Shimano 9-spd compatible twist grip shifters
Bikes: Volagi, daVinci Joint Venture
My wife currently has trigger shifters on her CF road bike and needs to change to twist grip shifters due to problems with her left hand. FD is Shimano 105 triple, RD is Deore 9-spd. I understand Shimano and SRAM both make models that will work. Would appreciate some model number suggestions.
Also, currently have MTB bars which I will probably keep on her bike, but not being familiar at all with twist grip shifters is it possible to install these shifters on bullhorn bars? Said differently, does the clamp on these shifters open up enough to slide over the curve(s) in the BH bars?
Thanks!
Thanks!
I'm Carbon Curious
I far as I know SRAM is the only one who makes 9 speed grip shifters. So you will need to buy a SRAM rear derailleur and front derailleur b/c it pulls the cable in a different pull ratio than shimano. The only SRAM grip shifters that are shimano compatible is their MRX series which is only 7 or 8 speed. Shimano makes 7/8 speed Revoshifters which is their version of grip shifters, but I don't think they come in 9 speed.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Here's a SRAM 9 speed Shimano compatible gripshifter: https://www.bikeman.com/LD2680.html.
SRAM grip- or triggershifters with names (as opposed to numbers) work with Shimano RD's.
Don't think you'll be able to take any gripshifters around a curve in a bar.
Insane Bicycle Mechanic
Quoted: 806 Post(s)
Liked 710 Times
Thanks!
Thanks!
Jeff Wills
Jeff Wills
sizzam
Bicycle Mechanics
3
03-14-11 09:29 PM
