Post pictures of your Hybrid
Old 08-16-09, 09:41 PM
  #126
Velocommuter Commando
Sirrus Rider's Avatar
Bikes: '88 Specialized Sirrus, '89 Alpine Monitor Pass, two '70 Raligh Twenties, '07 Schwinn Town & Country Trike, '07 Specialized Sirrus Hybrid
Quoted: 23 Post(s)
Liked 36 Times in 11 Posts
Originally Posted by Panthers007
I also design large-scale extraction and distillation devices for highly toxic and unstable chemicals.....Run! Run! Run for your lives!
Moonshine?
Sirrus Rider is offline
Old 08-16-09, 09:42 PM
  #127
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 67 Post(s)
Liked 129 Times in 96 Posts
Sirrus - You have some might comfy looking rides there.
Sixty Fiver is offline
Old 08-16-09, 10:01 PM
  #128
I'm not touching them. They work as intended with 2mm distance. Thanks anywho.
It's been my experience not to mess with configurations that designers and engineers spec out when it comes to mechanical devices.
Designers and engineers spend a great deal of time, money, and research to ensure that their product is going to perform at it's optimum level of performance -- if, and it's a big "if", their product is installed and used as intended. You can do whatever you please, but I think the others are correct -- your brakes are indeed not installed correctly. I have no idea if your setup has an adverse effect from what the designers and engineers intended but it may not work properly under certain circumstances if the brakes perhaps are in a situation of extreme conditions such as power braking, etc. Installed incorrectly, it's likely there are stresses applied in manners that the brakes were not designed for -- and from your photo, it appears that your brake arms are too far apart (note the cable is arched instead of being straight across horizontally -- that's not good).
Here's a link to the installation document:
https://www.sram.com/_media/techdocs/...igit%207SL.pdf
It clearly shows the correct alignment of the brake arms in illustration #2.
Sounds to me that you're a bit on the stubborn side and don't want anyone telling you that you possibly flubbed up your install. No big deal really. Personally, I'd just suck it up, reinstall the correct sized washer and move on with the knowledge that my brakes are installed as the designer intended.
65er means well and is only offering you some helpful advice based on his experience (forgive him if he's not as humble as he ought to be ).
Just saying is all - I'm merely a guy typing on the internet -- you should by all means do whatever you like.
WCoastPeddler is offline
Old 08-16-09, 10:06 PM
  #129
Originally Posted by msincredible
Here's my 2006 Cannondale Bad Boy, sadly it was stolen last year.
Ms Inc, that is (was) a very cool looking ride. What did you replace it with?
(my hybrid is in the shop getting a wheel rebuild -- I'll post pictures of it when I get it back)
Old 08-16-09, 10:41 PM
  #130
Gouge Away
kaliayev's Avatar
Quoted: 26 Post(s)
Liked 8 Times in 4 Posts
My 94 Specialized Crossroads.
kaliayev is offline
Old 08-16-09, 11:22 PM
  #131
crazy bike girl
msincredible's Avatar
Bikes: '07 Orbea Onix, '07 Birdy Yellow, '06 Cannondale Bad Boy (stolen)
Liked 3 Times in 3 Posts
Originally Posted by Bat22
Geez, that was a good looking Bad Boy. I never really got the hang of using that Crank bros. pump.
Thanks! I liked that pump, enough that I got another one, but the second one eventually died and took a valve stem with it. Sticking with Topeak now.
Thanks, WCoast. I haven't fully replaced it yet, but I got a Birdy (folder) that serves some of the same purposes.
I also have plans for a touring/commuting bike, I've got the frame and am working on the other bits.
Countries I've ridden in: US, Canada, Ireland, UK, Germany, Netherlands, France, China, Singapore, Malaysia
States I've ridden in: Illinois, Connecticut, Massachusetts, Pennsylvania, California, Nevada, Missouri, Colorado
msincredible is offline
Likes For msincredible:
Old 08-17-09, 05:06 AM
  #132
Freewheel Medic
pastorbobnlnh's Avatar
Quoted: 1452 Post(s)
Liked 2,195 Times in 962 Posts
My 2003 Cannondale Comfort 600, equipped with SRAM Dual Drive and Headshok. Recently I added an FD and double chainrings (32 & 42) to make it a 54 speed bike. Also, I believe I have finally found a pair of fenders I believe I can make work with the Headshok!
Bob
pastorbobnlnh is offline
Old 08-17-09, 05:34 AM
  #133
droobieinop's Avatar
Bikes: jamis xenith comp '08, trek 750 hybrid (w/drops) c.1995, centurian fixie, kona cindercone mtb c.2000
Why stop at a double when you can run a triple. 54 gear combos, crazy.
droobieinop is offline
Old 08-17-09, 08:09 AM
  #134
Great State of Varmint
Panthers007's Avatar
Liked 15 Times in 15 Posts
Stubborn? Moi? Try incorrigible.
And not 'moonshine.' That's way to easy. Try things like anhydrous diethyl-ether containing organic nitriles(cyanides).
Panthers007 is offline
Old 08-17-09, 08:19 AM
  #135
Its all the same if its burns...
yea, ok not really, is that like biomass fuel?
Old 08-17-09, 11:12 AM
  #136
Freewheel Medic
I didn't have to change the original crankset by going to the double. The guard came off and I mounted the big ring on the outside. If I ever replace the crankset I will do so with a triple, probably a 24-34-44, but my guess is this will be a few years down the road.
Bob
Old 08-17-09, 11:21 AM
  #137
Experimental extraction method for gold.
Old 08-17-09, 02:03 PM
  #138
Unique Vintage Steel
cuda2k's Avatar
Bikes: Kirk Frameworks JKS-C, Serotta Nova, Gazelle AB-Frame, Fuji Team Issue, Surly Straggler
Quoted: 57 Post(s)
Liked 225 Times in 56 Posts
1990 Schwinn Crosscut, built by Giant from what I can tell. Shimano 400LX group, including one of the very first "STI" shifters (yes, they came out with integrated shifters/brake levers for flat bar first, then for drop bars). So far I've replaced the original saddle with the WTB model seen here, added a cyclometer mount, adjusted the bar-ends and rack position. Currently putting new brakes on it.
cuda2k is offline
Old 08-17-09, 06:45 PM
  #139
Zensunni Wanderer
KShep's Avatar
Originally Posted by flaxx
This is my hybrid, a severely pimped dr.dew, i just love the color of the 2007 frame.
Weighs 10.2 kg First long ride will be to work tomorrow, can't wait...
Congrats. Nice work....I like what you've done to her. Nice tomato plants too.
KShep is offline
Old 08-18-09, 03:21 AM
  #140
Bikes: Cross Check with Rohloff hub
reueladhikari is offline
Old 08-18-09, 04:48 PM
  #141
1997 Gary Fisher Nirvana
Back in 1997, marketing mavens at Fisher called this a Sport Utility Bike (s.u.b.). It's essentially a 26" mountain bike with slicks. Its frame is triple butted steel, with steeper geometry than most mtb's. It also has larger chainrings than most mtb's: 28/38/48. I changed the pedals and the seat, and added the front rack and basket.
I'm not sure how long Fisher went with the s.u.b hype. Probably not long, since I hear the bikes didn't sell very well. But I've been happy with it.
mowyang is offline
Likes For mowyang:
Old 08-18-09, 05:15 PM
  #142
sh00k's Avatar
Bikes: 2011 Trek FX 7.3 | 2015 Trek FX 7.4 | Lotus Classique
Quoted: 171 Post(s)
Liked 22 Times in 16 Posts
Pics of my stock Trek FX 7.2 earlier this summer along the West side bike trail in Manhattan.
Only thing I did to the bike was that Schwinn pouch which was awesome for my cellphone/wallet/keys and I also had installed the Schwinn $9.99 bike computer I got from Amazon. I am going to get another one of these $10 computers for the $1700 bike I'm ordering :-D
sh00k is offline
Old 08-18-09, 05:47 PM
  #143
Bikes: 2015 Access Chinook Bravo Fat Bike /2012 Scott CR1 Comp /2009 Trek FX 7.3 White-Silver Duotone
fatboy cycling is offline
Old 08-18-09, 05:53 PM
  #144
Timber_8's Avatar
Liked 6 Times in 3 Posts
I like that, how do you like the Areo Bars
Timber_8 is offline
Old 08-18-09, 05:55 PM
  #145
Pedal faster not harder.
Bikes: Ummmm...Cannondale F4000..Ummmmm...Yeti ARC-X Cyclocross..Ummmm...Rocky Mountain Vertex TO with a BionX PL350 Electric Conversion...Ummmmm..Rocky Mountain Cardiac..Ummmm..thats it for now I think. I'd have to go look in the basement to be sure.
@lesmcluffalot: nice ride! My next project will be based on a cyclocross frame as well, but don't know which one yet ...
Thanks flaxx. I prefer a flat bar for riding among traffic. I just feel more secure having all controls at my finger tips. The bonus is this set up is a whole 2 pounds lighter than the road set up. The front end of this bike is uber light. I do have another cross bike that is my "road bike." It still has the road bar set up which is better for longer rides for sure.
LesMcLuffAlot is offline
Old 08-18-09, 05:58 PM
  #146
I love them! They really increase my speed if I stay down on them. However I need to build up my endurance because when I stay down on them for very long I lose my wind and legs.
Old 08-18-09, 08:29 PM
  #147
Forum Moderator
cb400bill's Avatar
Quoted: 3090 Post(s)
Liked 6,599 Times in 3,785 Posts
Great thread. Lots of wonderful bikes on here. There are some modifications people on here have done that I may copy.
This is my 1993 Raleigh C-50. I bought it new to ride with my kids and now use it for commuting, errand running, and riding with my wife.
cb400bill is offline
Old 08-18-09, 08:43 PM
  #148
who me??
imstumpedru's Avatar
Bikes: Team fuji Classic road bike, lemond 80's japenese road bike, trek hybrid, trek 830 mtn bike,
Originally Posted by AlmostTrick
I'm glad to see the new Hybrid forum, and did vote yes for it. Here's my '93 Bianchi Avenue that I bought new. Bianchi's term for the hybrid series at the time was "Cross Terrain".
Modifications include Sun wheels with sealed bearings from Harris cyclery. Schwalbe Marathon 700x32 tires, and closer ratio (than original) 6 speed freewheel.
SKS fenders and Transit rear rack.
Ergon grips and Patrick Star navigation system.
Go patrick
imstumpedru is offline
Old 08-18-09, 08:52 PM
  #149
who me??
Here is mine.. A 2002 trek 7100 Almost all original saddle and the bag are the only difference.
File Type: jpg
File Type: jpg
Old 08-19-09, 01:57 AM
  #150
Timber_8's Avatar
I also noticed an dramatic increase in speed, Not just top speed but my average speed. Try readjusting your seat. Not just the height but the tilt. Areo bars put you in a dramatically different position. I also recommend a helmet mirror if you using Areo Bars.
Timber_8 is offline
