How to build a singlespeed hipster bike!
Bikes: Nashbar CR-5
https://www.makezine.com/blog/archive...peed_bike.html
And to make it that much better, its available as a podcast...
discuss.
Close the BFSSFG. There is no longer a need.
https://blicksbags.com/
Originally Posted by shakeNbake
Lol, wut?
I've never heard anyone stealing a rear derailleur before.
I think they really were referring to periodic maintainence and the possibility of damage to a multispeed drive. I know I've bent the RD hanger on my road bike before from having it knock into stuff (without realizing). My RD almost went all the way into the spokes when I downshifted!
Originally Posted by blickblocks
People will strip everything off a bike if left locked up long enough...
Lol, wut?
All around nice guy
Bikes: THE KIND WITH TWO WHEELS AND ONE GEAR
Originally Posted by mugatu
chipping and flopping is mandatory?
news to me
news to me
Bikes: 1991 Diamondback Master TG 1990 Trek 850 Antelope
1. Frame I cant afford( preferably NJS)
2. Aerospoke front wheel
3. Let every body know I know more about bikes than they do.(or lie my a$$ off)
If you know a simpler way.....please ,enlighten me.
abides and rides
Originally Posted by Hocam
"crank spindles need to be grease free on assembly, wipe it dry or you'll split your crank"
A: Only if you're the Hulk.
B: Do that if you never want to get it off again, or want an incorrect chainline.
The guy on the left was pretty rad at the end of the vid with his knees cranking outwards and his fingers squeezing the brake though.
Originally Posted by AfterThisNap
I sure as hell have. That and tubes, single brake pads, assorted nuts and bolts, you name it.
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
Originally Posted by beard
a small part of me has died today.
SERENITY NOW!!!
Bikes: Haro Vector, IRO Rob Roy, Bianchi Veloce
I saw a frame on my block stripped of its headset cups and bb. I was impressed.
HHCMF - Take pride in your ability to amaze lesser mortals! - MikeR
We demand rigidly defined areas of doubt and uncertainty!
Dismount Run Remount etc.
Bikes: A couple customs and some beaters.
Originally Posted by dudezor
What ******** dip*****s. I recently had to angle grind a crank arm off because it hadn't been greased and was seized on the spindle.
Originally Posted by 12XU
Umm..from a mechanic to, presumably, a non-mechanic, that's quite ridiculous. Greasing the bottom bracket spindle risks scooting the crank arm further up onto the taper than it's designed to go, thus compromising the crank arm. A crank puller threaded into a crank arm should always remove the crank given the amount of pressure exerted in the process. You might have had a steel/steel crank arm/BB interface, which might've led to corrosion, but it's highly unlikely an aluminum crank arm would seize to a BB spindle.
