For a threaded fork, how do you know what length steerer to use? And thread length?
Bikes: Too many to count
I'm getting a new fork for a threaded headset. I am ordering the fork with the steerer tube precut. How do I know what length steerer I need. And what about the threaded length? Why don't they just thread the entire length of the steerer?
Call me The Breeze
Who sells forks pre-cut? Is it used?
Anyhoo, steerer length=headtube length+ headset upper stack height+ lower stack height-2 mm
You'll need an inch or so of threads on it.
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
If you want to play it safe and get a fork that is a little longer than I brad's formula, you can always add a spacer. They are available in 1" or 1 1/8" diameters.
Been there, done that.
Roccobike BF Official Thread Terminator
Quoted: 2026 Post(s)
Liked 1,096 Times
The reason threaded forks aren't threaded all the way down is that a quill stem's expander puts a lot of pressure on the interior of the steerer tube. Threads would weaken the steerer wall and it could fail at the point the expander pushes against.
The rule is that the quill should extend down far enough so the expander is below the threaded section.
Over the hill
Quoted: 1009 Post(s)
Liked 1,231 Times
Have you done that on a threaded steerer? Considering the headset races go into the head tube and the to nut screws onto that but can't bottom out on the steerer, I don't see how that would work.
Call me The Breeze
Not true though. I got one just the other day- 10" steerer, 7" of threads. Cut to fit. It's a low end fork, but just an example.
Quoted: 443 Post(s)
Liked 28 Times
Any threaded fork would come precut, because only the top inch is threaded so if you have to cut 1" off, it's not threaded anymore. You're correct on the formula, though.
The spacer goes under the top nut. I've seen 20mm of spacers used. It's a way to get the bars higher without using an extra tall quill stem. You could probably find an example on the Rivendell site. Velo Orange sells a 10mm spacer that's drilled and tapped for a bell.
Over the hill
Liked 1,231 Times
The extra long threaded part scares me, as that means you're putting the quill expander on the threaded part in most applications. I suppose such forks are made with thicker walls to compensate for that?
OK, I agree with everything you're saying about the threads and expander. But I'm trying to visualize the situation you described with 20mm of spacers and a standard quill stem. It seems like you'd be pretty close to having the expander in the thread zone.
Quoted: 443 Post(s)
Liked 28 Times
I mentioned looking on the Rivendell site for examples of headsets with spacers. I don't even know if those pictures are still there, but if you look at the quill stems they sell, you'll see why they have no trouble reaching the non-threaded part of the steerer.
Over the hill
Liked 1,231 Times
Then why would you need the spacers instead of just setting the stem higher? And how do you not put the expander in the threaded section of those forks with 7" of threading as mentioned by I_brad?
Quoted: 443 Post(s)
Liked 28 Times
I don't think I've ever seen a fork with 7" of threading. The replacement forks I've been looking at for an old Raleigh Competition have 50mm of threading. They'll work for a range of frame sizes. I didn't say they'd work for all sizes. I did see one with 100mm of threads, but that seems excessive.
If you look at the bikes on the Rivendell site, you'll see that most of them have headset spacers.
