Falcon Ernie Clements
Falcon is a British company who swallowed up British Eagle, Coventry Eagle, Elswick Hopper, Claude Butler and Holdsworth and lastly Dawes. Ernie Clements was their designer and his name was used on some of their mid to upper end models. Barry Hobans name was also used on some of their bikes. Judging by the braze on's that looks like an early 1980's to late 1980's frame. Possibly 1985 on judging by the paint job.The quality dropouts suggest a quality steel frame probably built out of one of the Reynolds tubesets. It looks like its had some newer non original parts fitted, saddle, shifter and rear mech. The chainset looks like a lower end double with the inner ring removed. I would tentatively guess that it was converted to a fixed or single speed bike before being coverted back to geared. It looks like this last conversion was done on the cheap as the mech and shifter are lowend bits. In addition the shifter is an mtb item and its placed in an unusual place, definately not done at the factory. Can you give us the frame number and details of any decals/stickers that may be on the bike, this would aid the more experienced members of the forum.
i agree with all that Trefor says, looks '80s to me. I never saw an Ernie Clements that was not a Falcon, that's the first I've seen under his own name and from this era. The rear spacing would also confirm that this is an '80s vintage (126mm for a 6-speed rear cluster?) and the seat post diameter (27.2mm?) might help determine if it's 531 Reynolds. Seems like it deserves some better components...
It appears to have a Falcon headbadge; is that correct? It's unusual that a frame doesn't get the components it deserves, I think. Don't seem to be any tubing decals. Ernie Clements may well have retired by the time this bike was made -- wasn't he a rider in the late 40s?
Bikes: Rocky Mountain MTB, Orange P7 Single Speed Commuting , Ernie Clements Roadbike
I attach some more pics of the frame & badge. Not sure if it's easy to see from the pics, but the fork-shoulders are distinctively sloped. Does this give a clue about age/model?
Also, the brake callipers are Weinmann 500's and the casting stamp date them being made in 1979. Can't be sure if the brakes were on the original bike though!
The frame appears to have been re-sprayed. I say this because the Falcon badge is glued onto the frame and not rivetted. I got this bike off a chap I worked with in the late 1980's. He had owned it for a while and I picked it up for a song (£15). This is what makes me think the frame must be much older than the '80's. My gut feeling, combined with advice from other forums, suggests it is a 1970's frame, but i'd really like someone to nail the date from the engineering.
I haven't found a frame number, but it is possible it is under the re-sprayed paint.
Some additional info...Weinnmann Type 500 brakes (circa 1979 off date stamp), Sachs Huret Derailleaur, cogs and chainset also Sachs, as is handlebar mounted shifter. Wheels are Mavic MA2 rims with Maillard 700 Hubs. Bottom Bracket is by Baylis Willey.
Also, the rear seat-stays have a nicely crafted concave bit at the end where it meets the seatpost. Here's a better pic of what I mean...
well assuming it's repainted there are a few non-paint clues: the shorter rear dropouts are late '70s at the earliest, the brakes are external-nutted; there doesn't seem to be any brazed-on shifter bosses (any remnants?); one pair of water bottle bosses I can see; the lugs are long pointed and have window cut-outs; under BB cable routing and top-tube cable tunnels. All pretty consistent with a frame from the late "70s to early '80s. That's my best guesswork
Ernie Clements - Owner name
The guy I bought the bike off in the late 80's was a chap called David Turnbull. I don't know if he was the original purchaser of the bike or not? If you can tell me anymore about my bike I would appeciate it? Cheers, Bob
The Legitimiser
Bikes: Gazelle Trim Trophy, EG Bates Track Bike, HR Bates Cantiflex bike, Nigel Dean fixed gear conversion, Raleigh Royal, Falcon Westminster.
Ernie Clements had his own shop in the 50's, before he joined Falcon, and built some lovely bikes then. There were also Clements branded bikes built outside of Falcon, in the late 70's/early 80's, and the CR list guys have produced varying vague opinions about who built them (I had one, so I was interested). The most likely idea seems to be another member of the Clements family.
This, however, is not either of those things.
1976 Falcon - Ernie Clements
I find this post interesting, as I myself still have a Falcon that is vintage 1976 with all original components on it... Weineman brakes, Shimano crank and derailleur (Titleist), and sew up tires... I'm wondering what the value might be? Any one want to hazard a guess?
Falcon Chaser
Bikes: Raleigh, Trek, Schwinn, Falcon, Specialized
edinmpls,
Have a pic? Or know the model. We can better help you determine price.
Does it have the GB stem and bars, Weinmann center-pull brakes, wrap around stay, semi-slope forks, foil or tri set Falcon Special decals? A 76 should have the metal badge.
There is mid 70's for sale on Mnpl Craigs.
Falcon - Ric
"Respect your Fellow Collector"
Falcon - Ric
Here is an article I wrote on Falcon bicycles that have come my way over the years.
Vintage Falcon Road Bicycles.
Hope this is a help.
Details of the Falcon
Thanks for the input guys... as for decals, there are very little markings on the bike, and this is how it came new. The forks are clean, as is the rest of the frame. The front plate appears to be metal and is in great shape. I'm at a loss to give this bike an appraisal... any help would be appreciated, thanks...
Ernie Clements Frame
Sorry to resurrect an old post but I've just bought a very similar Ernie Clements frame. I was searching for info and this popped up. Mine has the same lugs and decals. It has Reynolds 531 main tubes and forks. The Reynolds decals date it to 1982-89 but there isn't any frame number other identifying clues.
I had assumed it was a generic Taiwan frame but I'm wondering if it was made in Wales. Unfortunately my frames paint is beyond saving so it's at the powder coaters so I'll lose the decals.
I'm hoping someone on here can give me any more information. I can't post a pic of it yet because I've only just joined.
karmantra
Classic & Vintage
25
03-26-22 01:10 PM
Jantaras
15
03-03-17 10:48 AM
rodertmiller
9
05-28-14 06:27 PM
Jack_razzak
2
09-15-13 09:27 AM
