mercier kilo and flite 100 the same?
live free or die trying
Bikes: bianchi pista workhorse, cannondale r1000, mountain bike fixed conversion
i was looking at some flites on velospace today....it seems to me as though the headtube angle is different, so they can't be the same frame.....anyone have any data to back this up? i could have just been tricked by camera angles.
okay, yeah, i'd heard they were "the same", but looking at some bikes today, it didn't seem that was true. i noticed a way dif. head tube angle.
Bikes: Kilo TT and a Stumpjumper fsr comp
were they both the same size? could be a size difference the 60cm or whatever the biggest one is looks different than my 53cm
hmmm, i hadn't taken that into consideration. i'd think angles wouild stay relatively the samein dif. sizes, though.
Are we not men?
I think the geo is different, but everything else is the same. Crowned fork, tubing, eyelets etc.
This is my post from another similar thread
Here is the Kilo TT geo sheet: https://www.cyclesmercier.com/geometry_tt.html
Here is the KHS Flite geo sheet: https://www.khsbicycles.com/Images/Ge...7-geo-road.jpg
Now compare say a 57cm frame
KHS Flite 100 (57):
HT angle: 75*
ST angle: 74*
Top Tube: 575mm
Chainstay: 401mm
Fork Offset: 28 mm
Mercier Kilo TT (57):
HT angle: 73.5*
ST angle: 74*
Top Tube: 590mm
Chainstay: 405mm
Fork Offset: 40 mm
Maybe they are made by the same people, maybe they are made of the same material, but I am sorry these are not the same frames.
KHS Flite 100 (57):
HT angle: 75*
ST angle: 74*
Top Tube: 575mm
Chainstay: 401mm
Fork Offset: 28 mm
HT angle: 73.5*
ST angle: 74*
Top Tube: 590mm
Chainstay: 405mm
Fork Offset: 40 mm
slot machine
Bikes: fuji and a Meteor
Dang Neil! That's an impressive report, but you are forgetting one key variable. The Kilo in your post is the BLUE one and you are trying to compare that to a RED Flite! What's with that?
after careful analysis, my professional consensus is that icknayvon can't skid :O
Are we not men?
I wouldn't be surprised if the geometry on those sites is wrong. It makes a lot more sense for the factory to build these bikes from the same jig (a sort of table they use to lay out tubing to weld.)
They are the same frames and even forks...the ONLY difference is that the Kilo has the fork threaded and the KHS does not. Why? The dude that runs BD likes the 1" stem look. He's admitted so. The frames are identical otherwise. Spicers are as well.
Also, both frames come with the same wheels, tires, pedals, handlebars, both claim to be from Reynolds 520, and both feature the odd size jump from 53cm to 57cm.
Someone needs to email Mike from Bikes Direct and get him to publish updated specs on the Kilo.
