Any experience with Michelin Power Cup? Might leave GP5000s behind
Quoted: 2333 Post(s)
Liked 2,097 Times
Liked 2,097 Times
GP5000 TR S impossible to mount to Farsports Ventoux or FLo60 rims without heating them in the oven AND using the tire jack. It is a multihour ordeal to change a set of tires and get them sealed.
Michelin Power Cup could be mounted by hands or one lever to the same rims. Same with GP5000 clinchers.
Advocatus Diaboli
Quoted: 4821 Post(s)
Liked 1,556 Times
I've got one in my tool box and one in each of my saddle bags (I have big saddle bags), in addition to my quick link tool (that separates and doubles as tire levers). I used to have the VAR bead jack tool in my saddle bags, but this was enough better that I got bigger bags to ensure there was enough room for it.
Quoted: 4280 Post(s)
Liked 3,007 Times
I've tried that VAR tool a couple of times (bought one in hopes that I could stop carrying the Koolstop tool and use a smaller saddlebag), but, on tires where I needed it, I quickly turned to the Koolstop for its increased leverage (only tried it at home when I had the Koolstop available as well). I should probably have forced myself to try the VAR more to get better with it so I'd feel comfortable taking it with me as my main tool and leave the Koolstop at home, but, it was just easier to go with the bigger tool because it was available.
Bikes: SL8 Pro, TCR beater
Quoted: 1027 Post(s)
Liked 595 Times
2nd consecutive year using Schwalbe Pro Ones and they always mounted by hands. Levers needed only to unmount them.
Likes For eduskator:
Quoted: 338 Post(s)
Liked 408 Times
Modern Mavic SLR45 wheels (they pride themselves on being compliant to standards, though), the GP5000 S TR in 25mm width went on easily, helped myself with a lever for the final bit which I always tend to do.
Had to replace one due to a stupid sharp rock at night tearing the sidewall (held just enough pressure to get me home) and that was a breeze, too.
Quoted: 20810 Post(s)
Liked 9,456 Times
The Pro Ones and the GP5KS TR are both built to the same hookless compatible tubeless spec so I would expect the experience to be similar on modern rims; while I haven't tried the Conti yet, I can only use hookless compatible tires and all that I've tried have been pretty damn easy.
Likes For WhyFi:
Liked 2,097 Times
Like I said, the Michelins and clincher GP5000 could go on by hand or just a little help at the very end using a lever but I could do it by hand with some effort.
N = 1 experience.
Likes For GhostRider62:
Quoted: 338 Post(s)
Liked 408 Times
N=1 does it's thing, yeah.
Funny, I remember the old GP5000 clinchers were a pain to mount on one alloy (Fulcrum) wheelset. I actually broke one of the rims trying to mount some tubeless tires (Challenge brand ones) - I was trying to lever the damn thing on with a heavy duty steel core lever and the rim gave way.
Kind of suspect the wheel wasn't exactly to spec.
Liked 595 Times
It's actually not the first time I hear that GP5K tires are a PITA to mount. As WhyFi said, it may be easier to mount on hookless rims, though.
N = more than 1.
N = more than 1.
Liked 9,456 Times
My point wasn't really about hookless rims, specifically... it's that the two tires mentioned were both built to the same standard - which happens to be hookless compliant but, more importantly, is the most well-defined set of specifications in the (admittedly short) history of road tubeless - and should offer a similar experience when it comes to installation. The handful of ETRTO TSS compliant tires, that I've used, have been among the easiest to mount tires in my tubeless journey, whether I put them on hooked or hookless rims.
IOW, unless there's a significant difference, like tire size or sidewall rigidity, I don't see why my 6th set of ETRTO TSS tires would be meaningfully more difficult to handle than the first 5.
Likes For WhyFi:
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
I think it is very specific to the rim/tire combo.
Currently have American Classic alloy rims and Conti 5000's are super easy to mount with hands only. In the past I have used various Michelin tires and even the bike shop struggled like crazy to get them on. So once you find one that works, stick with that one.
Note, not tubeless, regular, old 25mm tire with butyl tube.
Likes For bblair:
Liked 9,456 Times
i would tend to agree with this logic, except I wonder if the hookless rim aspect does play a part. Only because we know the many difficulties I e had with the GP5000’s (and yet I keep going back to that well), yet I e had the exact opposite experience with the Schwalbe’s. First couple of sets went on super easy but were harder to seat, the one I just put on the front was freaking incredible. On in seconds, pumped up with my canister pump no soapy water, mounted complete with sealant in maybe 5 minutes
One of the difficulties with discussing Conti is that many are confused by their nomenclature - the GP5000 TL, their first tubeless tire, is the source for the vast majority of complaints/experiences of horribly tight fits. The GP5000 TL is *not* up to the current ETRTO TSS spec and they have, by all reports, undersized bead diameters.
Conti recently released the GP5000S TR; not nearly as many people have used them yet, but they correct the problem with the TL - the S TR *is* ETRTO TSS compliant, so they should have the same bead diameter, which is a key component of the spec, as the aforementioned Schwalbe, Michelin, Pirelli, etc. All accounts that I've seen on the S TR indicate that their far more manageable than the TL version.
Quoted: 429 Post(s)
Liked 248 Times
I've used some, but not all, of these TSS compliant tires on non-hookless wheels as well - all similar and all easy peasy.
Yes I'm bumping an old thread in case others have experienced this. I recently got my hands on the new Pirelli P Zero Race TLR with their new "Speedcore" and "SmartEVO" compound. It reviewed very well on Bicycle Rolling Resistance.
Today I sat down during the F1 race to put them on and could not get them on the wheels. I own a couple of the tools mentioned in this thread after my last experience with the GP5k (the tools helped but still tough with the TL version). No amount of trying could get the Pirelli tires on the wheel. So I called a buddy, while I've changed dozens of tires, he's changed hundreds. He came over and also couldn't get them on the wheels. 26x700 size, pretty infuriating that these new tires are damn near impossible to mount. I can't imagine having to change these on the side of the road. I'm going by a local shop tomorrow to have them mount them, I'd like to compare how they ride but being this hard to mount, I won't be running them long-term. At least not on these wheels. Major disappointment.
Still can't find the Michelin's state side, may order them from Amazon and try them. I did just order a new GP5k Clincher to see if it's easier to mount,.
Thread Killer
Quoted: 3270 Post(s)
Liked 1,810 Times
I did open the ‘23 season with a new pair of Michelin Power Cup 26, and they went on 21mm IW Hyper wheels without problem. I used a Pedros lever for the last bit of bead.
They’ve been great tires, too; our first camp was in hilly Bloomington, IN, and it was cold and rainy, but the tires were confidence-inspiring when braking and cornering. They’re supple and comfy, too, even at the 90/94psi I was running. I’ve backed those pressures down a bit since, and the tire has been fine and stable.
My crit days are (probably) over, so can’t comment on the tire in conditions like that, but for fast group rides, Power Cup has been an ace, rolling fast and transmitting a sensation of security over rough road and when hitting unseen cracks and divots.
It’s much better than the previous Power Road model, which was vague and dull feeling, and is more like Schwalbe Pro One in that regard.
Spring roads are full of debris, but Power Cup survived without puncture or signs of damage, so though that’s mostly down to luck, it’s looking like these tires are winners for me and might even be a new favorite!
I was going to ask the same question. I can only find them on Amazon to be shipped from Germany at 76 bucks a pop!
Thread Killer
Liked 1,810 Times
I don’t recall where I got them from, but yeah, R2 or Bike24 in Germany are likely as I’ve bought from them often over the years, and the $75 apiece price sounds right to my memory, too. I’ll try to dig back in emails and see.
EDIT: OUGrad05 Noahma Well I found the receipt, and I actually got them from Northwest Bicycle in Washington, $159/pr shipped, and it looks like they still have them: https://northwestbicycle.com/pages/s...%20power%20cup
Bikes: I have a few
Quoted: 350 Post(s)
Liked 238 Times
One of the difficulties with discussing Conti is that many are confused by their nomenclature - the GP5000 TL, their first tubeless tire, is the source for the vast majority of complaints/experiences of horribly tight fits. The GP5000 TL is *not* up to the current ETRTO TSS spec and they have, by all reports, undersized bead diameters..
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I experience some difficulty mounting Michelin Powers or Pro4s.
Maybe slightly easier than GP5000s, but I like how the Michelins ride.
Conti's feel less buoyant. I found their 4000's sidewall very brittle and prone to failure.
With both brands, just run the bead closer to the rim channel when mounting.
Usually requires a strong plastic lever for the final push. Pedro's and Conti make good ones.
I never had problems with GP5000 28s as well btw
Liked 595 Times
4th season with Schwalbe Pro Ones and still no complaint about them aside from having a short lifespan. They mount on my rims only using fingers and can be seated tubeless on rims with no compressor.
Changed a tube on my girlfriend's bike (it has older gatorskin tires) and I almost lost a thumb trying to re-mount the rear tires on the rim. Contis are a big no no for me.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4449 Post(s)
Liked 3,071 Times
Last night I put GP5000s on my Light Bicycle (Falcon R55 disc) wheels. When I first got these, mounting new tires on them was a bear and could take an hour, a whole lot of cursing, and blisters on my hands. (These days I wear work gloves for the job). Commonly I would finally succeed but discover that I had punctured the inner tube in the process, so...repeat.
Rear wheel was a new 25 mm tire and front wheel was a slightly used 23 mm tire. The first took 5 minutes, the second took 10.
I don't have any secret tools or strategy. I need a tire lever for that critical step near the end. All I can surmise is that experience helps.
But if there is a more enjoyable tire out on the road with reasonable flat protection, I'd like to hear about it, 'cause when riding, I haven't ridden anything close to the GP5000s
