Fueling body
Fueling body
I asked a question about Energy gel yesterday, and then i bought 2 energy gels from PowerBar.
It seemed like buying 24 pack of energy gel is a waste of money cause if i go for 4 hrs ride, i'll be drinking about 4 energy gels.
So a guy who works at GNC, recommended me a jar of powder. It contains carbohydrate, sodium, no protein, and no potassium.
Do you recommend me taking a 24oz water with the powder mixed when i'm cycling??
Wouldn't it be better if the powder contains potassium?
For 4 hr rides, I bring 3 bottles, each loaded with 1 cup of maltodextrin - I buy it bulk at $56/50lbs shipped from Honeyville. Gives 300-400 cals/bottle, and it works great - I'm not even hungry after the ride, and I do mostly big mountain road climbs. For longer rides or hotter days, you will need access to more water than 3 bottles and may have to bring some powder (or food) for the 4+hr mark.
I think "Carbo Gain" or something like that is a big tube for about $2.50/lbs of pure maltodextrin - same as the bulk stuff, just about 10 lbs worth.
so if i put a cup of "carbogain" in my 24oz waterbottle, then do i just drink it like i drink water during the ride?
my fuel for longer rides: banana (potassium), half a ham or turkey and cheese sandwich (carbs and protein), handful of M&Ms for quick energy. on a nice day water works and when it is hot a waterbottle 1/2 full of OJ and 1/2 full of water for a nice "sports drink"
after workout: coupla glasses of 2% chocolate milk and a nice meal with a big salad, veggies, and small protein.
all of the gel stuff is just a shot of flavored chemicals and processed goo.
make sure there is food in your fuel.
Bikes: Specialized Allez, Specialized Sirrus
As for the type of product to use, you need to find out what works best for your body. I can't go on liquids alone and need to eat solid food on long rides. Try different things and see what you like.
Too Fat for This Sport
Bikes: 2011 Cannondale Supersix
I seem to consume way too much water on my rides. I used to go 25mi. on one 24oz bottle of water. Now since I got (2) cages and bottles I go through both bottles of water. I understand the tempature is now 30+ degrees hotter than when I first started riding, I don't know If I truly need water or if I need fuel.
I guess when I'm hurting and I am struggling to keep pace its just easier to reach for the bottle and take a sip, Its almost sub-conscious.
Im going to try mixing fuel with my water. Maybe this will help me from finishing my water source before I finish my rides.
Fred at large
You should check the label on whatever mix powder you're using. Most have high concentrations of vitamin C and citric acid in them. If you drink too much, you can have problems just as if you ate too much real fruit at once. Also, high vitamin C and citric acid levels means that if you eat fruit (or a powerbar) you could wind up with stomach problems.
I think Japhy's post sums it up - make sure that there is food in your fuel.
How are the mini cliff bars as a mean for fuel? *attachment*
It has 23 vitamins and minerals, but it only has 100 calories per bar.
I assume I need high calorie fuel on a ride. I burn a little more than 1000 calories an hour at my body weight. I weigh myself before a ride. Usually when I get home after a 40-50mi. ride I weigh 3-4 lbs less.
Even though I consume 3lbs. of water + 3 mini cliff bars.
I understand the 3500cal per 1lb of fat. I really dont understand where I loose the weight, because I do not believe I sweat that much, however I really dont worry too much as long as I lose the weight.
