alfine 8 wheelsets or lbs build?
Hello all,
I'm planning on building up a cross check with an alfine 8 igh. I'm wondering if anyone knows the best / cheapest way to buy the wheels. Am I best going into my local bike shop and having them build up the wheels for me, or am I best buying a full wheelset off the internet? If it's the latter, would this on eBay be a good deal https://pages.ebay.com/link/?nav=item...d=231103011863 ? It has a dynamo on the front as well, which is something I'd like.
Many thanks! Jack
Many thanks! Jack
aka Phil Jungels
A lot better deal than you would get around here - just have it checked for true and tension, and relieved, before you mount them. You would pay more than that for the rear here!
Are they disc capable? Ahhhh, I now see that they are disc compatible.
Quoted: 2026 Post(s)
Liked 1,096 Times
The e-bay listing says nothing about the rim make or spoke type. Also, those are disc capable hubs so be sure the rims will work with caliper brakes if that's what you have. I'd want more info from the e-bay seller before buying them.
If your LBs has a competent wheel builder (many don't) I'd find out what they would charge for the same build or if they have a good source for prebuilt wheels.
Liked 1,096 Times
Are you going to to the install or have a shop do it? If having a shop do it, have them price things out for wheel build and them sourcing parts + install vs. you providing parts + their install labor. Buying online will certainly be cheaper if you are doing the work yourself; if you are having a shop do the work, it might come out very close or close enough to go with the shop pricing.
Into what kind of bike are you installing these wheels? Vertical dropout -- "Safety eyes 8L / 8R (green / blue)" -- yes?
Will you be buying lights, too?
Once you get everything tallied up, you may find the shop as cheap or certainly competitive, vs buying online and having a shop do the install. Figure shipping into the cost of anything you are ordering, your familiarity with bike mechanics, and the decision should be more clear.
aka Phil Jungels
Specs say rims are CNC machined, so assumption is they are rim brake compatible, also..
Yes, I'm pretty sure those rims are compatible with canti brakes.
Mconclonx - I am planning to do the work myself. I'm somewhat of an amateur, but I've stripped and rebuilt a couple of bikes in my time, so feel fairly confident that I'll not have much issue building this.
The frame I'm going to build up is a surly cross check and has horizontal drop outs so should fit fine.
I agree that if I was to offer the whole build to my lbs I might stand to save money, but I'll be buying parts as and when they come available to me (i.e. When I find more money / stuff on eBay), so I'm almost certainly best off building it myself.
My main point was weather the wheels alone were best built by a local wheelbuilder, or ordered complete, as per the ones in the link.
Thanks again, Jack.
Thanks again, Jack.
Quoted: 1438 Post(s)
Liked 1,092 Times
The only questionable item are the spokes as I don't recognize the maker. Anyone know who they are?
"Nirosta" is not a brand of spokes, it is a German acronym for NIchtROstender STAhl, meaning "non-rusting steel"; a product of ThyssenKrupp AG, it is the material of which the crown of the Chrysler Building is constructed. One might infer that it is of reasonably good quality.
Liked 1,096 Times
Thanks again, Jack.
Thanks again, Jack.
"Best built" depends on who built them or at least did QC for the wheels online, vs experience and skill of whoever would build them for you at a local shop.
Liked 1,092 Times
You state that your frame has horizontal dropouts. The antirotation washers ("safety eyes" in the listing) are 8L and 8R which are for vertical dropouts. Per this document https://techdocs.shimano.com/media/te...9830638091.pdf
you will need either 5L/5R or 7L/7R. You will need to add these to your shopping list.
As for those spokes, they're probably fine. We get Wheelsmith here and I bet nobody across the pond knows them.
