How to remove paint from aluminum
Bikes: Fiorelli Coppi, Vitus 979, '84 Raleigh Comp, Miyata 710 & couple of old green Raleighs
I bought an aluminum Vitus 979 for pretty cheap, but it had been given an unattractive home paint job in an attempt to make it look like the European bikes of the day (hence the good deal). Does anyone have a recommendation for a paint stripper/technique that will preserve the original polish, assuming it was in good shape before the paint job? I don't want the frame to dissolve on me.
Bikes: Schwinn Letour 1989, Shogun 300 198?
Aircraft Paint Stripper, it is sold at most Auto Parts stores and Wal-Mart. Wear Gloves and don't get it on anything other than metal. It will take off any paint and/or clear coat.
missing in action
Quoted: 42 Post(s)
Liked 49 Times
On the other hand, you may find that the old clearcoat was in rough shape prior to meeting the spray bomb.
You Know!? For Kids!
Isn't the 979 a bonded frame? Would be careful using chemical strippers on it if so?
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Thanks. I'll try some on a beer can to make sure it doesn't look bad. Another good excuse to have a beer.
Good call - It crossed my mind, too. I'll protect the seams somehow.
Be sure it's aircraft or at least states that it is safe for aluminium. The other common paint stripper formula uses a caustic base that will eat aluminium.
Bikes: Trek Madone 5.5, Klein Q Pro Elite, Surley LHT
Be careful not to get any striper on your skin. Stuff burns like h___.
Quoted: 1572 Post(s)
Liked 643 Times
When i built my fixed gear bike I started by stripping all of the paint off of an old Raleigh Technium (aluminum main frame bonded to steel stays). I used some Zip Strip that I bought at the local hardware store. It says not to use it on plastics and lots of other things, but doesn't say anything about aluminum. At any rate, both the aluminum tubes and the bonding are doing fine.
Then again, I didn't have much to lose with the Raleigh. That Vitus is a considerably nicer frame.
Shimano Certified
One mistake often made with chem strip is the duration on the surface. If it is left on too long it can be detrimental to the process, normally for drying out, but also for various effects on plastic/bonds/etc. Use a scotchbrite pad to scrub it in and test periodically over a couple of minutes until it lifts satisfactorily, scrub it the rest of the way and rinse immediately thereafter. Continue to scrub as it is rinsed to assure the stripper is cleaned off completely as it can affect the paint finish later. For most finishes this is only a small handful of minutes total.
"this is not suck"
I frickin HATE chemical strippers, they suck (yes even aircraft stripper, provided you stay conscious long enough while using it) they are caustic, they burn you, they DO NOT REMOVE FACTORY PAINT COATINGS VERY WELL, they are hard to remove, they are messy, they stink, they have noxious fumes,...
should I go on?
take it to a media blaster, and tell them how you will be painting it (or powdercoat) because they use a different media for each coating type.
my guy charges me $25 to blast a frame, and $30 for a frame and fork.
best thing about the blaster, is it's no work, no mess, and you get perfectly clean bare metal with no accidental stripper residue hiding in crevices just WAITING to "strip" your new paint job.
I was a professional custom painter for almost 35 years, and I stopped using chemical strippers back in the 70's.
maybe for your wifes antique credenza, but not for a bicycle.
should I go on?
try acetone - cheap - safe on aluminium and may not damage clear coat. Do a test section on the bottom of your bb shell - media basting may be the best method - but can't be done at home, if it can please tell me how without expensive equipment.
Will media blasting preserve the original polish of the Aluminum (as the OP noted)?
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
If this is a crappy garage paint job, acetone will likely take off the new paint without attacking the old. It's cheap, not mind-blowingly toxic, doesn't burn your skin (though it will dry it out because it dissolves oils) and cleanup is done by leaving stuff around outside to evaporate.
Pleasurable Pain
Bikes: Voodoo Rada, KHS Alite 4000, Smith & Wesson Tactical, Diamondback Response
I have heard that Permatex Gasket remover works great on frames. Spray it on and use a brush or maybe a putty knife to scrape off decals and paint.
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
If this is a bonded frame, I think you would have to be nuts to use any chemical method to remove paint.
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
"this is not suck"
if you REALLY want to try and save the original finish, you can try:
use zip ties and wrap the entire frame with paper toweling, then soak the paper towels in acetone, and wrap the entire thing with plastic wrap: tight around each tube,..and leave overnight.
check in the morning, if the paint isn't wrinkling, unwrap and add some more acetone, and let it sit some more.
eventually you should be able to lift the paint off quite easily, HOWEVER, you will have to use several applications of fresh acetone, on fresh towels until it's totally clean, and finally a acetone rub down to clean it all up.
now if that IS a bonded frame, DO NOT USE ANY KIND OF CHEMICAL STRIPPING AGENT OF ANY KIND: no acetone, no alcohol, NO paint stripper, NO orange based products OF ANY KIND (containing D-limonene),pretty much all you can do is get some superfine scotch pads (grey or white) or 1500 grit (or finer like 2000, or 2500) and a bucket of clean water and start scrubbing, until all the paint is removed,....this is going to take several days of 3-5 hours of scrub/sanding.
then you'll have to polish it again to get the original shine back.
check with your media blasting service, because my guy has a superfine plastic bead that he uses sometimes on small parts, and they come out looking almost like polished aluminum, just not quite that shiny,..but that would be a great place to start polishing it.
first thing is to find out if that IS a bonded frame, because that tells you what methods will remove the coating safely.
keep in touch, I'm curious as to how this comes out.
Quoted: 443 Post(s)
Liked 27 Times
Stripper works for me. I use Jasco from the hardware store. I apply it with an acid brush and wipe it off with paper towels or newspaper, then I go after it with a wire brush. Some spots may require a second or third application. I wash down the frame with lacquer thinner when I'm done. I took the original paint off of a '74 Raleigh Competition a couple of weeks ago in about 45 minutes. I've never had stripper cause a problem with the paint.
The stripper burns when you get it on your skin, but it won't even leave a mark if you wash it off right away. I got some on my eyelid once and that hurt! I always wear safety goggles now.
I have no experience at all with aluminum frames and I probably never will.
I use acetone. Nail polish remove has acetone in it but at a lower percentage.
Acetone works great. Yu can also use sandpaper.
Or both :-)
Or both :-)
Not sure what they glued them to together with .. epoxy once cured ,doesn't un cure ..
to be safe, mask off the joints.
