Hatta Swan BB spindle and crank question.
Old 04-17-11, 06:54 AM
vladuz976's Avatar
Bikes: Nagasawa Special Track
Liked 4 Times in 2 Posts
I have a Hatta Swan R9400 bottom bracket.
The cranks in the pictures are Sugino 75.
Before, I had Sugino RDs on the same BB, and they would slide in a bit further toward the BB shell.
With the Sugino 75 cranks it seems that they don't slide on quite as deep.
Is that normal? Shouldn't they both fit on their similarly?
File Type: jpg
File Type: jpg
vladuz976 is offline
Old 04-17-11, 11:27 AM
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Liked 27 Times in 18 Posts
The RD is JIS and the 75 is not
hairnet is offline
Old 04-17-11, 11:36 AM
i smell bacon
yummygooey's Avatar
Bikes: Geekhouse Deerfield, GT Edge Ti, Spooky Skeletor, TET Track, Ritchey P-650b, Bridgestone MB-3
My 75s on a JIS spindle look the same. I don't know if that's bad or just not optimal.
yummygooey is offline
Old 04-17-11, 11:50 AM
u________u
jessesv's Avatar
75's are ISO and depending on who you ask r9400's are ISO as well, so technically they are fully compatible with each other. however, the r9400 might have some sort of unique taper on it since people have had success using JIS and ISO cranks.
as long as your chainline is straight, that small of a gap is fine. if your chainline is off, just find a new spindle.
jessesv is offline
Old 04-17-11, 12:52 PM
Veteran Racer
TejanoTrackie's Avatar
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times in 431 Posts
Provided you have a good chainline, it doesn't matter.
What, Me Worry? - Alfred E. Neuman
Originally Posted by Dcv
I'd like to think i have as much money as brains.
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
TejanoTrackie is offline
Old 04-17-11, 03:34 PM
i smell bacon
yummygooey's Avatar
Yay!
Old 04-17-11, 09:20 PM
vladuz976's Avatar
Not sure if Hatta R9400 is JIS or ISO. I always thought it's ISO, since it's so common with Sugino 75 cranks.
Old 04-17-11, 09:30 PM
Veteran Racer
Something is wrong. Your adjustable cup is screwed in too far and there is no lockring. And yes, it is ISO with a 109mm spindle length, same as the Sugino 75 BB.
File Type: jpg
Old 04-18-11, 09:14 AM
u________u
jessesv's Avatar
yeah i just noticed that too.
should look like this:
jessesv is offline
SchwingBikes
General Cycling Discussion
5
07-06-18 07:37 PM
stryper
Bicycle Mechanics
10
06-19-14 08:26 AM
eschlwc
Classic & Vintage
25
02-11-12 09:08 AM
diff
Singlespeed & Fixed Gear
2
11-09-10 11:15 PM
Silkworm
16
01-01-10 09:46 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
