I am new: stupid question
Old 06-07-09 | 10:06 AM
Hey guys,
I am new here and I have a very stupid question. I recently upgraded to a clipless pedal (Shimano). Luckily for me, I have no problem with using the clipless pedal. I can unlock them very easily.
My only problem is mounting the pedal. The pedal keep on spinning and is often upside down thus making it very difficult to clip on. Sometime I have to spin the pedal with the tip of my shoe to get the pedal up right before I can clip my shoes on.
Stpuid question: Is it smart to use loctite from prevent my pedal from floating/spinning? If using loctite is a stupid idea, is there any other method to limit my pedal from spinning completely upside down?
Thanks
Aspire is offline
Reply
Old 06-07-09 | 10:09 AM
^oZ's Avatar
^oZ
shut up legs
^oZ is offline
Reply
Old 06-07-09 | 10:11 AM
wow....what a great way to start a relationship. I hope the rest of the community is not as rude as you. I rather you not saying anything then to make immature remarks
Aspire is offline
Reply
Bikes: Windsor Fens w/ Shimano 105 group
Let me get this straight....you don't wait the pedal to spin?
KCWolfPck is offline
Reply
Old 06-07-09 | 10:12 AM
Mr.jon's Avatar
Bikes: Motobecane Messenger
Obvious troll.
Mr.jon is offline
Reply
Old 06-07-09 | 10:13 AM
halfspeed's Avatar
20 Anniversary
Bikes: are better than yours.
Originally Posted by Aspire
Hey guys,
Thanks
No. You just have to get used to flipping it with your shoe or go with a two-sided pedal.
Telemachus has, indeed, sneezed.
halfspeed is offline
Reply
Old 06-07-09 | 10:15 AM
I am not talking about the crank. Of course I want the gear to spin. I am talking about the free floating movement of my pedal. I dont want to to spin completely. I want to limit its spin so that it doesnt go upside completing. I want to spin only 90 degree in each direction (front and back) but not 180 or 360.
Aspire is offline
Reply
Old 06-07-09 | 10:16 AM
So, how do you intend on turning the crank 360 degrees if the pedal can't spin 360 degrees?
Reply
Old 06-07-09 | 10:17 AM
thanks for the post.
.that is what I been doing but I figured that there should be a more effecient method. I guess I just have to practice and practice.
btw...is my idea really stupid or does it make sense?
Aspire is offline
Reply
Old 06-07-09 | 10:18 AM
Mr.jon's Avatar
Just think about how your bike works for 10 seconds. Go ahead and locktite the heck out of it and tell us how it goes, be the first...
Mr.jon is offline
Reply
Old 06-07-09 | 10:19 AM
Really stupid. To do as you proposed would negate the use of clipless pedals. You would have to lift your foot off the pedal through the bottom half of each rotation....unless you plan on pedaling from both the top and bottom of your bike.
Reply
hendrick81's Avatar
Bikes: 2006 caad8, 2010 caad9 1, 2011 caad10 4
Just go sit in the corner already............
hendrick81 is offline
Reply
Old 06-07-09 | 10:21 AM
Flatballer's Avatar
No matches
Bikes: two wheeled ones
Well, he'd have to loctite the bearings, not the pedal threads. To do this would require much more mechanical knowledge than he apparently possesses, therefore, I don't think we're going to get to watch him purposely seize the bearings in his pedal spindle.
It's unfortunate, I know.
Flatballer is offline
Reply
Old 06-07-09 | 10:23 AM
halfspeed's Avatar
20 Anniversary
The pedal rotates completely around its axis on each revolution of the crank. It's for this reason that two-sided pedal systems (see Speedplay for road-specific) have been introduced.
Reply
Jynx's Avatar
Bikes: 2006 Cannondale CAAD8
if the pedal wasnt allowed to rotate you could not pedal 360* around
Weight Listing Index (Feel Free to add to it!)
Buy your bike parts here
Jynx is offline
Reply
Old 06-07-09 | 10:26 AM
kidonabike's Avatar
Hello :D
there are one-sided, two-sided and 4-sided pedals. If you don't want to have to spin the pedals around to clip in all the time you might want to look for a two/four sided system.
kidonabike is offline
Reply
Old 06-07-09 | 10:28 AM
<--------- laughing at pictures in my head of this guy trying this and getting thrown over his handlebars on the first push off to try and avoid breaking his ankles.
Reply
Old 06-07-09 | 10:33 AM
vja4Him's Avatar
GadgetJim57
Bikes: Yuba Sweet Curry eBike, Surly Long Haul Trucker
I'm not a wiz at Math, but spinning 90 degrees in each direction equals 180 degrees! That would be 90 plus 90, which equals 180 ....
I don't use clipless, so I don't have to worry about this problem. But I do remember many years ago, when riding other people's bikes that had the toe straps ... I never did like those ....
vja4Him is offline
Reply
Old 06-07-09 | 10:36 AM
roadiejorge's Avatar
stole your bike
Titanium Club Membership
15 Anniversary
Bikes: Orbea Orca, Ridley Compact
Hey guys,
Thanks
In terms of bicycle mechanics yes it would be highly advisable to NOT under any circumstances use loctite to keep your pedal from spinning, I cannot repeat that enough. What you need to do is get used to flipping the pedal up then clicking in, once you do it won't be hard at all as you'll know exactly how to do it quickly. If you can't however adapt to this or don't like a pedal with only one engagement point then check out pedals like Speedplays or Crank Brothers' Eggbeaters which offer more engagement points.
I like pie
roadiejorge is offline
Reply
I think his confusion comes from the fact that the pedal stays upright throughout the stroke. If you don't think about what's happening, it seems the pedal is stationary. You have to realize that the crank arm is rotating and the pedal must be able to rotate separately to stay upright.
chadteck is offline
Reply
Old 06-07-09 | 10:47 AM
banerjek's Avatar
Portland Fred
Bikes: Custom Winter, Challenge Seiran SL, Fuji Team Pro, Cattrike Road/Velokit, РOS hybrid
Hey Aspire,
Don't be dissuaded. If you stick around on BF, you will learn that practically every idea expressed here is stupid.
But in response to your original question, there is a reason why none out of the millions of cyclists try to make their pedals seize. Just ride more and get familiar with your equipment.
banerjek is offline
Reply
Old 06-07-09 | 10:49 AM
BarracksSi's Avatar
Bike ≠ Car ≠ Ped.
15 Anniversary
Bikes: Some bikes. Hell, they're all the same, ain't they?
Sorry, but yeah, it's dumb. Two things I would consider would be to get a two- or four-sided pedal (the only 4-sided pedals I know of offhand are Crank Brothers Eggbeaters) or to add a weight to the underside of the pedals you have now.
Adding a weight won't always work, though, because the bearings on the pedal spindle might not necessarily move freely enough to allow a small weight to maintain a pedal's orientation. You'd have to use a weight that's heavy enough and/or make sure the bearings can spin very freely and easily.
Since you haven't said what kind of clipless pedals you've got, remember that road-specific pedals like those from Look or Shimano's SPD-SL line (Dura-Ace, Ultegra, 105, etc) are only one-sided.
(wondering if high schools even have shop class anymore..)
BarracksSi is offline
Reply
Old 06-07-09 | 10:50 AM
hendrick81's Avatar
Hey Aspire, need one of these.
Reply
Old 06-07-09 | 10:55 AM
VA_Esquire's Avatar
Would be funnier if he loctites his pedals and it was a fixed gear.....
VA_Esquire is offline
Reply
Old 06-07-09 | 10:58 AM
mr handy's Avatar
Living Notoriously Well
Bikes: 06 Felt F80
Your cranks go 360*... in order for the top of your pedal to face the sky all the time, the pedal must also be able to rotate 360*
Keep riding with the pedals, it will become second nature to kick and clip. You won't even have to think about it, it will just happen.
mr handy is offline
Reply
