Trainer or Rollers
I think you need both if you want to be a good rider. You could get smaller diameter rollers for some resistance.
部門ニ/自転車オタク
Bikes: 2008 Blue T16, 2009 Blue RC8, 2012 Blue Norcross CX, 2016 Blue Axino SL, 2016 Scott Scale, Fixie, Fetish Cycles Road Bike (on the trainer)
I don't know what a trainer does that rollers don't, but I've only owned rollers. I do know some of the obvious things that rollers do that trainers don't - like balance, evening out spin.
I'm obviously a vote for the rollers.
Envision, Energize, Enable
Overacting because I can
Bikes: Merlin Agilis, Trek 1500
I can't ride trainers - just too boring. Beyond the technique benefits, on rollers, your cycling computer works fine because the front wheel is rotating.
I bought a magnetic resistance unit from Sportscrafters (good rollers). It's not as adjustable as it makes out, but it definitely makes riding the rollers pretty tough. So I get spin training and resistance training in one piece of equipement.
“Courage is going from failure to failure without losing enthusiasm." (Churchill)
"I am a courageous cyclist." (SpongeDad)
Bikes: Yeti ASRc, Focus Raven 29er, Flyxii FR316
I don't know about your rollers, but mine can give me more than enough resistance to do hard workouts on. I can do an LT workout very easily on mine. Sportcrafters, to be brand specific. Granted, mine came with the 5 setting mag resistance unit...
Bikes: Cannondale EVO, CAAD9, Giant cross bike.
On a trainer, you can do more power training. It's more difficult to simulate a long climb or a sprint (standing or out of the saddle) on a set of rollers. And, in the case of a Fluid2, you can really produce big power...
Rollers are great for smoothing out your pedal stroke, improving bike handling, etc...
If you are a crit racer and want to simulate final sprints, or want to do extended standing climbs, that's really not what rollers are for. In other words, you'll get stronger or more powerful, faster, on a trainer. You can develop a smoother stroke and better balance on rollers.
Really, if you can, having both is the best.
I vote for rollers......
I don't race....or sprint even...
This winter I will use my rollers to work in increasing my average cadence.
I should still be able to get out of the roads for all but the coldest and/or snowiest weekends to keep my climbing legs in decent shape.
I've never trusted that having my bike hooked to a trainer and then standing and rocking the bike side to side would not cause damage and/or unusual stress on the frame....especially with carbon seat stays......
I know that statement will draw some fire but that's how I feel.
If you only have one indoor trainer I think rollers are best all around.
If you can have more than one, more power to you.....
Ca-na-da?
Bikes: none at the moment
This has always raised a fundamental question for me.
Rollers with a mag unit can provide just as much resistance as most trainner's. Free motion rollers enable you to ride out of the saddle and even sprint. Therefore the only advantage that's left to trainners is undistracted power trainning allowing for maximal force to be acheived since you don't have to divert energy to worrying about controlling the bike.
The fundamental question is: Should you be getting more powerful if you can't handle the bike with the power you can generate now?
Rollers have always made sense to me, although it gets tricky to control my bike on a 16" tube when doing maximal L5, L6 & L7 intervals, it's still something you have to learn to do. Your bike isn't going to bolted to a trainner during a race especially during a final sprint when bike control is critical.
I find sprinting on my free motion rollers very informative, I immediately noticed that i had to much weight shifted over my front wheel and not enough over my rear, fixing this I immediatly noticed an increase in sprinting power.
And of course rollers increase your balance which alot of cyclist's think they have, until they try to ride a set of rollers, especially with no hands, or do a track stand out on the road.
NOTE:I didn't have my mag unit attached at the time of this video but i do now and it works fine with the whole setup.
Wow, every time you post that video it motivates me to continue trying to learn these rollers (been having issues getting used to them). To be fair though I haven't really given sufficient time yet either. Weather is still too nice outside.
-D
-D
That's the coolest rollers video I have ever seen !!!
You rock !!
What is that rack setup you have your rollers bungeed to ?
Where can I get plans for one ?
What is the premise behind the concept ??
That is so cool !!
I must build myself a set.
Thanks for the inspiration !!!
J.
you can go way harder on a trainer than on rollers. you can also
safely test extreme high cadence allowing your form to take a
back seat while you probe you physical limits (first time you
spin 198 cadence is an eye-opener. I lose 'roller form' above 160)
rollers teach peloton kung-fu and technique, which is crucial
to ride in fast groups. they are only hard the first few times, then
it become easier, yet you can never lose focus. you can work up
to no-handed water bottle swapping then one legged spinning
on rollers, no handed, then I'd say you might have good form to
stay in a peloton at speed (tho' shoulder and handlebar bumping
is something you can only learn on the road) don't try this at home
folks...it is fun to test yerself but not necessary to become a
cycling guru (which i am not)
stationaries can make you see stars and come close to passing out
which you cannot always do on rollers without coming off them by accident.
you can come close, but no dice on the passing out part. which is part of extreme
anaerobic training if you want to test your limits and train your body to
hit that spot, and back off and recover to BLT levels without having
to stop. no one needs to pass out on a bike, but it sure helps to come close to it
then you can really meter yourself in real world hammering sessions and not
blow up. last time I passed out on the road, it sucked. I fell off and it hurt.
on the stationary, hitting 209bpm and the tunnel vision started,
I just leaned over the bars and took a 5 second forced nap, then
continued to spin easy. on rollers I'd have smashed up my room
survey says, get both.
rollers and a stationary setup. for the unique
aspects of each, and it is never boring when you swap out spinervals
dvd's and switch up trainers ....it doubles the action during the winter
Cardiac Case
Bikes: Trek, Cannondale, Litespeed, Lynskey
KrazyDerek -
The roller setup ROCKS!!!
Where'd you get the idea to make a horizontal float for it? That's great! I'm gonna have to build one of those!
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
you know I've always been a big proponent of Rollers,
and have resisted these newfangled rollers, however
after seeing that vid I may have to give these free motion
rollers a longer second look.
marty
marty
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
marty
marty
I can see why Derik built his setup.
They have them here but they're not cheap $800
https://www.insideride.com/index.php?...tpage&Itemid=1
Some more cool videos on there site too....
Check out Deriks thread on how he built his set:
https://www.bikeforums.net/showthread...motion+rollers
Derik,
I noticed one thing about your setup....
Your rollers were not folding...
Could you do your setup with folding rollers ?
Would the weight of the rider & bike be enough to keep the rollers from snapping open like a mouse trap !!
Can you still buy non-folding rollers ?
Why did you choose to attach the bungee cord along the top of the roller frame ?
Couldn't you have just drilled a few holes on the sides of the roller frame and used the S hook to attach there ? A couple different holes would allow you to easily fine tune tension of the overall frame ?
Just curious...
Just curious...
I recently bought rollers and have tried them a few times. I'm getting the hang of it little by little. They work your balance and cadence nicely and if you want resistance, then just shift up. I wish I had a resistance trainer though.
Now if I went with the resistance trainer, I'd probably be wishing that I had the rollers!
So I guess I'll be getting the trainer too in the near future to put my mind at ease.
Originally Posted by Fantik
When I try to stand up on my rollers, I always drive off the front, what am I doing wrong?
You're leaning too far forward....
It's not noticeable on the road but you're rollers know...
I have my front roller directly beneath the hub... thats right, right?
This would give you a little more stability....but move the hub back too much and you'll be likely to pop off the back of your rollers and/or your steering will become twitchy....
Used to be a climber..
Bikes: 2021 Merlin Sandstone, 2016 Ridley Fenix SL, 2020 Trek Emonda ALR (rim brake), Trek Roscoe 9
If you have to get one or the other....get a good fluid trainer (Kurt Kinetic, CycleOps). Gives you more options to train with. If you need to work on balance, cadence, bike handling, etc...that's what pavement/roads are for. If you need to focus on your fitness, a trainer is the better choice, as noted by others as well.
2016 Trek 520 (54cm) touring bike for sale - never ridden. Message me for photos/details.
We disagree ???
