Spraypainting my CREATE: The result!
It turned out much better than I had expected.
https://imgur.com/a/Ng24w
Even if the paint will go to **** in a week, It'll look better than it did before haha!
I used Henx paint btw, if anyone's interested.
Do's and dont's for others who might want to do this
DO:
- Put down a large piece of plastic
- Put down newspapers when you're going to spray
- Wait between layers of paint
- Keep distance from bike and spraycan
- Wait at least 24h before riding the newly sprayed bike, even after the drying period. I waited 36 hours myself
- Buy a paint mask, otherwise you'll get lightheaded really quickly
- Spray in a well ventilated, but not too windy area
DONT:
- Scrap off all your paint, looking back on the project I might aswell have painted over the paint I already had on there. It was a lot of work to scrap off all the paint, even after applying paint stripper.
- Buy a CREATE bike.
- Buy a bike you don't like the colors off
DO:
DONT:
Bikes: 2008 Surly Cross Check, 2010 Fuji Track Comp
This… is horrifying.
To the OP, it looks better, but the other guys here are right. You probably damaged your bearings by not taking everything apart first. It's a relatively cheap bike, though, so ride it until it falls apart* and try to learn basic maintenance along the way. When it eventually does die you can upgrade.
*) No, I'm not saying the damaged bearings will make it fall apart, they'll probably just grind a bit and not roll as smoothly.
Bikes: Fiori Fixie powder blue w/ granny bars
Buddy of mine went kind of insane when he was riding a Honda CB400 across the USA back i the late 80s. Somewhere in TX he decided it would be awesome to paint the bike black and hit everything with rattlecan... paying special attention to the cooling fins... bike died somewhere in Louisiana...
But the only replies were HUEHUE LMGTFY and HUE HUE CLOWN BIKE and so on.
If only people would actually tell that before hand, instead of first being a dickass about it and then afterwards crying about it
Whatever, I just wanted to post this to let them know I did it anyway, and now I'm completely and officially done with this ****ty ass forum. Never has there been such a terrible community before, instead of helping beginners they just **** on them.
I'll check on this thread now and then but nothing more than that. Cya
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Well, it still works just as fine as it did before, besides I did ask those same guys on this forum right here, I'm pretty sure they both replied to it as well, https://www.bikeforums.net/showthread...internet-karma! (take a look at the bottom of the thread especially)
Oh and a couple tips for you if you decide to try this again.. you will need masking tape, cloth for plugging threaded surfaces and you will also have to tape off those areas to prevent overspray into the threads. You may not need to remove all the paint, but you must at least evenly break the gloss all the way around the paint, anodized parts like your rims you will need to strip the anodizing and make sure everythings perfectly clean, you will want more than a piece of plastic to lay down you should want an entire "room" made of plastic that can hold the bike frame, your equipment and yourself as well as being ventilated by at the very least a box fan. Thin even coats with the rattlecan is extra extra important too, as can be wet sanding.. As for drying times.. If you've got the ceiling space you'd be better off throwing that sucker into there for a few weeks to give the paint a real chance to dry and harden as well, always allow drying time between processes IE Priming, Paint, Clearcoat...
Most importantly.. you only paint bare parts.. IE the frameset completely stripped down, or the fork with no crown race installed..
As for this particular sub-forum, I read for awhile before posting so I could get a feel for what kind of behavior to expect. There's a mix of smartasses and helpful smartasses. If you can roll with the punches you can get good advice and information around here.
Now, go ride your bike until it dies, then upgrade.
I don't think a bike message board was needed...perhaps a spray paint message board would have been more useful.
https://www.spacepaintings.com/spraypaintart.html
Hogosha Sekai
It's full of a bunch of dicks just being dicks.
I've tried to ask them for suggestions and how to spraypaint my bike, and all I got was a bunch of Let me Google that for you links and replies stating how terrible my bike looks and that I should throw it in the trash. Well, that might be the reason I am asking you HOW TO SPRAY IT?
I'm done with this forum just because I feel like there's a lot more subs on this forum just like those. Bad influence on my first opinion, so bad that I'm done. See ya and I hope y'all do something about it.
Custom User Title
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Hogosha Sekai
Custom User Title
Custom User Title
