modern cycling shoes and toeclips and cleats
my name is Jim
So I have been just swapping my Look Keo compatible pedals from bike to bike. I have two sets so it hasn't been too much of a hassle. But this year I wanted to go more retro I guess and use real correct vintage pedals on my vintage bikes. After all I rode thousands of miles with clips and cleats so why not do it again? Then no more pedal swapping.
So I ordered a set of Look compatible cleats from Yellow Jersey that are supposed to screw into the Look holes on modern bike shoes and thought problem solved.
But problem not solved. Modern cycling shoes, Diadora Aerospeed comps in this case, have thick plastic or carbon soles and almost all have extensions on the sole at the toe to allow easier walking and prevent damage to modern cleats. But that seams to mean that they don't fit into vintage toe clips. See picture. Even with XXL toe clips they really don't fit into the end of the toe clip.
Plus the Yellow Jersey clips don't seem to be able to be positioned for correct placement of the ball of my foot over the pedal shaft no matter which way I mount them. And the cleat slot is way to tight for any vintage Campy pedal. I would have to file them out.
Are there others out there using modern cycling shoes with vintage pedals, clips and some kind of cleat?
Flickr Albums
ebay: cicloclassico
70 Pogliaghi ItalCorse, 72 De Rosa, 72 Masi Gran Criterium, 75 Masi Gran Criterium, 77 Melton, 79 Bianchi Super Leggera, 79 Gios Super Record, 81 Picchio Special, 82 Guerciotti Super Record, 82 Colnago Profil CX, 83 Colnago Superissimo, 84 Fuso
Flickr Albums
ebay: cicloclassico
i've never, even in the 80's when you COULD buy clips and cleats, NOT bent my toe clips to fit my toes. they're just another thing you have to tweak to work right. just yank on the things until they fit your toes, and if that doesn't work-- just pinch the things with a pair of channel locks between some shim stock or plywood scraps and bend away.
my name is Jim
Flickr Albums
ebay: cicloclassico
Flickr Albums
ebay: cicloclassico
hm. well honestly-- the only modern shoes i've found that work alright ( or at least the 43's work alright for ME) is bontrager streets. they're pretty narrow toed, and somehow the strap drops between velcro straps. actually i looked for forever to find new modern shoes that worked, and finally gave in for some shimano a520s.. and i'm kinda glad i did.. but i did nurse an old pair of diamants along for a LONG time...
you could also try vittoria 1976es. or dromartis, which are super cool, but already mentioned. but they? yep. SUPER cool.
PanGalacticGargleBlaster
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
Quoted: 20 Post(s)
Liked 8 Times
I ride strictly with toe clips and straps and had the same issue. I've had success with "driving" or "motorsport" shoes. Adidas and Puma both make some.
Right now I rock Saucony track (running) shoes...there's like nothing to them, they have a very slim profile which is what you want for toe clips.
In cool weather I've got a pair of leather Hush Puppies that are awesome.
My best successes have been when I rode my bike to the shoe store and just brought it in with me and tried on shoes with my bike. It makes sense.
--Don't Panic.
--Don't Panic.
Vain, But Lacking Talent
There must be something I'm missing here, but if you are using a clipless system, what is the point of the toe clips? Are we talking about a classic style clip-in pedal that doesn't work the same as modern pedals?
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12843 Post(s)
Liked 7,763 Times
Quoted: 83 Post(s)
Liked 13 Times
I had a worn out pair of modern Sidi's that the velcro straps no longer worked. I had my buddy at the shoe repair shop cut off the straps, punch lace holes and install eyelets. Then I used the Yellow Jersey cleat that's a slotted style but drilled for the 3-hole "Look" pattern. I figured this was as good as you could get a modern shoe altered to use with clips and straps. But I found that even without the velcro straps they are still way to thick, and nearly impossible to get into the pedal without reaching down and using your hand to hold the pedal. And with the rounded shape of the sole under the toe they do not really want to sit right on the pedal. I rode them a few times and then gave up. Back to the Detto's with no socks.
Noob
Bikes: '86 Schwinn Paramount
Liked 5 Times
MKS makes some 'deep' toe clips that have a larger toe section. It has a more boxy square profile compared to the toe clips in your pics.
my name is Jim
I am coming to the conclusion that it really isn't going to work right, as Otis suggests. The Dromartis are fantastic but way expensive. Either find some vintage shoes or look at continuing to use modern pedals for actual riding. I don't think I can ride without the support of a real cycling shoe or something with a very stiff sole.
Flickr Albums
ebay: cicloclassico
Flickr Albums
ebay: cicloclassico
Bikes: everywhere
Liked 7,763 Times
It won't be pretty but some plastic MTB clips are one option. If they fit my hiking boots OK, they should work fine for your thick-soled cycling shoes.
Maybe a shot at the Track Cycling or SS/FG subforums would find some slotted cleats experts that have other clip ideas.
Bowie
Classic & Vintage
8
06-27-10 08:02 PM
