Circuit Rebuild
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3919 Post(s)
Liked 6,549 Times
Likes For SurferRosa:
Quoted: 1441 Post(s)
Liked 1,998 Times
Liked 1,998 Times
Bikes: '93 Cannondale R500; '88 Centurion Ironman Expert, '97 Cannondale R900, '95 Serotta CSI, '83 Trek 700, '97 Lemond Zurich, '89 Bianchi Giro, '87 Schwinn Prologue, '83 Fuji TSIV + one perturbed wife
Quoted: 71 Post(s)
Liked 154 Times
I dunno now. SurferRosa's "Mona Lisa" of red cable housing is tilting the needle that way. Maybe it's a touch more of an impressionistic Van Gogh than a Da Vinci!
Quoted: 71 Post(s)
Liked 154 Times
Cables
So back to work on the Circuit. I was able to "correct" the problem with the Cinelli 110mm stem. At some point in the past, I apparently tried my stock of stems on another project and mistakenly switched the clamping bolts between stems. The bolt in the Cinelli was the wrong one. Swapping out the bolts between stems allowed the stem to tighten to the handlebars. $50+ saved by not having to source an old, odd sized Cinelli stem.
Cleaning and waxing the original chain, followed by installing a quick link, resulted in the link jumping as it went through the rear cogs. Since the chain is probably original, I splurged on a new chain. I just have to degrease it, wax it and install.
After ordering "trial" red cables from eBay, this project sat on hold for a couple of weeks. When the ordered cables arrived, they turned out an orangish-red. It wasn't anywhere near SurferRosa 's "red cable rendition". And didn't work at all with red of the Circuit's top tube decal and the Schwinn HT badge. So, the vendor kindly took back the first set of cables and I located another set that fortunately turned out a true fire engine red. (It's always a toss of the coin for me when I order a particular color item online.) So this morning, I took pictures of the existing black cables, mounted the red cables and took more pictures. So without further ado, the cable options are below. My preferred choice follows the pictures.....
It's RED for the win. I like the subtle "pop" it gives the frame. I'll test ride it this weekend when it warms up so I fine tune the index shifting and the adjust the handlebars / brake levers. Once that's done, the white bar tape and Turbo saddle will cap it all off!
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 687 Post(s)
Liked 1,010 Times
very nice bike thanks for sharing
Likes For georges1:
Quoted: 71 Post(s)
Liked 154 Times
To Close This Thread
I was finally able to complete the work on the Circuit and took it for its inaugural ride this morning....
Likes For Triplecrank92:
Quoted: 3594 Post(s)
Liked 3,014 Times
Awesome rebuild. You did right by that bike. Take a well-deserved bow.
Likes For smd4:
Quoted: 71 Post(s)
Liked 154 Times
Mucho Gracias! It rode well this morning but had a little slippage in the DT shifters which I hope to correct by checking the washers in the shifters or finding some nylon washers. The RD needs a slight adjustment of the shifter cable given a little chatter in the pulley wheels.
resykler
Bikes: Bianchi Eros, Bianchi Reparto Corsa, Mongoose IBOC Campagnolo, Schwinn Super Sport, Mairag 4 Star, Canondale Criterium, Centurion Accordo RS, Specialized Hard Rock 1st Gen, Bianchi Special '81
Quoted: 101 Post(s)
Liked 59 Times
Beauty
I had one stolen a couple of years back and still miss it a beautiful build congratulations
Likes For brixxton:
Likes For Sierra:
