Oxalic acid question
Death fork? Naaaah!!
Bikes: Seriously downsizing.
I went to the local Sherwin-Williams store this afternoon and left ten bucks lighter clutching a 12 ounce tub of oxalic acid. The label has lots on instructions on mixing it up as a wood bleach, but what's the dope on making it a rust remover?
Top
Top
Depends on how much water you're using.
I use a very scientific method - I fill a metal pie tin with hot water, and add pinch or two (literally - a thumb/forefinger pinch). Stir it a bit to dissolve, and add the rusty bits. Then let it sit and occasionally check it for progress. I've done soaks for a couple of hours for lightly rusted stuff, and for a couple of days to take care of really rusty stuff. I tend to err on the weak side, just because.....
I had some cable clips with light surface rust that came out gleaming after about a 2 hour soak. Conversely, I had a chain that was dry and bright orange - after a 2 day soak it looked and worked like new.
"Love is not the dying moan of a distant violin, it’s the triumphant twang of a bedspring."
S. J. Perelman
S. J. Perelman
Originally Posted by Old Fat Guy
Mix it in warm water until the solution is saturated (Crystals no longer dissolve). If you want it weaker, add water from there. Always use warm water.
S. J. Perelman
S. J. Perelman
A Son of the Cape Fear
Bikes: '73 Schwinn Super Sport, '74 Schwinn Continental, '75 Raleigh Super Course Mark II, '99 Giant Upland
Does anyone have experience with oxalic acid and plated parts? I'm thinking about nickel and chrome plating, primarily.
I own a band instrument repair shop, and my 79 year old repair tech dips some parts in Lysol Toilet Bowl Cleaner. I'm wondering if oxalic acid is the active ingredient in that. Does anyone know?
Almost all the parts I've done have been chrome plated - cable clips, chain ring bolts, binder bolts, headset cups, etc. Works great.
You do have to clean/degrease the parts first, though. Oxalic acid needs to touch the bare surface, and will not work though grime or grease.
S. J. Perelman
S. J. Perelman
There are two sets of instructions on the container: 3 oz per quart to BLEACH wood and 3 oz per gallon for BRIGHTING wood decking. Do I use either of these or some other dilution?
Top
Top
Top
Top
Oxalic acid is a very mild organic acid. It has long been used to remove rust stains from fabric and will not damage fabrics. It is poisonous so wash your hands after using it or use gloves. I'll bet if you read the ingredients in your Tidy Bowl, you will probably see EDTA (ethylenediaminetetraacetic acid or one of its salts). EDTA is non-toxic and is also used in foods like salad dressing. It's great for dissolving soap scum and dried minerals like calcium and magnesium but I'm not sure about removing rust (iron oxide) from parts. 10 bucks for less than a pound seems like a Tidy profit for the store.
Vegas Triker, chemist
Top
Top
Lemond Zurich, Cinelli Hobootleg Geo, ICan gravel bike, Tifosi Rostra, Specialized vado turbo
Chrome Freak
Bikes: 71 Chrome Paramount P13-9, 73 Opaque Blue Paramount P15, 74 Blue Mink Raleigh Pro, 91 Waterford Paramount, Holland Titanium x2
I used it on a freewheel and it went from this:
To this:
I did disassemble it first, though.
To this:
1971 Paramount P-13 Chrome
1973 Paramount P-15 Opaque Blue
1974 Raleigh Professional Blue Mink
1991 Waterford Paramount
Holland Titanium Dura Ace Group
Holland Titanium Ultegra Triple Group
DON"T use it on zinc or cad plating, the acid will eat the plating and leave you with dull metal. The tiny bubbles coming off the plating during the process are pretty cool though.
Here are before and after pictures of the fork on a Rossin I picked up:
https://www.gallery.unvoiced.com/main.php
Originally Posted by raverson
I am going to have to find a local source. The Chemistry Store would cost $32 for a minimum order and S&H.
Originally Posted by McDave
Yeah it ended up costing me $29 for a 7lb pail delivered to Texas but I'm so far out in the sticks I don't have any other options. That's why I don't mix it as strong as Old Fat Guy does, and at the rate I'm using it it should last a couple or three years.
Here is the directions off my box of OA:
Directions: Rust Stain Remover
Wet the stain and sprinkle PURE OXALIC ACID on it. Rub with a wet cloth, sponge or brush until stain has vanished. Rinse thoroughly and wipe dry. For more stubborn stains, make a paste of PURE OXALIC ACID and water, apply to the stain and allow to stand a minute or two before rubbing. Rinse and wipe dry. To whiten iron stained clothes, presoak using 4 tablespoons of PURE OXALIC ACID in 2 gallons of water. PURE OXALIC ACID can also be sprinkled in the toilet bowl and other porcelain surfaces to clean embedded rust and hard water stains.
Source:
https://www.empireblended.com/enginee...xalicacid.html
Like I said above, a paste made with Zud cleanser and OA, rubbed or steel wooled onto the surface works in a few minutes.
Borax will neutralize the OA, if needed.
I thought the fork on the Rossin was junk, but as you can see in my earlier post, a bit of elbow grease and OA works wonders.
Source:
If I can find a cheap supply, I figure I won't have to worry about using it so sparingly.
OFG brings up a good point - using Borax to neutralize the acid when finished treating. I had a case where treating cheap shorty fenders the acid seemed to continue working even after I rinsed and polished. I noticed a couple weeks later that it left dull specks down to the steel where the rust spots had been. I now rotate the old box of Baking Soda out of the fridge into my OA rinse baths to ensure the acid stops working.
