Campy 8 speed
Bikes: Canyon Ultimate, GF 29'r, Specialized Crux
Campy 8 speed
Does anyone know a sorce for Campy 8 speed stuff? Shimano still sells 8 speed cassettes, but I can't seem to find any Campy. With a little filing will a Shimano work?
feros ferio
Check with SheldonBrown.com. Also, I have heard of another European brand which is Campy-compatible, and you can always use 7-speed cogs in an 8-speed system.
human
Bikes: 2005 Litespeed Teramo, 2000 Marinoni Leggero, 2001 Kona Major Jake (with Campy Centaur), 1997 Specialized S-Works M2, 1992 Specialized Rockhopper
Branford Bike is another good choice. I find their prices good and their service excellent.
when walking, just walk. when sitting, just sit. when riding, just ride. above all, don't wobble.
The Irregular Cycling Club of Montreal
Cycling irregularly since 2002
HomeBrew Master!
Bikes: Aegis Aro Svelte, Surly LHT, Cannondal R3000 tandem, Santana Triplet.
Here's some places to try:
Campagnolo Cassette 8 Speed Steel $32.95
https://www.excelsports.com/main.asp?page=1
Campagnolo 8sp $30.00
https://www.labicicletta.com/
No, to make a shimano work, it would take much more than filing.
First, you need a new hub. Shimano cassettes aren't compatible with campy hubs. As well the cogs are the wrong spacing for campy derailleurs so you would need to change them which involves messing around with pop rivets etc.
It is possible to work in a shimano hub, but it will be so much work, you may as well change the whole drivetrain.
I would do my best to try to find a campy cassette.
I wish you good luck in finding it.
I know that there are freewheel mechanisms available for using campy cogs on a shimano hub, but I haven't heard of it working the other way. Those conversions aren't cheap, either.
Je vais à vélo, donc je suis!
Bikes: Seven Axiom Ti, Trek 620, Masi cylocross (steel). Masi Souleville 8spd, Fat Chance Mtn. (steel), Schwinn Triple Bar cruiser, Mazi Speciale Fix/single, Schwinn Typhoon
Forget the Shimano cassette, you could work on it for weeks and still not get it to work.
Two Wheel Transit, ( my LBS), keeps 8spd campy cassettes in stock!
www.twowheeltransit.com
Ride with Campy pride
Pat
Pat
THANKS TO ALL WHO REPLIED!!! I found what I needed with your help!! I still would like to know why these manufacturers drop a perfectly good (still functional) product line.
'cause they're all trying to build better mousetraps to sell to people who've been convinced to think they need them.
Ride the best stuff...
pat
pat
human
I switched from Campy (8) to Marchisio when 28tooth cogs became hsrd to find. An added advantage is that I can replace the cogs individually, since the big ones seem to wear more with me.
With Marchisio, you can change the spacers to get the cogs to work with any indexing system, eg Shimano mech and changers with a Campy hub. This is not so crazy, if you want a really long rear mech and maybe bar-end shifters.
Torelli.com has more info
