NEW chain noise problem
the barbarian
Bikes: Independent Fabrications Crown Jewel, Surly Steamroller(FG), Abici Podium (road)
I just put a KMC K710SL chain on my 06 Bianchi Pista. I have read other posts that there is some noise, but mine is ridiculous!! when I accellerate, the chain does not appear to engage on the cog very well (kinda looks as though it is snapping into place).
It is a 1/8 chain and apparently the pista has a 3/32 drivetrain, but I wouldnt think this would matter all that much. I lubed the hell out of the chain with white lightning but to no avail? With the old z410 chain there was no noise, now it is really crappy sounding
What the hell is wrong!
if you didn't replace your chainring and cog at the same time the noise is due in part to wear on those components and no wear on your chain causing them to not mate perfectly. this will improve with time but the general rule of thumb is to replace your drivetrain as a whole at the same time.
It is also very likely that you left the old chain on too long and now your cog is worn. The new chain doesn't mesh with the worn cog..hence the noise. You need to get a new cog and replace your chain more regularly.
out of shape
710s are going to be louder than the 410s you replaced... not sure why it happens but i've seen that happen firsthand on a few occasions. could be the plate design, or less flex, or something.
either way, check your chainline, inspect your drivetrain for wear, and if it's really a problem, get a different chain (possibly in 3/32).
Live without dead time
It sounds like in this case the drivetrain might be pooched though
Every couple months. Usually when it feels as though my wheel is alot further back in the dropout than I remember it being, I replace it. Like I said, it's just 15 bucks but it'll save you from having to replace your cog and chainring as often
https://www.nashbar.com/profile.cfm?c...in%2FFreewheel
With proper chain maintenence, a freewheel or track cog should last through several chains...maybe 5 or 6 chains..I always loose track before I wear out the cog.
the barbarian
Wonderful new development, I was riding down the street, still with bad noise but hoping it would go away. Well, it got worse, the masterlink on my chain flew off and the the chain fell off! WTF~!!!! i guess i need to replace my cog and get a new masterlink?
another chain question:
removing a link from an average 3/32 chain typically causes the rear axle to move forward how far in the track end? (or is that impossible to answer without knowing the bike's geometry all around?)
Adding or shortening a chain by 1 link will move the axle 1/2". Changing the tooth count on either gear will move the axle 1/4"
Not exactly. The difference of one tooth on either your cog or ring will move the axle 1/8". For example, subtracting a cog tooth decreases the circumference of the cog by 1/2 inch. The chain only goes half way around so the chain has 1/4" less contact with the cog. That gives you 1/4" of slack. Divide that in half again to account for the upper and lower parts of the chain and you have 1/8".
ride
Bikes: iro / bianchi / soma
The length from center of one roller to the center of the next is 1/2". When you remove a link, you have to remove "two links" - a set of inner and outer plates (unless you cheat with a half link) - which removes 1" from your chain. That translates into 1/2" from both the top and bottom of the chain (between the chainring and cog), moving your axle 1/2".
Edit: I just realized that bidaci was also talking about removing a tooth. And your reasoning on that matter seems sound. Amen.
n00b
Bikes: nice Raleigh roadbike and an S&M BMX
For reference I tend to change my chain every three to five months depending. I have access to a chain checker which makes life easy, but yeah I'm a little anal about my chain.
the barbarian
well, problem solved!!!!
i decided to put a 1/8 cog on rather than a 3 3/32 chain (the k710sl is just too sweet!) and man oh man is my drivetrain smoooooooooth!!
(though i was disappointed R&A cycles would not exchange my chain, they just wanted to charge me $25 for a z410! Dixon's gave me the cog for $10!)
the switch definitly made a change for the better!
lessons I learned:
1) a 3/32 cog will NOT work with a 1/8 chain. do not even try
2) rear cogs are very very difficult to get off! (i had to put it in a vise and turn the wheel, and even then it was tough)
thanks for all your help!
lessons I learned:
ride
nice work, but, you just got a new cog as per everyone's recommendations, and replacing the old, worn cog is probably what made all the difference. you most definitely can run a 1/8" chain on 3/32" cogs/chainrings. after all, you probably still have a 3/32" chainring on up front, right?
You apparently didn't learn much. Your problem is solved because you swapped out your worn cog. A 3/32 cog will work with a 1/8" chain on a singlespeed drive train. Anybody who tells you different is misdiagnosing the problem.
