700c vs 29": difference?
Marathon Plus - Schwalbe Fahrradreifen, Rollstuhlreifen, Scooter- und Mopedreifen
contiuniously variable
Just putting this out there, that there are different size 700 standards, but 700c and 29 are the same size.
- Andy
- Andy
DancesWithSUVs
Quoted: 7 Post(s)
I remember riding a bike with 29" tires 45 years ago, 29" is simply the older imperial measurement that used to be in use before 700c became the more common designation.
I also have a bike I ride today that has 700c wheel that has 40mm tires on it, so your second point has no merit either. There are skinnier tires designated 29" and fatter tires designated 700c, there is overlap in the sizes and widths.
Agreed. See the second paragraph in the above quote. 2"+ 700c tires should be the only tires designated 29er,everything else is just marketing hype. When I bought my '08 Novato,it was between that and the Muirwoods 29'r. The Muirwoods was called a 29er,but came with either 40s or 42s and would def not fit 2" knobbies.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
Bikes: 2015 Giant Roam 2 Hybrid
Quoted: 91 Post(s)
Liked 6 Times
Tire Sizing Systems
A guy I know was frustrated that the bike shop would not sell him tubes for his 29" tires, they were "only made for 700c's" was their excuse. When I explained that 29" and 700c were the same thing and he just needed to make sure the stem and width range were right he got mad and stormed off to the BS to "give them what for". So the ignorance is everywhere.
So generally 29" tires refers to older bikes using the imperial measurement or to newer bikes with wider tires, but not always! Just match the stem type and width and you should be good.
Wouldn't it be wonderful if they just got rid of the marketing hype and stuck to designations that made sense?
I've never seen a tube, tire, rim or wheel that didn't have it clearly marked.
Bikes: 89 Raleigh Technium PRE, 92 SP 1000 ti, '09 Team Pro, 72 International, 63 Hercules 3-spd, '81 Vitus 979, 2 Kabuki Submariners, 2 C. Itoh Submariners, Gary Fisher Big Sur, Skyway 3-spd, Robin Hood w/ S-A IGH 5 speed.
So what do the inch designations refer to anyway? 700 mm is about 27 1/2 inches. Does it refer to the OD of the tire? OD of the flange of the rim and the 700mm is the diameter of the bead?
Antique car tires (early 30s and older)are sized by OD. Modern car tires are sized by rim diameter.
Anyone have the knowledge?
The 29" designation refers to the outside diameter of a 700c tire that is about 29" (xx-622). The 622 is the rim size. The xx number (width) will be relatively large 60mm+ for a 29" tire. 26" Big Apples in 60-559 (aka 26" x 2.35") have about a 27.5" outside diameter. It's all a little confusing, unfortunately.
Ultimately, you need to match the tire to the rim and to the frame and fork. Also, you need to match the inside diameter of the rim to the tire width. If the tire is too wide for the rim, the rim will fail or the tire will feel squirmy, and if the tire is too narrow for the rim, the tire will not seat properly.
Bikes: 2017 Soma Valhallen, 1992 Trek 820, 2011 Tern Joe C21, 2012 Tern Link D8, 20?? Takara Kabuto
Quoted: 10 Post(s)
As alan s referenced earlier (and just elaborated on), details can be found at https://sheldonbrown.com/tire-sizing.html. To summarize, 700C was from French sizing, originally based on the nominal diameter in mm, including a specific size tire (C was a width designation, there were also A, B, and D). It also notes that 29" is just a marketing term for some wide 700C tires (mostly MTB, presumably based on the approximate outsize diameter of the tire). As most have mentioned, ISO is the most clear, it consists of two numbers, the inner rim width in mm, and the bead seat diameter of the rim. When in doubt, check ISO size.
Quoted: 10 Post(s)
Sorry for the misunderstanding, the linked article answers this in much detail. Basically, the general answer to your question is, yes, the inch sizing (as well as the older metric sizing) was historically based on the outside tire diameter, not bead diameter or any part of rim size.
Bikes: 2008 Dawes Haymaker 20XX Leader LD515 TotoCycling Road Bike
Quoted: 27 Post(s)
Liked 32 Times
My 700c wheels are 19mm wide where as my "29er" wheels are 25mm wide, otherwise same diameter without tires mounted.
Bikes: Scott Spark 30, Scott Sportster 10,Chesini X-Uno, Miyata Century, Cannondale SuperSix
Quoted: 16 Post(s)
And my "29er" wheels are 19mm wide...
Ragnar
Ragnar
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
My 622mm wheel rims are marked as 19mm wide on one bike and 21mm on the other. Both have 47-622mm Marathon tires mounted.
Would a 700c wheel fit on a 26 inch wheeled bike?
- Andy
- Andy
Quoted: 52 Post(s)
Liked 17 Times
If there is enough clearance, then yes. Rim brakes would be a problem though as they probably wouldn't line up.
There's also 650B which falls in between and is gaining some popularity on off road bikes. Used to the see 650c on Tri bikes.
Some people will put 650B wheels on a standard road bike as a way to get additional clearance for wider tires, but you will also need to replace the brake calipers.
DancesWithSUVs
Quoted: 7 Post(s)
Depends on the frame/fork. My Bad Boy Ultras were designed to swap between 700c and 26" to go from street riding to off road. Just for fun I put a set of 700's on my old 1x1 and they fit just fine.
I'm going to have to do some research on this, because i'd love to put 700c wheels on my uptown. I think it'd give me better high end ratio speed without doing much to the low end. Catch is, i can't use discs on this frame, and the hubs are what they are....
- Andy
Quoted: 16 Post(s)
Alternatives are still made and sold though:
Xtracycle 26" to 700c Brake Post Conversion Adapter | Bike Trailer
Ragnar
DancesWithSUVs
Quoted: 7 Post(s)
Sheldon Brown's Bicycle Gear Calculator
The thing about IGH's is you can only raise or lower the entire gear range. On a derailleur bike,swapping an 11-28 cassette for an 11-34 will lower your granny gear but leave the high untouched. Swapping your big ring for a bigger one will do the opposite. But you can't change the gears inside a hub,you can only swap the rings and cogs to move the range up or down.
Quoted: 4227 Post(s)
Liked 2,488 Times
It depends on how much room there is in the frame and fork...My Surly 1x1 has a lot of room and I can easily fit 700x42 tires and full fenders...My other MTB can only fit 700x32 plus full fenders. Both bikes have disc brakes so switching wheels is not a problem.
Thanks for all the replies & info.
Sadly i looked today, and there is definitely not enough room. The whole thing is set up for 26 inch wheels. I would need a new fork with proper spacing, and the rear rack mounts (not moveable) only give enough clearance for the fender.
Happily, though, i can say that my plan to put a fatter tire on the back is still possible. New wheels are definitely still a go once i get the money together, but they are gonna have to be 26 inchers.
- Andy
- Andy
