View Poll Results: Helmet wearing habits?
I've never worn a bike helmet
178
10.66%
I used to wear a helmet, but have stopped
94
5.63%
I've always worn a helmet
648
38.80%
I didn't wear a helmet, but now do
408
24.43%
I sometimes wear a helmet depending on the conditions
342
20.48%
Voters: 1670. You may not vote on this poll
The helmet thread
#2826
Except that it can be clearly proven that smoking damages lungs. You're assuming that by simply wearing a helmet, it protects your noggin. This hasn't been clearly proven. In fact, there is evidence that when helmets are worn, injuries increase.
#2828
Bikes: A load of ancient, old and semi-vintage bikes of divers sorts
Or highly likely.
Or perhaps the people claiming that helmets are effective should be required to explain why fatal crashes have doubled.
Aw, I don't remember the exact figure, but it's around a 5% increase.
However, the fatal crashes in pro cycling typically happen at speeds that are very high, and a difference between 60 km/h and 63 km/h is unlikely to make that big a difference.
Edit: What I wrote aboute "increased speed" referred not to the increased speed of the pro races but to the difference in the effect of a helmet at 20 km/ respectively 60 km/h. Sorry about the confusion.
That's not what I "required". I tried to show you that you offered no explanation, and in light of that, I offered an alternative, plausible explanation which is in line with what we know about the capacities and drawbacks of helmets. I have now also explained why it probably doesn't have anything to do with the speed. As for the number of crashes, I have no idea. But look at older footage of the Tour, the Giro etc. Plenty of crashes.
(Or look at the Youtube-video I linked to showing Fuente's descent. You may remember that he and Merckx crashed at one time at high speeds.)
Sort of like Elvis being alive. I'm not required to prove either claim: the people making the claims have that requirement.
Please provide any data about the speed of the TdF crashes before and after the introduction of helmets you have. Once I see your data, maybe, I'll comment on it.
??? So, I'm required to prove it isn't correct but you aren't required to prove that it is correct? That's bizarre too!
#2829
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
That's what I've been saying all along, those that don't wear helmets will die, it's just natural selection at work...those that are dumb will die off eventually leaving only the higher IQ people. So I'm all for those people not wearing helmets, go for it!
#2830
Yes. It says something about how we should approach statistics. Have you for just ONE moment considered that the reason might not be that it's because they're intelligent but because they typically belong to a social class with a generally different life style and different risk assessment (AND have bought into the myths about the life-saving helmets)?
#2831
Beautiful parody
#2832
Observer
Bikes: 2000 LeMond Buenos Aires
It appears that the only differences is that crashes are more common in MTB biking and those crashes never involve cars. Outside of that, there's a lot overlap of crash properties between the two activities. That is, if helmets are useful for some MTB crashes, then they are useful for some road cycling crashes.
Of course, we don't really know (that is, assuming the events are similar is risky but assuming that they are different is equally risky).
#2833
Liked 253 Times
#2835
I wear a helmet because it's law in my city and makes me feel a bit more safe, psyche-wise at least. It could be useful someday, or block my view from some imminent danger coming from the side some other day, who knows.
However, it'll do pretty much nothing, should a truck decide to run over my torso. Or my head, for that matter.
/thread.
/thread.
#2836
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
First approach would be to ask the poster of the snippet of helmet-IQ "info" to provide a reference a little more substantial than the vague and unsubstantiated "Studies show..." It takes very little IQ to post rumors and fabrications about "studies" and even less to believe them without question.
#2838
You gonna eat that?
I'll throw this into the mix from another thread:
His "helmet was absolutely smashed" but his only injury was a broken left leg. And to answer the question I had, no, that's not a pedestrian crosswalk; it's a dedicated bicycle path.
While there is a lot of debate about the methods used to determine helmet safety, this is a pretty clear example of a helmet at least helping prevent a more serious head injury.
#2839
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,536 Times
But thanks anyway for posting the URL for the thread. I don't normally read anything on that list. It was interesting and provided some good/useful information about insurance coverage limitations.
#2840
As much as people would like to thnk otherwise, once a helmet has exceeded its limits, it can't help
#2841
it is a clear example of a circumstance in which the helmets limits have been exceeded (those limits are exceeded beyond simple falls - helmets are not intended for impacts with motor vehicles)
#2842
I tend to think it's a perfect example of a helmet doing what a bicycle helmet is designed to do. The rider is thrown from his bike, goes upside down and lands on his head. Is this not basically the standard of which bicycle helmets are tested. That being, dropped upside down from a few feet. The rider says he suffered no head injury, yet the helmet was destroyed. I'd say the helmet did it's job.
A helmet is destroyed when it passes it's maximum capacity. This happens at far lower forces than most people think.
#2843
A helmet is tested by a simply drop only. It is not tested by a drop that involves an acceleration outside of the force of gravity acting upon the drop.
#2844
I agree, bicycle helmets have limits of protection and one would provide little to no protection if your head were to bounce off the windshield of a vehicle at 35 mph, or even much less perhaps, but won't you concede that in the subject crash, the helmet probably provided some measure of protection considering the rider suffered no head injury?
But don't take my word for it. Take the word of the director of the largest facility in Europe that tests helmets to make sure they meet standards:
the protection helmets provide is for the kind of accident where the rider falls to the ground without motor vehicles being involved...
The tests cycle helmets currently go through mean they should offer similar protection to a pedestrian that trips and falls to the ground...
#2845
#2846
not really. Passed it's capacity, a helmet bottoms out and can offer no more protection. Cyclists survive such impacts without helmets all the time. The presence of a broken helmet is no proof of anything other than the helmet passed it's limits
#2847
#2848
I know someone that put their head through an SUV windshield. Their jaw and some teeth were broken. Nothing else. I know someone else that was struck from behind and somersaulted over the vehicle onto their head. Scalp lacerations were the only result. Obviously the fact that were both carrying mastercards in their wallets protected them. Wouldn't you concede that?
#2849
Quoted: 1610 Post(s)
Liked 2,592 Times
I'm going out on a limb (the one that supports a head) and I'll say that a head covered with some styrofoam will have less damage then one without if it meets a hard surface (concrete ,asphalt, car, tree). I've watched them drop eggs off two story buildings, and the ones in some sort of packaging tend to do better. Doesn't make sense to argue that point. The point most non-helmet people have is that they've chosen not to use one when they ride in low risk situations.
#2850
Geck, wo ist mein Fahrrad
safety IS the reason I don't wear a helmet. the noise a helmet creates makes it impossible to hear anything else. faster than 40 mph and it's just one long LOUD whistle. 50- 60 mph and hearing loss would be a larger concern. you can argue how a foam hat can save lives all you want, but I'm not eliminating my second most used sense for safety, for safety equipment.
