non-petroleum lubricant? soy wax?
Old 01-27-08 | 03:07 PM
Artful Dodger
I'm interested in eliminating non-renewable compounds from my bicycle maintenance routine. I've seen several recommendations in the forums here for the use of paraffin wax as a chain lubricant. Has any body tried soy wax or bees wax? Are there any other non-petroleum-based chain lubricants available? How about grease or light lubricant substitutes?
vincentpaul is offline
Reply
Old 01-27-08 | 05:08 PM
max-a-mill's Avatar
aspiring dirtbag commuter
https://www.ernestolube.com/
max-a-mill is offline
Reply
Old 01-27-08 | 05:16 PM
I_bRAD's Avatar
Call me The Breeze
Bikes: 2004 Litespeed Siena, 1996 Litespeed Obed, 1992 Miele (unknown model), 1982 Meile Uno LS.
It should be noted that soy wax would likely be made from GMO soybeans, packed into monoculture fields and sustained by petrochemical fertilizer. Just sayin.
I_bRAD is offline
Reply
Old 01-27-08 | 06:56 PM
Severian's Avatar
META
Bikes: Gary Fisher Aquila (retired), Specialized Allez Sport (in parts), Cannondale R500, HP Velotechnic Street Machine, Dented Blue Fixed Gear (retired), Seven Tsunami SSFG, Specialized Stumpjumper Comp Hardtail (alloy version)
+1 I_bRAD
I'd say go for a teflon based lube. Usually its teflon powder suspended in an alcohol base. Alcohol dries away leaves teflon behind. Downside is that it washes off when the chain gets wet. Upside: when in dusty conditions it doesn't get dirty as quickly.
Severian is offline
Reply
Old 01-27-08 | 07:04 PM
late's Avatar
20 Anniversary
I got some Dupont Teflon wax base spray lubricant at Lowes.
Gonna try it come Spring.
https://www.webbikeworld.com/t2/motor...chain-lube.htm
late is offline
Reply
Old 01-27-08 | 07:37 PM
Jarery's Avatar
How far do you want to go in your elimination? Since most of the non petroleum lubes come in a plastic container made from....well you know.
Jarery is offline
Reply
Old 01-27-08 | 08:05 PM
Roody's Avatar
Sophomoric Member
Lithium grease? Does that contain petroleum? Anyway it's a pretty good lube.
I've heard of people using beeswax, but I think they dissolved it in kerosene or gasoline. White Lightening is my favorite summertime lube. It's a wax, but it might contain some form of petroleum.
Did anybody ever try plain old vegetable oil? I would reccommend canola if your bike has any cholesterol problems. No trans fats!
"Think Outside the Cage"
Roody is offline
Reply
Old 01-27-08 | 10:19 PM
orange leader's Avatar
B-b-b-b-b-b-bicicle Rider
Bikes: 1997, stumpjumper S-works hardtail, Medici, Giant Perigee(track dropouts and fixed gear), Columbia twosome, schwinn twinn, '67 raleigh 5 speed internal hub, Old triumph 3 speed, old BSA 3-speed, schwinn Racer 2spd kickback, Broken raysport criteriu
Originally Posted by Severian
+1 I_bRAD
So the OP is worried about using petroleum,...... and you suggest TEFLON? it's a poison! I know 90% of america cooks on it, but it's still rated as a poison. The only reason it's allowed on cookware is because it's coated in whatever makes it stick to the pan. Teflon by itself would not stick to the pan, it would flake off.
Also, as far as the GMO soy plants go. the point of GM (genetically modified) plants is to use fewer pesticides and/or fertilizers, and still get yield. Yes, there are still unknowns with frankenfarming, but I feel they are going to outweigh the problems, like say... 6- legged frogs, or just plain dead frogs from teflon lined ponds.
orange leader is offline
Reply
Old 01-27-08 | 10:37 PM
Roody's Avatar
Sophomoric Member
I always wondered about that. Since nothing sticks to teflon, how do they get it to stick to the pan?
I was thinking that maybe the OP doesn't want to use petroleum for ecological reasons. Sorta like some people are vegetarians because raising animals is bad for the environment, not so much because it's cruel to the animals.
Roody is offline
Reply
bhchdh's Avatar
Titanium Club Membership
20 Anniversary
Bikes: '07 Trek 520, '09 Gary Fisher Triton, '04 Trek 8000, '85 Trek 500, '84 Trek 610, '85 Trek 510, '88 Trek 660, '92 Trek 930, Trek Multitrack 700
https://www.chainjisgood.com/
Pedro's canola oil based chain lube.
bhchdh is offline
Reply
Old 01-27-08 | 11:19 PM
Roody's Avatar
Sophomoric Member
Bingo!
Roody is offline
Reply
Old 01-28-08 | 01:41 AM
Severian's Avatar
META
you started it:
GMO plants have shown a high rate of cross-contamination with non GMO plants. And since GMO plants are all genetically identical the possibility of losing your whole crop to one disease is vastly increased. AND GMO seed is vastly more expensive than standard seed, which you need to use petroleum based pesticides and fertilizers on.
Teflon lined ponds?!?
Severian is offline
Reply
Old 01-28-08 | 01:56 AM
Don't forget Terminator Technology seeds.
https://en.wikipedia.org/wiki/Terminator_Technology
Cyclist0383 is offline
Reply
Old 01-28-08 | 04:44 AM
doraemonkey's Avatar
Senior Membre
20 Anniversary
Bikes: '87 Cannondale Team Comp, 98 Cannondale F900, 08 Bike Friday Tikit
you started it:
IANAG, I am not a geneticist, but I can play devils advocate (ICPDA). I not think you can really say all GM plants are genetically identical. They can be actually genetically diverse, but all share a common gene which usually codes for one or a few proteins, the rest of the gene pool is left unmodified.
The topic of GMOs is very complex and to me can't be reduced to direct gene modification vs. artificial selection. Weve been modifying the gene pool of organisms for thousands of years already. We've been making grass wheetier, wolves doggier, seeds nuttier, and cats more LOLier for ages. The real issue to me is intelectual property rights and the industrialization of these genes. Who owns you?
OK, back to the topic at hand: as many posters have mentioned, is eliminating a few drops of light oil really an effective way to ween one's self from the petrochemical industry? Already getting on a bike eliminates a good bit compared to using the car. But there are a lot of a lots of other places that we rely on petrochem. Reduction is good principle, but eliminating it all doesn't make sense.
doraemonkey is offline
Reply
Old 01-28-08 | 06:50 AM
Cyclaholic's Avatar
CRIKEY!!!!!!!
20 Anniversary
Bikes: several
are those seeds that travel back in time to kill John Connor?
(disclaimer: i am somewhat bored and have nothing constructive to add to this thread )
Cyclaholic is offline
Reply
Old 01-28-08 | 08:14 AM
genec's Avatar
genec
I suppose to really eliminate all the petro products he would have to go to wooden wheels too.
genec is offline
Reply
Old 01-28-08 | 08:35 AM
ItsJustMe's Avatar
Seņior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Uh, NO. Teflon is completely chemically inert and nontoxic. If it's BURNED at temps in excess of something like 500*F, it DEGRADES into a vapor that is poisonous. Many things degrade into poisons when burned; wood for example.
You can eat teflon all day long and not have a problem. Just don't burn it and breathe the vapors. Human effects of breathing high concentration of the vapors are short term flu-like effects. Birds are highly susceptible; they will probably die if they're in a room where it happens.
It's not COATED in anything. What's on top is teflon. The way they get it to stick is to first sandblast the metal, then coat it with a material that bonds to both teflon and metals like aluminum, then they put on the teflon. The coating underneath does not affect the toxicity (or lack thereof) of the stuff your food actually touches.
Teflon is perfectly safe if you keep it below about 500*F. IOW, don't use nonstick cookware for very high temp cooking methods, use cast iron. nonstick is great and safe when used as intended. The FDA sez that the toxicity of fumes released from the "all natural" vegetable oil used in cooking are worse than those of teflon.
My bike doesn't get up to 500*F, even when I'm sprinting
Just because something is artificial does not mean it's not sustainable. I don't know if the process involves petrochemicals or not (apart from providing energy). It's a CFC derivative; If you're going to eliminate teflon, be sure to stop wearing GoreTex; it's also a fluorene derivative.
Be sure to wear all natural fibers too; almost all technical fibers are petrochemical based.
Back on topic, I guess I'd try beeswax. Paraffin seems to work well for many people, so beeswax is probably worth a try.
Work: the 8 hours that separates bike rides.
ItsJustMe is offline
Reply
Old 01-28-08 | 08:41 AM
ItsJustMe's Avatar
Seņior Member
Here's probably the best non-petroleum-based lube you'll find: Mobil 1 synthetic motor oil (or some other synthetic). Synthetics are usually made from stuff like carbon dioxide, carbon monoxide and methane, all of which are bad greenhouse gasses or are poisonous, and they combine them into nice well-behaved hydrocarbon chains.
I am being serious here. A little research may be needed; it's possible that some manufacturers use petrochemicals as a base ingredient.
Reply
Old 01-28-08 | 09:47 AM
JeffS's Avatar
not a role model
I would agree that a high-quality synthetic oil would be petro-free (aside from the obvious packaging, powering, transportation, etc... inherent with all products) and would be much more cost-effective than the little bike bottles.
I recently switched my fixie from the Dupont spray above to some Motul gear oil I had left over from my car days - solely because it runs much quieter. The downside is it probably requires more frequent cleaning.
As mentioned though, the key is the base. Motul oils are a 100% synthetic esther base. Many of the lower-end "synthetics" (Catrol Syntec comes to mind) are nothing more than reformulated dino oils. There were some court battles over the naming at one point, but the courts ruled on a VERY broad interpretation of synthetic.
Anyway, I'm not an oil geek, although I absorbed some of the information when I was a car/track guy.
My main point would be that if you're going to use a straight oil like this, it's simply more cost-effective to use something that's not bike-specific - and it would meet your needs. I've been doing my best to avoid **** seed oil (canola) for some time now, and wouldn't feel any better about putting it on my bike.
JeffS is offline
Reply
Old 01-28-08 | 11:09 AM
Artful Dodger
I didn't realize that these products weren't derived from petroleum. I'll look into them. And thanks for yours and all the other posters thoughtful comments. I'm not anti-technology, nor am I anti-genetic engineering. I am, however, in favor of breaking our economy's dependence/addiction on a substance (petroleum) that is non-sustainable and supplied by countries I'd rather we didn't do business with. I view it as doing my part in the various wars we're involved in. It's one of the main reasons that I commute by bike, after exercise. If we have no dependence on their oil, we stop messing with them and a variety of problems go away. I'd like to support products that are produced internally as they provides job and reduce foreign dependence.
Reply
Old 01-28-08 | 12:04 PM
ItsJustMe's Avatar
Seņior Member
We're in the same mindframe then. I'm partially in it for reducing oil dependence. That's one of the reasons why I'm so irritated with the love affair with corn-based ethanol. So much oil is used in the production of the ethanol that it amounts to nothing more than a subsidy for farmers. We need other answers.
As was mentioned by myself and JeffS, SOME synthetics are dinosaur-based. Research is warranted. If someone knows, or does the research, please post back here.
Reply
Old 01-28-08 | 01:03 PM
15 Anniversary
Bikes: 2003 Giant OCR2
What the hell? Teflon isn't a poison, it's pretty much inert. See its Material Safety Data Sheet: https://ptcl.chem.ox.ac.uk/MSDS/PO/po...oethylene.html
The only hazard is from inhaling Teflon powder en masse, which if you don't work in a teflon plant while wearing no protective gear, you're not going to be doing.
I don't know where people get this stuff sometimes.
Mr. Underbridge is offline
Reply
Old 01-28-08 | 02:40 PM
littlefoot's Avatar
Bikes: Many all steel.
https://www.astroglide.com/
oops wrong forums
littlefoot is offline
Reply
Old 01-28-08 | 03:05 PM
Artful Dodger
oops wrong forums
Never know, might be dual use. Like the old Dan Akroyd and Jane Curtain skit "It's a desert topping, AND a floor wax!"
Reply
Old 01-28-08 | 03:37 PM
bigbenaugust's Avatar
always rides with luggage
Bikes: 2007 Trek SU100, 2009 Fantom CX, 2012 Fantom Cross Uno, Bakfiets
Is anyone using this stuff? Can anyone say how good/bad it is? I just this week bought a new bottle of Cross Country lube, but I could be persuaded to try plant-based lube the next time around.
... has anyone tried straight olive oil?
--Ben
2006 Trek SU100, 2009 Motobecane Fantom CX, 2011 Motobecane Fantom Cross Uno, and a Bakfiets
Previously: 2000 Trek 4500 (2000-2003), 2003 Novara Randonee (2003-2006), 2003 Giant Rainier (2003-2008), 2005 Xootr Swift (2005-2007), 2007 Nashbar 1x9 (2007-2011), 2011 Windsor Shetland (2011-2014), 2008 Citizen Folder (2015)
Non-Bike hardware: MX Linux / BunsenLabs Linux / Raspbian / Mac OS 10.6 / Android 7
bigbenaugust is offline
Reply
