removing laser etching
Listen to me
Oh, you want to remove the logo AND still have a pretty HS.....
In that case my friend you have a couple options.
1. Live with it.
2. Remove logo abrasively then use alodine to protect the now exposed Al.
3. Send the part out to have the anodize removed and re-anodized. The Acid treatment used to remove the anodize will most likely also remove the logo.
Enjoy
1. Live with it.
Enjoy
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
Black Sharpie, $1.09, CVS.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Older CK headsets did not have that etching; perhaps you can find a decent one used or NOS on ebay.
Aluminum is not easy to polish well. I guarantee if you start messing with the finish you will not be happy with the results.
Today, I believe my jurisdiction ends here...
Cycle Dallas
Bikes: Dulcinea--2017 Kona Rove & a few others
Quoted: 197 Post(s)
Liked 10 Times
If you go the sanding, refinishing route, just a few points:
1. You will have to paint the piece, since as mentioned, polishing aluminum is rather difficult.
2. Sand the entire piece. You won't be able to match the original finish on the area you sand.
3. Use three thin coats of primer; one coat of self-etching primer and two coats of regular primer.
4. Paint it with two thin coats of spray paint. If you lay on enough that it drips, you'll be disappointed with the results.
Good luck.
Good luck.
Quoted: 443 Post(s)
Liked 27 Times
I chuck mine in a drill press. You have to apply quite a bit of pressure on the wheel. I start with 220 grit emery paper and work up to 600. Rouge will remove the scratches from the 600 grit. You can use a pad sander on some parts. I can make a black seatpost look like chrome in about 20 minutes (I polish only the part that shows). It may take you a little longer. I've had some practice. I polished my first set of valve covers in the '60s (312 T-Bird).
I dislike logos, so I strip and polish a lot of parts. Bare aluminum dulls quickly, especially if you touch it, so you have to polish it often. I use Mother's, but I'm sure there are lots of other good products.
Aluminum bike parts don't need a protective coating, it just makes them easier to live with. All of the aluminum parts on my '70s French bikes are bare and they still look like new, at least right after I polish them.
Bikes: Cinelli Unica, BP Stealth, K2 Razorback, Steel Bianchi roadie, Bianchi Super GL, Specialized Stumpjumper, and 3 beach cruisers
Why don't you just get a different headset that doesn't have a logo on it? I don't see the point of having Chris King stuff if it isn't pretty and anodized.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
The solution, green sharpie (its a green headset). It doesnt completely get rid of the logo, but its pushed back enough that it looks pretty cool. The sharpie plan seemed best after I contacted the CK folks and this is what they had to say: "The laser etching on the cups can not be removed. The white is the lower surface of the anodized coating which is exposed after the colored portion has been removed. Below the logo is the silver raw aluminum. Exposing raw aluminum would allow corrosion to set in to the parts. Thank you for your support and have a good day". Thank for everyones input, it was helpful.
"Uh-uh. Respek Knuckles."
Bikes: '06 LeMond Versailles, '04 S&M Beringer, '03 Quamen Bowls, '68 Raleigh Grand Prix (converted to fixed gear)
Apparently the new high-tech ultrasonic parts cleaners will take logos off certain components. We called around a few shops that had 'em when we went shopping for a new solvent tank for our store, more than one shop said their ultrasonic cleaner would scrub logos off crank arms, derailleurs, anything you left in there too long.
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
If you get yourself on a auto rotating lapper with 10 micron diamond paste, you can polish the CK to a shiny jewelry quality finish.
Cycle Dallas
Quoted: 197 Post(s)
Liked 10 Times
Originally Posted by dminus22
--snip-- Exposing raw aluminum would allow corrosion to set in to the parts. --/snip--
Bikes: '64 Schwinn Traveler, '73 Astra Tour de France, '79 Fuji Gran Tourer, '86 Dahon folder, '94 Specialized Hardrock, '95 GT Timberline, 2005 Jamis Aurora
Originally Posted by MMACH 5
Does aluminum corrode?
The shiny surface of raw aluminum quickly corrodes to dull, whitish-colored aluminum oxide. Aluminum oxide is very non-reactive, and the thin layer of aluminum oxide on the surface of the part prevents further corrosion of the aluminum beneath it.
Quoted: 2026 Post(s)
Liked 1,096 Times
I'm late to this discussion but I gotta ask, why do you want to remove the Chris King logo? People pay a huge premium just to be able to display it on their bikes.
Maybe there will be a thread on "How do I etch a CK logo on my FSA headset?"
Klaatu barada nikto
Does anyone know how to safely remove the white laser etched Chris King logo from a CK headset.
I know that does not solve your problem, but it's an alternative solution with same end (at the cost of a new headset, of course).
See this page:
https://www.peterwhitecycles.com/headsets.asp
and, you can also see Peter's lovely wife, Linda ;-)
Quoted: 443 Post(s)
Liked 27 Times
I just spent a couple of hours turning an ugly set of Dia Compe 983 brakes into things of beauty. I used a pad sander with 220 grit and then a couple of grades of steel wool and then buffed with rouge on a cotton wheel. They look like I had them chromed.
The rims, hubs cranks, bars, stem, brakes and seatpost on my Gitane TdF are all bare unprotected aluminum and they're 35 years old. There are no signs of corrosion on any of the parts. You don't have to worry about corrosion as long as you polish the parts once in a while.
https://community.webshots.com/photo/...15654223LpNOlK
Bikes: 2003 KHS F20-Westwood folding & enough parts to make several more bikes...
If it's laser etched, you're not going to "remove" it at all - you'd only be sanding down surrounding areas so the logo isn't as visible. A better option if it's etched is to remove all the anodizing as bare aluminum will make the logo far less conspicuous.
I don't know how the logos are placed on the Chris King headsets, however, I have some experience with removing silk-screening.
First, try a standard, pink eraser. You might test this on an inconspicuous area to make sure it doesn't take the anodizing off - usually it doesn't.
Next step up is to try a blue, abrasive pen eraser. Be VERY cautious with this as it's much more likely to remove the anodizing.
Finally, if you don't mind having a bare aluminum headset, BLEACH!
Household bleach will remove anodizing from aluminum. Soak the part in it. Rinse with water when done and dry thoroughly.
Originally Posted by powers2b
Laser etching is only a few thousandsth deep and could be removed by sanding/filing.
Enjoy
Enjoy
Tim
Easy way to remove the anodizing is to use oven-cleaner (sodium-hydroxide). Spray on, let sit for 10-15 minutes, scrub off with scotch-brite pad. If the laser-etching was deeper than the bare-aluminium surface after you've removed the anodizing, then you're gonna have to sand some more...
That's a lot of work, I say just spray-paint it...
Liked 1,096 Times
Originally Posted by Moose
ammonia and bleach are not the same thing and absolutey should not be mixed!!!
Quoted: 273 Post(s)
Liked 10 Times
Originally Posted by Dirtdrop
I disagree. You just need a cotton wheel, some rouge and something with a lot of torque to spin the wheel.
