement.
Reply
Old 04-26-07 | 06:36 PM
cedricbosch's Avatar
W.W.DZ.D?
What kind of material is that? looks like some sort of congressman poster.
cedricbosch is offline
Reply
Old 04-26-07 | 06:37 PM
Tri JP's Avatar
Dig it...
Bikes: 2005 Orbea Mitis
This design is pure genius. You're foolish for putting this on the internets, as it will be very easy for someone to steal your design and get the patent first.
Tri JP is offline
Reply
Up and comer
Exactly right. Corrugated plastic election sign.
Reply
Old 04-26-07 | 06:38 PM
W.W.DZ.D?
Yeah right, totally not safe enough.
Reply
Old 04-26-07 | 06:42 PM
Up and comer
Safety is overrated. Besides, in a TT (which is obviously the only thing I'll be using these babies for), there's no one anywhere near you if, and that's a big IF, 7 handcuff-grade zip ties manage to break.
Reply
Old 04-26-07 | 06:48 PM
Raiyn's Avatar
20 Anniversary
From Sheldon Brown:
Disc wheel
A disc wheel is a wheel with solid sides, instead of spokes. Although disc wheels are heavier than spoked wheels, they have less air resistance, and permit a cyclist to go noticeably faster. They are not usually used on the front, because they can cause severe handling problems in cross winds. They are not usually used for hilly conditions, because the added weight is too much of a disadvantage on the climbs.
The illustration is from Archibald Sharp's Bicyles and Tricycles, originally published in 1896, reprinted by the M.I.T. Press in 1977.
The front wheel has cutouts to reduce steering problems that result from crosswinds when disc wheels are used on the front.
Raiyn is offline
Reply
W.W.DZ.D?
Oh yeah, I completely agree with you, and I think your creation is the coolest thing ever. I'm all for DIY projects, but I'm just saying that trying to get a patent for a folded piece of plastic would be ridiculous.
Props to you!
By the way, how did you get the plastic into a cone shape?
Reply
Old 04-26-07 | 06:49 PM
JonnyV's Avatar
Bikes: 2012 Fuji Altamira 1.0. 2017 Lynskey R250
JonnyV is offline
Reply
Tri JP's Avatar
Dig it...
What do you mean?
Tri JP is offline
Reply
Old 04-26-07 | 06:50 PM
JonnyV's Avatar
Oh yeah, I forgot to put "I agree!" with that...so, I agree!
JonnyV is offline
Reply
Old 04-26-07 | 06:52 PM
W.W.DZ.D?
What do you mean?
I was responding to this post-
Reply
Old 04-26-07 | 06:55 PM
Up and comer
To get it in the cone shape, I just cut along a radius, folded it to the right curvature, and thencut out some extra material on a radius (think of it as cutting a slice out of a pie).
For those guys berating my use of a disc in the front, firstly, I'm a pretty big guy and I can handle the crosswinds- and also, you realize that a disc in the front saves a LOT more energy than a disc in the back, because the wind is still "pristine", right?
Reply
Old 04-26-07 | 06:58 PM
Raiyn's Avatar
20 Anniversary
Famous last words
Raiyn is offline
Reply
Old 04-26-07 | 07:10 PM
slvoid's Avatar
2-Cyl, 1/2 HP @ 90 RPM
20 Anniversary
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
Are you familiar with the term "reconstructive facial surgery"?
slvoid is offline
Reply
Old 04-26-07 | 07:38 PM
KyleKranz is offline
Reply
Old 04-26-07 | 07:43 PM
Up and comer
I don't see what the big deal is. I've used the front disc maybe 3 times now, it's perfectly safe.
Reply
Old 04-26-07 | 07:47 PM
Bikes: custom built roadie
i guess you know something the pros dont?
stea1thviper is offline
Reply
Old 04-26-07 | 07:49 PM
Namenda's Avatar
Originally Posted by KyleKranz
Damn, looks as bad as Joe Theisman. Can you say "external fixator"?
Namenda is offline
Reply
Old 04-26-07 | 07:50 PM
Raiyn's Avatar
20 Anniversary
The name of a good plastic surgeon
Raiyn is offline
Reply
Old 04-26-07 | 07:57 PM
lowracer1's Avatar
lowracer ninja master
20 Anniversary
https://www.wisil.recumbents.com/wisi...ic%20sheeting:
Actually , the recumbent guys beat you to all the methods of making disc wheels.
lowracer1 is offline
Reply
Old 04-26-07 | 08:02 PM
Tri JP's Avatar
Dig it...
Dude, Cedric. I was kidding.
Tri JP is offline
Reply
