How do I Fit a Nitto tech stem in a Kilo
Old 05-20-09 | 10:31 AM
I got a Nitto stem and want to put it on my kilo tt. But I notice that its a threadless headset and the Nitto is quilled. Is there a way to get the stem to fit on the kilo.
Please help.
Blindguy is offline
Reply
Old 05-20-09 | 10:35 AM
Cynikal's Avatar
Titanium Club Membership
20 Anniversary
Bikes: Too Many
This should be fun. Excuse me while I grab some popcorn and a seat.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Cynikal is offline
Reply
Old 05-20-09 | 10:36 AM
happytruck's Avatar
hey
15 Anniversary
i think your best bet is to go threadless
edit: ie. bite the bullet and buy a threadless stem. or you could buy a new fork/headset. or maybe thread the fork you got
happytruck is offline
Reply
Old 05-20-09 | 10:42 AM
howl's Avatar
you must thread that fork. go to lbs.
howl is offline
Reply
Old 05-20-09 | 10:45 AM
thanks guys
Blindguy is offline
Reply
Cynikal's Avatar
20 Anniversary
Bikes: Too Many
^good luck with that.
OP you will need a new fork and headset. Basically, you will spend a bunch of money on outdated technology to achieve your aesthetic. It's up to you to decide if it's worth it.
Cynikal is offline
Reply
Old 05-20-09 | 10:46 AM
monster
Fork needs to be cut down to correct size and threaded. You will also need a threaded headset.
Off to the LBS you go.
monsterkidz is offline
Reply
Old 05-20-09 | 10:47 AM
howl's Avatar
why would he need a new fork?
howl is offline
Reply
Old 05-20-09 | 10:52 AM
Cynikal's Avatar
20 Anniversary
Bikes: Too Many
Ask the LBS who won't thread a threadless fork. The dies to cut a fork from scratch are different than the ones most shops have (Park) which are more meant to chase threads. They will probably charge more than you think. Like $10-$20 per inch. This is all assuming that the fork and headset are 1 inch and not 1 1/8th.
Cynikal is offline
Reply
Old 05-20-09 | 10:54 AM
jpdesjar
Guest
Posts: n/a
i would say go threadless unless you really want the quill
it sounds like it can be done but it may cost more and be a hassle
Reply
Old 05-20-09 | 10:55 AM
happytruck's Avatar
hey
15 Anniversary
threaded components are rare for 1.125 forks, if that's the case.
so i think
edit:
...This is all assuming that the fork and headset are 1 inch and not 1 1/8th.
this
Reply
Old 05-20-09 | 11:01 AM
exhibitx's Avatar
Balls
kilo has a 1" fork.
exhibitx is offline
Reply
Old 05-20-09 | 11:05 AM
happytruck's Avatar
hey
15 Anniversary
Originally Posted by exhibitx
kilo has a 1" fork.
o yea i missed that
...and i own one of the new-gen, threadless ones hah
Reply
Old 05-20-09 | 11:10 AM
radiocontrolhea's Avatar
OP should have searched.
The fork can be tapped to have threads so that a quill stem can be installed. You will need a 1inch fork(kilo has this) and a threaded headset.(kilo does not have this)
radiocontrolhea is offline
Reply
Old 05-20-09 | 10:49 PM
ok so i called my lbs and they asked me if i wanted to thread it 1" or 2". Which should i do? and what size threaded headset will i need?
Thank you all for the help thus far
Blindguy is offline
Reply
Old 05-20-09 | 11:06 PM
Cy Trivialities's Avatar
shtface
u should return that stem.
Cy Trivialities is offline
Reply
jet sanchEz's Avatar
20 Anniversary
You have the bike all set up for riding? You should really ask yourself if all this hassle is going to be worth it. At the end of the day, if you do choose to get your fork threaded, you will have to get a threaded headset too.
Threading a fork: $35 or so
Headset: $25 or so
Installing a headset: $15 or so
Initial cost of Nitto Tech stem: $30 or so
You are in the neighbourhood of $100----that is a nice new seat and some good rubber for your bike.
Why do you want to do this? What is wrong with your current setup?
jet sanchEz is offline
Reply
Old 05-20-09 | 11:51 PM
Reason i want to do this is that i like the look of it and i'm tired of the way it looks. there is nothing wrong with the set up i got now, just want a little change.
How difficult is it to install a threaded headset? i was planning on do that with a friend since my friend works at a bike shop.
Blindguy is offline
Reply
Old 05-20-09 | 11:54 PM
Jabba Degrassi's Avatar
FNG
Bikes: 2008 IRO Angus, 2008 Jamis Exile 29er
If you insist on going through with this, MAKE SURE your mechanic checks the steerer tube to ensure it is THICK enough to be threaded safely. Otherwise you risk CATASTROPHIC FAILURE.
It is almost certainly not worth the risk. Just get a nice threadless stem...
Jabba Degrassi is offline
Reply
Old 05-21-09 | 12:52 AM
20 Anniversary
not disagreeing with you here, but doesn't the BI kilo frameset come with a fork that has a super long steerer that is partially threaded up top so you can go either way? i assume it could be the same fork, thus, safe for threading.
tFUnK is offline
Reply
Old 05-21-09 | 12:58 AM
FNG
I'm not too sure, but wouldn't having threading up that high be pretty much useless based on how threaded forks are fitted to a frame? See: https://www.parktool.com/repair/readhowto.asp?id=115
Reply
Old 05-21-09 | 01:46 AM
carleton's Avatar
Elitist
Don't throw good money after bad.
Make a change by investing in:
- Clipless pedals
- Good clipless shoes
- Good tires
- Saving for a non-entry level bike
Man, you will be totally amazed when you ride a mid-level bike. Your head will asplode when you ride a high-end bike.
I know it's tempting to tinker. We all do it. But, don't devolve your bike by adding a quill stem.
All signs point to this being a bad idea. If you still do it, there is no helping you.
carleton is offline
Reply
Old 05-21-09 | 02:31 AM
cc700's Avatar
Ths Hipstr Kills Masheenz
Bikes: tirove
lollerskates
i went threadless simply to avoid rethreading the fork.
now i'm thinking of going threadless on my mtb.
threadless = better
cc700 is offline
Reply
Old 05-21-09 | 02:43 AM
UCP
Why is threadless better exactly?
I'm not saying it isn't, I just haven't seen an explanation. Perhaps a quick summary please?
Just be happy you don't have this stupid thick 70's schwinn steerer tub that is too THICK to fit a standard quill.... F-ing Schwinn. I need a new frameset... for several reasons.
UCP is offline
Reply
Old 05-21-09 | 03:05 AM
cc700's Avatar
Bikes: tirove
it's lighter, more easily adjustable, and stronger for its weight. it's more easily serviceable and lends itself to reliable, longer lasting bearing designs.
cc700 is offline
Reply
