Toe Clip/Strap Recommendations?
I have a CAAD9 and I'm looking to upgrade from the platform pedals to toe clip or strap pedals. Does anyone have recommendations on the best ones I can get for close to $20 price-wise? And is 9/16" the standard thread diameter?
I'd like to stay away from having to get clip-in pedals and shoes, because I want to be able to get off the bike and walk around. Thanks in advance!
MKS has a couple options for pedals, and toe clips, toe straps you are about 30 years too late for better ones...
but you can still find some leather ones..
Mostly the nylon webbing is the ones out there.. I stiffen them up with Plastidip, the tool handle stuff.
to be all weather.. EZ care..
Quoted: 6556 Post(s)
Liked 58 Times
My advice is to just look on Nashbar for their right-priced pedal offering making sure that there are toe clip mounting threaded holes on the front of the pedals.
Here is a good example: Nashbar Scratch Pedals
And 25% off the price today. The holes aren't threaded but you can attach the toe clips with nuts and bolts instead of just machine screws.
Bikes: 2022 Ribble Endurance Disc Sport 2018 Trek Emonda Al4, 2012 Motobecane Heat Ti,
Quoted: 19 Post(s)
Liked 222 Times
Clipless pedals are the way to go. As well you can get mountain bike shoes that have a recessed cleat for walking around.
If you definitely don't want clipless there are pedals that have pins or grips that grip your shoes like these: https://jet.com/product/detail/0b0c6...f-0f2c8fffe16e
Have you considered MTB clipless, like SPD? They use a small cleat that can be positioned recessed in a walking sole. I've worn my SPD shoes all day at work before and it was just fine.
just another gosling
Quoted: 3901 Post(s)
Liked 1,953 Times
I did this for years as a young man. Sneakers and toe clips. If you always use the same sneakers, the rat-trap pedals will wear grooves in the sole, plus the soles are soft enough even before that happens so that it's almost impossible to pull the shoe out. I always buckled the left shoe in, but only pulled up on the strap for the right shoe so I could get out quickly. That said, for sure clipless is safer but I do understand the OP's desire.
You want a pair of rat traps with strap slots in the inner and outer plates, similar to these:
It's odd how few have proper slots now. The straps have to be leather.
Results matter
Results matter
Lots of old quill pedals are still out there in great shape, though.
Farmer tan
It's the only shoe I took on vacation. Walked through the airport, walked around volcanoes, walked in restaurants.
No problem. Giro makes a pair for $70.
Liked 1,953 Times
Classic quill pedals had that shape to mesh with slotted cleats. Since high-performance applications have basically totally moved to clipness, there's near-zero demand for cleats with toe clips. Since there's no cleats, there's no reason to design the pedals to mesh with them.
MTB shoes would have been weird. Not what I'd want to wear if I were on my feet all day, every day.
Downside of that setup is that one's tennis-shoed feet get tired of the straps after a century of so. And they're really cold in winter and rain, partly because the straps cut the circulation off a little, partly because the metal just sucks the heat out of one's feet. There is some small performance loss with flexy shoes, but hey folks, it's very small compared to plain flats.
Results matter
Results matter
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
For a few years now, I've used plastic BMX pedals with Pure Fix foot straps on my fixed gear road bike. Pros: cheap, reasonably durable (I get 4-5K miles out of a pair of pedals, longer out of the straps, even with a lot of mashing), does little damage to shoes. Cons: less foot retention than rat traps or clipless; more difficult, IMO, to get into than clipless.
Once you go clipless, you'll never look back. I'm strongly considering putting clipless pedals on my fixed gear the next time I take it on a road ride.
Quoted: 130 Post(s)
Liked 24 Times
I used to have these on my commuter, very comfy and easy in and out. https://www.rei.com/product/788129/p...port-pedal-kit
pan y agua
Quoted: 1456 Post(s)
Liked 733 Times
The two standards are 9/16th, and 15mm.
9/16th is typical on beach cruisers, etc.
Almost all road bikes, including your CAAD 9 use 15mm pedals.
You could get lost and die.
You could hit a tree and die.
