Which tires are these? Pic
ride
Bikes: iro / bianchi / soma
Anyone know which tires these are?
I like the red/colored sidewalls.
Larger version available at https://velospace.org/node/585
Thanx
Thanx
Bikes: Pake track, Soma DoubleCross, LeMond Etape, Maruishi RoadAce 303
I think they are Specialized Armadillo tires, judging by the logo. They are pretty similar to Conti Gatorskins, which I like better.
I believe they are Armadillos. Good puncture protection, not the lightest or supplest tire you'll find.
Nor is it good for skidding, if you're into that sort of thing. It has a fairly soft rubber compound over a hard plastic liner. If you lock up your wheel, it'll rub that soft rubber right off .
Gone Tarcking. Back Later
Bikes: Iron Horse Warrior Team (tricked to high heaven), Jamis Coda Sport (frame and fork, built into CX commuter), Gary Fisher Opie Dirt Jumper,SE Lager tarck bike
But you can safely run them flat in emergencies.
Bikes: 2005 Specialized Langster, 2005 Giant TCR C3, 2006 Bianchi Castro Valley, 2007 Redline Monocog 29er, 2007 Trek 5000
I always felt that they wore down a little too quickly and gave a wooden feeling when the pressure was too high. I usually ride with about 100 psi in my tires but I kept the Armadillos at about 90 psi or so.
Bikes: nagasawa, fuji track pro
Bikes: Raleigh 29er, IRO Angus frameset- random components, Giant Bowery, Raleigh Rush Hour frameset-future build
My name is triplesixer, and I approve this message:
I like that Fuji Track Pro (minus NYC sticker)
without hed3 and da7600 36h laced radially to nmsw deep v (same as rear wheel)
it was about ______ complete. (white san marco saddle instead of turbo)
this bike was the budget build compared to the nagasawa
brand new FTP frameset - 420
brand new sug 75 bb - 70
used sug75 cranks + 49t sug75 ring - 150
brand new hkk chain - 30$
deep V + da7600 36h wheelset + eai 17t cog +lockring - $400
gr-9s + toshis + mks clips = 100
new miche supertype - 60
used white san marco saddle - 60
new b201aa black - 30
somewhere around 1300?
ride
That bike is georgous. I'm in love.... Is IRO a good brand? I'm just getting into fixed gears and I'm so overwhelmed by all the different manufactures! I've tried checkign out the stickies but they're still so overwhelming.
ride
Edit: I also would like to suggest to you that you use the Search function of the forums, as pretty much everything has been discussed at one point or another and the archives are an invaluable resource. It helps to narrow your search down to the Singlespeed and Fixed Gear subforum.
Last edited by alheim; 10-15-08 at 10:50 PM. Reason: mandatory mention of the search feature
