Need advice
Need advice
Im truly not a bike mechanic but I'm trying to replace the bearing cartridges for rear suspension on my Giant Reign. I'm having trouble removing the air shock from my frame, seems the bottom bolt will not budge. I've removed the nut but it just spins and seems that it should just tap out but It won't budge. Any advice?
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
What year Reign?_
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
Moar cowbell
Quoted: 29 Post(s)
Liked 6 Times
Bolt should tap out with a soft-faced hammer or plastic mallet. Make sure the rear suspension is totally unweighted (in a stand or hanging). If this task is daunting, you may want to rethink DIY on the rest of your Maestro setup, as all of the pivot bearings need to be pressed out/pressed in to replace - - which you can do if you are handy with tools and can improvise bearing presses with bolts, clamps and various-size sockets (or short pieces of tubing). But if you are not, you may want your Giant dealer to do it for you.
There is a pretty good look at pulling down the '05-'07 Reign/Trance pivots out on YouTube:
jambon
Bicycle Mechanics
7
11-24-17 08:14 AM
