52/36 chainrings?
52/36 chainrings?
Old 06-20-05 | 03:26 PM
squeegy200's Avatar
Bikes: Colnago Altain, Klein Pulse II, Stumpjumper FSR, GT Zaskar LE, Pedalforce RS2
52/36 chainrings?
I inquired a few weeks back about a compact(?) crank used by Ivan Basso on one of the Giro mountain stages. It wasn't a traditional compact crank as the chainrings were 52/36 compared to a compact which has a 50/34
The responses I received is that it was a compact crank but the chainrings were different.
I've not seen 52/36 chainrings anywhere. I've searched a few online retailers and catalogs but to no avail.
Are these chainrings available somewhere that I have not found? Or is this a special custom crankset made for team CSC?
Im currently using a traditional 53/39 but occassionally, I could use one extra gear on extended climbs. I've tried a 50/34 and I don't like loosing the top end.
squeegy200 is offline
Reply
Old 06-20-05 | 03:32 PM
moxfyre's Avatar
cyclist/gearhead/cycli...
Bikes: Homebuilt tourer/commuter, modified-beyond-recognition 1990 Trek 1100, reasonably stock 2002-ish Gary Fisher Hoo Koo E Koo
Sheldon Brown's shop sells chainrings in pretty much every conceivable size... https://www.sheldonbrown.com/harris/chainrings.html
They don't seem to sell 52T chainrings in the 95 mm BCD...
Perhaps what Basso used was a 110 mm BCD crankset? That's a standard size for touring cranks and 52/36 chainrings are available in that size from Sheldon Brown.
moxfyre is offline
Reply
Old 06-20-05 | 08:15 PM
hmai18's Avatar
Cannondale Shill
Bikes: '06 CAAD8, SRAM Rival/Force and fixie of unknown origin
AFAIK, Basso rides on FSA compact rings which have a 110mm BCD and are available in 46/48/50/52 tooth outer rings and 34/36/38 tooth inner rings as listed on the FSA website: https://www.fullspeedahead.com/fly.as...axid=25&pid=67
hmai18 is offline
Reply
Old 06-21-05 | 04:20 AM
20 Anniversary
Many of the pro teams use Specialities-TA rings which are available in just about any tooth count and BCD and are particularly hardwearing.
MichaelW is offline
Reply
Old 06-21-05 | 11:33 AM
Sheldon Brown's Avatar
Gone, but not forgotten
Sheldon Brown Memorial - Titanium
20 Anniversary
Bikes: See: https://sheldonbrown.org/bicycles
There is no 95 mm BCD.
Standard "compact doubles" are 110 BCD except for the oddball Campagnolo system that uses 4 bolts at 110 BCD and one at some other random distance, just to force you to use Campagnolo chainrings.
See: https://harriscyclery.com/110 for 110 BCD chainrings
Sheldon "We've Got 'Em" Brown
Code:
|  One measurement is worth 50 expert opinions    |
|                         --Howard Sutherland     |
Sheldon Brown is offline
Reply
Old 06-21-05 | 11:37 AM
moxfyre's Avatar
Oops, I meant 94 mm BCD.
I was trying to say that you didn't carry any 52/36 chainrings in the 94 mm BCD size. Sorry for the mistake.
moxfyre is offline
Reply
Old 06-21-05 | 01:34 PM
20 Anniversary
We don't stock them, but I believe TA makes them. There's very little call for such sizes, because the 94 BCD is mainly used on mountain bikes, and these don't commonly have sufficient chainstay clearance to allow a 52 to be fitted with a decent chainline.
Sheldon "Glad To Special Order One If You Can Use One" Brown
Code:
|  Give a man a fire, and he will stay warm for a day.        |
|  Set a man on fire, he stays warm for the rest of his life. |
Reply
Old 09-10-11 | 12:38 PM
Bikes: i still have 5 road bikes that i can't get my leg over the top tube, so in 1999 i bought a greenspeed gto trike
36 & 52 tooth chainrings
peugeots & gitanes used come stock with these chainrings, the clusters were 14-26 teeth. between the chainrings was a piece of sheet metal to provide a ramp to aid shifting from the small to large chainring. with the pushrod simplex front derailleurs (design that was kept in production 15 years after it was obsolete), so the upshifts were not lighting fast.
gear freak is offline
Reply
Old 09-11-11 | 02:27 AM
Bikes: 8
I put together a 52-36 combo 20 years ago . the crankset Gippiemme
a special triple, outer ring, a Campag chainring guard. nice, posh , classic and available..
fietsbob is offline
Reply
ducati hyp
Bicycle Mechanics
8
09-27-13 01:37 PM
martytardy
Bicycle Mechanics
10
05-29-13 07:11 PM
jasandalb
Road Cycling
5
07-09-12 09:58 AM
gus6464
Bicycle Mechanics
5
05-09-11 01:17 PM
RiverHills
Road Cycling
16
04-01-11 01:46 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
