Help I need a\can I borrow\can I rent a tool
Bikes: Indeed!
Quoted: 1522 Post(s)
Liked 3,541 Times
Brent
"I have a tendency to meander sometimes." B.G.
Likes For obrentharris:
Quoted: 3646 Post(s)
Liked 3,085 Times
Extraordinary Magnitude
Quoted: 2612 Post(s)
Liked 1,733 Times
One of the nicest things someone has done here was to contact me to offer to let me borrow a tool.
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Stop reading my posts!
Quoted: 1471 Post(s)
Liked 1,107 Times
the thread file is worth a try, I believe they are "normal" metric pitch threads, just a very abnormal diameter. But a good quality metric thread file might do the trick, I've used one on some automotive parts before and had success.
At first I only had some cheaper Asian-made files in both SAE and metric, but acquired a used Nicholson brand SAE file (same arrangement with 8 different patterns on the 4 surfaces of two ends) and I think (or imagine) it gives better results.
YMMV
Quoted: 7400 Post(s)
Liked 2,580 Times
Well, it's not the worst thing that can happen, and I probably will be able to repair the tool. We have to balance risk, cost, probability, etc.
Likes For noglider:
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1186 Post(s)
Liked 2,078 Times
I do have a BB re-facer that I will loan locally and in my presence.
Robert
PS, perferably with beer in hand.
Robert
"Leave the gun. Take the Colnagos."
Likes For Robvolz:
Not lost wanderer.
Quoted: 901 Post(s)
Liked 1,045 Times
Well, I never ended up with a chainstay cripmer. But
I still needed one and nlerner stated in post #5 that he used a bench vise.
Well I had a cool little bench vise I made while I was in college for Industrial Arts in my cold metals class
I had a cool piece of plastic I put on the outside of the stay and put the vise on it and tightened it and indented the frame about 4mm
did what I needed.
This is the first time I used the vise.
did what I needed.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Likes For bwilli88:
Liked 3,085 Times
did what I needed.
did what I needed.
Do you mean to say that you dimpled the exterior of the chain stay with your machine vise and tubing block? Was this so that the front derailleur would not hit it while shifting?
Bikes: Indeed!
Liked 3,541 Times
Brent
Quoted: 1119 Post(s)
Liked 1,352 Times
My condolences!
YMMV
YMMV
If the damage is localized I'd get a loupe on and use a smoothed triangular pick to burnish the bad sections into submission.
I do wonder how it got damaged, being harder than any aluminium crank.
Not lost wanderer.
Quoted: 901 Post(s)
Liked 1,045 Times
Nope, I needed tire clearance and the plastic piece kept the exterior from dimpling and it just flattened the interior of the stays right where it was next to the tire. I did both sides.
feros ferio
Quoted: 1406 Post(s)
Liked 1,364 Times
Caution: My 1973 Peugeot UO-8 frame failed due to a crack in the drive-side chainstay, about in the middle of the dual (tire and chainring) clearance dimples.
Not lost wanderer.
Quoted: 901 Post(s)
Liked 1,045 Times
Thanks to nlerner for the idea!
Liked 3,085 Times
