Jamis Renegade owners
#401
I even put half of the spacers on the top to lower the handlebar a bit.
I haven't yet done very long rides but my frequently 30/40 km rides don't give me any pain (shoulders, back etc.);
my body seems to be quite happy with the geometry.
But well, size is always a personal thing, perhaps you can try out the 58cm frame somewhere.
#402
For those with steel frames, running 650b wheels/tires, what tires you are you running, what is their actual width and how much rear chainstay clearance do you have?
I'm a little dissapointed that the 650 x 48mm gravel kings, which measure out to 50mm (on my 22mm inner width rim), only leave ~2mm of clearance on each side. I know the max tire clearance is 47mm, but even at 47mm it would only leave 3-4mm of clearance on each side which is well below what I thought manufacturers use for determining max tire size (i thought they used 6mm). FYI I have 2019 Escapade frameset.
#403
Quoted: 82 Post(s)
Liked 8 Times
![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
https://gravelbikes.cc/tests/the-big...700x50c-tires/
Likes For sweetspot:
#404
Sunshine
Quoted: 11104 Post(s)
Liked 7,712 Times
To find out more and see the pictures please visit my website ![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
I have no idea why this practice is allowed on the forums since it drives away traffic, but to each their own.
#405
Quoted: 82 Post(s)
Liked 8 Times
Below you will find the pictures of my bike with 700x50c tire. As you can see it was a really tight fit and worked only after I piled of a fender mount near the bottom bracket and only at 20 psi because when I infalted the tire to 30 psi it started to rub my carbon fork. I managed to take all the measurement I needed but at the price of a slightly wiped paint on my fork.
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1538/50_b7e2b0c0fe807cc36171ee9d505bd3c4992ce47a.jpg)
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/img_20190803_120850_fd5a13fe963ee54bff9dba1fb47113bb0846206d.jpg)
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/img_20190803_121225_1710da7372a3bf48cc6b1ad4b2a8f1776e20e82a.jpg)
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/img_20190803_120908_8cfea91c408f6d524b2cabb80f0a5ce89fd39dc8.jpg)
#406
I wrote Jamis customer support regarding tire clearance and they confirmed that 3-4mm is expected at the max tire size, therefore going over that will leave less. :/
#407
Could anyone tell me the rear spacing on 2018 expat also does anyone have a stock 650b wheelset they’d wanna swap for a 700c wheelset ?
#408
Quoted: 1874 Post(s)
Liked 698 Times
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
#409
This one? https://bikepacking.com/news/2018-jamis-renegade-expat/
Specs are in there.
Specs are in there.
Likes For valve_timing:
#410
Quoted: 5 Post(s)
I've got a 2018 Jamis Renegade Exploit.
Right now I primarily use it for commuting, but I plan on taking it to some gravel trails and bike paths and towing my son around in a bike trailer.
Questions:
Fenders: I want to get some fenders, but am at a loss for recommendations. I've seen mud butlers posted in this thread, but the rear fender looks like it doesn't go far enough around the back of the rear tire. My concern isn't for me, but for my son in the trailer. I've heard that if you don't have an adequate fender system, your kids will end up eating dust for most of the ride, so I'd like to avoid that if possible!
New wheels: I have the stock Clements set up tubeless and they're ok, but man do they feel sluggish on pavement. I'm not sure if it's the rim or the tire. I've got some Panaracer GravelKing 38 slicks coming in so I plan on mounting those, but have been toying with the idea of getting some new rims. Alloy is fine-keeping in mind primary use is for commuting and hitting potholes (I'm 170 pounds), and secondary use will be bike trails with the kiddo-any recommendations? I'd like to keep it under $500 for a new wheelset.
Thanks for any advice you can offer!
Questions:
#411
Liked 698 Times
Questions:
Questions:
2019 Salsa Warbird
2019 Salsa Warbird
#412
Quoted: 5 Post(s)
interesting about the wheels. I figured newer ones would at least be lighter and maybe easier to fit tubeless to-the i23’s were kind of a pain.
#413
Questions:
Questions:
Have never used them but Mason Hunt wheels seem to be a popular choice for budget wheelsets at about $380. For $500 you can get a custom wheelset from Colorado Cyclist with DT Swiss 350 hubs and R500/R470 rims which is what I'll likely be doing soon.
#414
Liked 698 Times
They clements are a little sluggish yes, new tires will help depending on what you get.
2019 Salsa Warbird
2019 Salsa Warbird
#415
Quoted: 5 Post(s)
I bought SKS AL46 fenders and fitted them but have not tested them. They don't have a mud flaps but PDW Full Metal Fenders do.
I mounted the Gravelkings today on my existing rims so I figure I should try these out first before I look at spending $500 on wheels.
For fenders, it seems my options are pretty limited since I'm running 38's. Since people use the mud butlers here and have good things to say about them, I think I might try those out and see how the kiddo does. Worst case scenario I can add a strip of leather like a mudflap to the rear fender.
#416
Quoted: 428 Post(s)
Liked 340 Times
You are going to have to drop back to a 32 - 35MM tire to fit fenders. Challenge Strada Biancas are a nice really fast alternative in a 33mm. We use them with renegades and fenders in our shop all of the time. Fenders on a Renegade are da'bomb! Will help out keeping kids happy if you get into some rain, puddles or wet streets.
Likes For dwmckee:
#417
#418
Quoted: 5 Post(s)
The Gravelking slick's in 38's are sooooo much better than those stock MSO's-holy crap. Not sure I have a reason to upgrade the wheels at this point honestly. For fenders, since I just bought these tires, I might just grab the mud butlers since they will accommodate the 38's.
New problem for commuting: I'm trying to find a bag that I can put my lunch in. I don't really want to go with racks + a pannier, and I had a handlebar bag but didn't like how it threw off the steering, so I think I'm limiting my options to a frame bag or a bigger saddlebag. The frame bag could work great, but in the event I have some soup or something in tupperware (or a salad in a bigger tupperware), I don't see there's anyway that would be able to transport the tupperware laying flat.
#419
Quoted: 5 Post(s)
The gravelkings in 38's were a pain to mount on the stock rims as well. I didn't need a bead jack, but I was close.
#420
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1124/20181215_125728_ce9a9242e550a9ebb1b686361f92990aca488861.jpg)
Are people having luck with 700x38 Gravelking SK's with Mud Butlers? Seems like it would be a problem unless they measure same as 700x36 MSOs.
#421
Quoted: 18 Post(s)
You'll be able to clear the 38mm SK in the front, but probably not the rear. I cleared a set of Rene Herse (Compass) Bon Jon's on my Expat on a set of American Classic Race wheels that measured 38mm inflated with Mud Butlers, but it's a slick tire. The tightest point will be at the rear seatstay bridge. I was able to gain a bit more clearance by putting the fender mounting bracket on the underside of the seatstay bridge and gently bending out the sides of the fenders with a crescent wrench. In the front, tire clearance is better and you should be able to clear the SK 38 no problem. I've got a 38mm G-One that measure's 40mm on the front right now. On the front wheel the tight spot is going to be at the mounting point where the strut attaches to the fender and may require some manipulation as well. Here's a pic of the rear bracket and the sort of clearance I have with the G-One 35 in the rear. You're going to need to get some real world measurements of the Gravel King's before you make any decisions. You could always order one 38 for the front, test it out in the rear and if it doesn't fit run a 35 instead.
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/mud1_2f950d857528f3696bc416c1e0d8dc08ce0a79c3.jpg)
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/mud2_566c618b0b912c8afedefb1eb0fc452c1ed0d307.jpg)
#422
Hi folks...I am in the process of building a Jamis Escapade. I have never built a bike before, however, I am making steady progress. Could someone kindly provide a pic for me of the cable wrap around for the front derailleur on the seat tube? There are two holes on plastic cover that covers the pulley. I am guessing that the cable enters and exits one hole vs down one hole and out the next.
For those interested I am building the bike with a GRX 810 double cranke, Grx 810 rear and front derailleurs, and Ultegra 8000 shifters. I am doing Spyre brakes instead of Hydraulics.
Thanks!
Thanks!
#423
Quoted: 5 Post(s)
Mud Butlers are a tight fit with stock MSO 700x36 on the steel Renegade. I had to remove the rubber from the part of rear seat-stay mount bracket that goes under the fender.
edit: 38 GK Slicks don’t work-they measure 41.5 on the stock wheel set. Looks like it’s time for new tires!
edit2: as mentioned above, the 700x38 gravelking slick will fit in the front using a mud butler fender, but not the back. I bought a 700x35 and used that for the back. However for the bolt at the chain stay mount (near the BB), I used one of the bolts that was on the chain stay instead of the supplied bolt from mud butler-the mud butler one sits too high and I only had about 2mm clearance from the tire. Using one that was originally where the strut attaches to on the chain stay gave much more clearance.
#424
Bikes: YT Capra, 1984 Fuji Del Rey, Jamis Renegade Expat LTD
Picked up a new Expat LTD over the weekend! The ride is much improved over my 1984 Fuji Del Rey. I was surprised at how wide the handlebars are and how comfortable the riding position is.
I'm 6'2.5" and went with 58 cm. Fit perfect right out of the box, but the bike shop set up the saddle position based on measurements they took, so that helped.
The LTD color is gorgeous IMO. I'd post a picture but this is my first post. The Jamis website image does not do it justice.
Likes For mbuse:
