HR Question for Ric
Serotta
Bikes: Serotta Legend Ti, Paramount (waterford) custom
Ric, I have seen in the past comments you made on HR rate dropping when you get fit. Is there info on this? I think this just happened to me. I have been back riding for 4 months now after 3 years off. My resting HR has dropped from 78 in April to 46 now. Biggest change I notied last week is my work out hr has dropped. I took a weeks vacation and have really noticed this change. I tend to pedal at a higher RPM, 95 - 105 as this works better for me. Is this normal? My hr seems down ~ 10 -15 beats from 2 months ago.
TIA
TIA
Bikes: Handsling AIROevo and CEXevo
TIA
TIA
Yes, HRmax does decrease as you get fitter because plasma volume increases. after a period of detraining, plasma volume decreases and HRmax increases.
During submaximal efforts at a given workload (i.e., a specific power output) HR will tend to decrease as fitness increases.
Resting HR decreases with increased fitness
when you are untrained it's comparitely easy to work at an intensity that elicits a high(er) rate, however, as you start to gain fitness it can become psychologically harder ride at an intensity that elicits that same HR as you now have to push considerably harder.
ric
Elitist Jackass
Bikes: Cannondale 2.8, Specialized S-works E5 road, GT Talera
Originally Posted by Ric Stern
however, as you start to gain fitness it can become psychologically harder to ride at an intensity that elicits that same HR as you now have to push considerably harder.
ric
ric
Ain't that the truth!!!!!!!!!!
Serotta
Thanks very much Ric! So much of the info is blocked from here that I cannot read some of the links. I do not have a watt meter, but I have noticed that my HR at a given level of work, ie percieved effort and speed, has decreased. I was able to ride harder yesterday at a lower level yet attain higher avg speed and shorter ride time than 2 months ago. Boy have I noted the harder to get to that level here lately. Very noticable after a full week of rest.
Thanks for the info!
John
John
John
John
After a full week of rest, the situation should be reversed as your plasma volume will have dropped to sedentary levels and your HR will have risen.
it's impossible to compare speeds over such time periods (or even over shorter ones) as change sin atmospheric conditions can significantly alter velocity, due to changes in air density/barometric pressure/temperature.
sorry that none of this really helps
ric
Originally Posted by JBBOOKS
Amen, Smoothie!
ric
Serotta
Thanks Ric, gives me a starting point. I was off the bike for a week, but I did fly my stunt kites ans walk daily. Got about 4 hrs daily of low aerobic workouts.
Originally Posted by Knighty
You aren't suggesting that the entire training effect is lost after one week, are you?
of course there's a myriad of factors that are involved in training (and detraining) two review papers are
https://www.ncbi.nlm.nih.gov/entrez/q..._uids=11252068
https://www.ncbi.nlm.nih.gov/entrez/q..._uids=11474330
ric
Interocitor Command
Bikes: 3 Road Bikes, 2 Hybrids
... when you are untrained it's comparitely easy to work at an intensity that elicits a high(er) rate, however, as you start to gain fitness it can become psychologically harder ride at an intensity that elicits that same HR as you now have to push considerably harder...
