Why do many bicycle manufacturers not list the weights on their bikes?
Bike weights no longer listed? They used to be for the described component configuration and frame size (usually a 52 or 53cm). It was a major selling point. Weights should be listed, as apart from fit, as it is the single most important determinant of bike performance. Heavy is cheap and slow, light is expensive and fast.
The reason why weights are no longer listed is obvious: disc brakes, and all of the associated extra ballast. Also, to a lesser extent, aero stuff including wheels. What used to be an elite-level bike circa 2015 with rim brakes (<15 lbs) is now unobtainable with discs at any price. A run of the mill $2,000 road bike in 2015 would come in at 17-18 pounds. Now, you'd have to pay 3 x that to get down to those weights with discs.
For similar reasons, the big vendors no longer offer organized "test ride days", where you could drop your credit card off at the tent and ride a few new bikes. For those of us with enough experience, and with a fleet of pre-pandemic bikes, the results of such a test on 2024 bikes would be both ride disappointment and major sticker shock.
The language on the vendor websites citing their 'inability' to list weights is due to legal butt covering and simple embarrassment as to how porky their current bikes are.
With a mighty wind
Quoted: 1130 Post(s)
Liked 922 Times
Listed bike weights would be with no pedals and no cages.
I think most bikes have tubes in the shop and get set up tubeless later.
I remember one shop that had reflectors on all floor models, regardless of how high end.
I think that most accurate if you are concerned about grams, would be to look at the published weight of a given frame. Realize that most bikes are going to be really similar at a similar price point. Just be careful with published weight, read the fine print of which frame size they are weighing.
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 257 Post(s)
Liked 1,101 Times
Unless they list the weight spec for each model frame and particular component spec, the manufacturer claimed weight is highly suspect. I was recently looking at bikes in the "climbing" or "light and stiff" categories, and one particular manufacturer stood out in that they claimed a 6.7kg bike weight in medium. Digging further, the 6.7 weight wasn't for the bike I was looking at, but rather a top-shelf bike that was over $10k. They didn't actually provide a weight for the mid-tier builds with a lower-spec carbon lay up. The weight wasn't the final factor in not choosing this bike, but it did certainly play a part in how I compared it to other bikes at that price point.
Yep, weight does matter to a certain extent. Not to start a popular debate, but there are certain features of modern bikes that I won't forgo in the name of weight. However, weight certainly does matter when I'm cross-shopping similar models of bikes. Additionally, there is a general upper weight limit for a bike, that will make considering it, a non-starter for me. Maybe if I lived in a flatter area, weight might become a non issue for me and I'd suddenly care about whatever aero benefits are touted.
I am potato.
Quoted: 1826 Post(s)
Liked 1,701 Times
Aero on the other hand. I have first world experience with an ultra aero dude on a TT bike fully optimized with the silly hat sitting in my draft and unable to pass me on my IGH touring bike with rack & fenders. On that 5 mile flat, straight, and windless path with good quality pavement I averaged 305 watts at ~23mph. He averaged 173 watts. He had every advantage and couldn't escape my rather large slipstream. I even pulled away a few times and let him catch up. I looked up his ride report on Strava. Turns out he was recovering from being sick & giving it his 100% At my power he would've cleaned my clock if he had it in him.
To be absolutely clear: He used ⅓ less power for the same speed.
Aero matters more.
Quoted: 833 Post(s)
Liked 1,977 Times
A skinny waif will most likely not be on the cover of Shape, but a cross-fit more muscular women would.
Different looks for different audiences.
A sub 15 lbs carbon superbike would not best serve my 220 lbs muscular frame but a 20 lbs 853 Reynolds steel bike would.
My point is simply, lighter might not be better for certain body types.
In regards to the original post, lighter weight would not be high on my list of must haves.
Perhaps I'm an outlier?
Nor is lighter necessarily a better manufactured product.
Quoted: 6346 Post(s)
Liked 4,948 Times
Probably because some people get upset when their bike is 17.8 lbs instead of the 17.4 lbs that was listed in the specs.
Likes For Iride01:
Quoted: 2621 Post(s)
Liked 3,157 Times
Which bike catalogs do you have in mind that listed bike weights? In particular, which catalogs listed weights until recently but stopped doing so when they changed from rim brakes to disc brakes?
Quoted: 4599 Post(s)
Liked 5,144 Times
Actually many of the major brands do list bike weights in specific build specs. Giant is just one that doesn’t bother.
Specialized, Trek and Canyon all list weights for each model and build spec.
As usual you are talking nonsense.
Quoted: 4876 Post(s)
Liked 4,042 Times
Myself, for example, I've got old injuries where having to heft around a heavier bike can get problematic. The difference of a half dozen pounds on a daily-used bike can make quite a bit of difference. A lighter bike can strain the injury areas less ... a really big deal, for some injuries.
"Weight-weenie" stuff is a whole other kettle of fish.
With a mighty wind
Liked 922 Times
Your statement contradicts your statement.
A $2000 (105 trim level) road bike was never sub 15lbs, in any era.
A disc brake bike under 15lbs is achievable. I think that Rodriguez and some others might even have steel bikes that fit this description. Not cheaply.
The UCI weight limit is 6.8kg. Wouldn’t it make sense to build the bike more aero and stronger at that weight than to go under just to make a very small group happy?
Likes For rosefarts:
Quoted: 257 Post(s)
Liked 1,101 Times
I can’t tell if you’re spinning a wild conspiracy theory or just grouchy about the bike industry moving away from your preferences.
Maybe my scale is crap, but even my uber-light climbing frame with rim-brakes, shallow carbon wheels, and Ultegra, was a bit of a struggle to get down to sub 15lbs. It's even from Dave's golden era of lightweight frames from about a decade ago, about 750 grams for the frame.
It's light and snappy up hills, but I'm still more likely to grab my 18lb disc brake bike. The discs and ability to fit larger tires, are a couple of the features that I'm willing to sacrifice some weight for. Even that's not a like comparison, the equivalent modern climbing bike with disc brakes is only going to give up about a 1lb...which is totally worth it IMO.
Quoted: 3633 Post(s)
Liked 3,059 Times
Back in the day I got most of my bike weight info from the road test reviews in the magazines.
Quoted: 18569 Post(s)
Liked 16,014 Times
You telling us that weight is a factor you never consider when purchasing a bike?
Quoted: 833 Post(s)
Liked 1,977 Times
I came to the realization at 60 y/o and 220 lbs, the best bike for me may not be the lightest.
I regularly ride a 35+ lbs rigid MTB on the road even though I own a 17 lbs carbon road bike in good condition and a 20 lbs crit bike.
It is about fitness at this point and not speed or distance.
If I want to ride further, I'll get out the lighter bike.
Otherwise, the MTB does great for 30-40 mile rides in the hills.
Liked 16,014 Times
It is not a black or white issue for me.
And are you telling us that, all else being equal, you’d opt for a 40# MTB over a 35# MTB? If so, why?
I do loaded touring. If I wanted a new bike and there were choices that were otherwise equal, I’d certainly want to know how the weights compare because I wouldn’t want to have to pedal appreciably more weight.
Likes For indyfabz:
Liked 16,014 Times
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12965 Post(s)
Liked 7,885 Times
I'm glad to see more manufacturers listing weights again. Seems like most didn't post them from the late-90s to 2020 or so.
From this 2010 C'dale Catalog snippet, I think their angle was to get people in the store to check out the weights, then the salespeople would work their magic and NBD!!!
But once a couple of manus start posting weights, I think the rest are going to be forced to in a way.
Quoted: 833 Post(s)
Liked 1,977 Times
But you see, weight does matter to some people, even if they are not racing, even if it doesn’t matter to you.
I am considering converting the Kestrel to a flat bar bike as Kestrel even sold the RT-1000 as a Hybrid BITD.
This would make a great comfy all day bike for me at 17 lbs where speed, distance and endurance would matter.
All I am stating is it is not that big a deal for me to push a heavy bike.
I am considering using the MTB for a week long tour in the SoCal mountains when I get the chance.
I have taken the MTB up HC and Cat 1 climbs and it is tough but not impossible.
Bikes: everywhere
Liked 7,885 Times
Liked 5,144 Times
So what do you expect them to do? They list the weight of a production bike as specified at the time. They can’t really offer any more than that.
For example they list an S-Works Tarmac DuraAce at 6.62 kg (size 56 cm) and the equivalent SRAM Red build at 6.85 kg. That’s good enough detail for me and their disclaimer is not unreasonable.
Likes For PeteHski:
Quoted: 7705 Post(s)
Liked 3,628 Times
No, it does not hold water. It's like saying that when a car manufacturer states a weight for a certain model, spesific engine and size that they can't do it because maybe the buyer puts on different tires (heavier/lighter), extra lights and installs a big music system in the car. Well, I'm talking about the specified weight of each specific model before the buyer makes their modifications. Withholding information about the product is the kindest thing I call it.
hsea17
hsea17
Just because car makers can list the weight of a car ... is the weight accurate? When is the last time you weighed your car, or any car? Obviously options will change the weight ... and equally obviously ... People Don't Care.
No one is going to buy one bike over another because fo a one-pound difference. People will definitely choose one bike over another over a one-pound difference .... and will make that choice based on published weights, provided by the manufacturer, or by some magazine writer who wrote a review.
Most cyclists are smart enough to realize that the listed weight for a bike is not necessarily accurate, but still some parts of the brain will be influenced by the number ...... even knowing it is not an accurate comparison. And how many manufacturers want to list every frame size?
You need to remember, a difference of fifty pounds in a three Thousand pound car is what ... 1/600th? The difference of one pound on a a 20-lb bike is thirty times that ..... and in a car, the motor pull;s the weight.On a bike you are the motor. Note the subtle differences?
Yes, in part, manufacturers know that if they list a bike in a given size at a given weight, and a competitor lists a comparable model at half-a-pound more, that looks bad ... even though the bikes are not identical in any other fashion (slap on some light tires for that model, use lighter but more expensive cockpit components .... hoping to make up the higher cost with higher sales spurred by the lighter listed weight. And no one wants to be honest, publish an honest weight, and lose a lot of sales because of the asterisks and fine print (a simple disclaimer like "bike weight may vary due to component choices" (and already a lot of manufacturers have fine print explaining that the model they ship might be different than the model on the website ... if they run out of Shimano parts but got a deal form SRAM ... oops .... so long as the manufacturer can claim "comparable quality" ..... " so a manufacturer Could,if sleazy, build a up a few "diet" models and weight them and keep them in the factory store room in case of law suits ... )
But really, the whole issue of listing weights is just a rabbit hole full of rabid weasels. Seriously, weight is Important to cyclists .... not ultimate (to most of us) , but important .... and no manufacturer wants to list weights for seven models with seven frame sizes and seven build options ..... and then have to defend on the internet (social media would go nuts) if all the weights were found to be a little low ..... even if only a few grams ("We used a different tire and bar tape on our production models ... ")
Seriously, if a difference of a few hundred grams is the deal breaker ... either you are obsessed or worse. Pros don't care that much about weight .... they know they have enough motor to propel anything at a very high rate of speed ... when you see riders cracking on hard climbs, it isn't that they would have won the stage if they had only used just a single cage and bottle instead of two .... and for the rest of us .... an extra hour of intervals three times a week will outweigh any minor difference in bike weight.
We need to remember, one Big reason bike manufacturers started trumpeting low bike weights was because it was an easily understood, easily calculated metric. NOT because it was the most important metric, but because most consumers can relate to a claim like "For every gram we shaved off our latest (and lightest model, you can feel the power in your legs turning into more speed on the road." or "Don't spend your power moving mass---spend your power going fast." it was all hype, all ad copy ... a way to make a specific brand stand out from the rest ... and since (due to technology) bikes were getting lighter, lighter must be better, right? (And super hard super skinny tires must be faster, right?) Of course now we know that aero trumps weight, and wider, softer tires are faster for most uses (except track riding) ...
But ... we were sold "Lighter is Better" and a lot of us bought it ... and now we compromise an the quality of our riding experiences to have bikes which look good on paper ..... Well, a Little less so now, but there was definitely a stretch of several years when people went crazy to shave grams without ever asking how much it mattered in the physical world ... they were happy to have the mental edge of having drilled holes in every component ....
When I plan to buy a bike online, I Always find a source for the weight .... even if I don't fully trust the source ... not because i will only buy the lightest bike, but to look for anomalies ("Why does that bike weight that amount? It seems that is should be heavier/lighter with those components ... ") and when I get he bike I don't expect it to weigh what ever the manufacturer claimed, anyway .... pretty sure whenever they Do post weights, they weigh one of the six 48-cm frames they produced .......
Liked 16,014 Times
Hi!
I'm interested in buying the 2025 "New Giant TCR but neither that model or previous TCR models are listed with weight on the web in their specification. For me its like show me what you have in detail, and you have a potential buyer, if not its turn around.
Rant over.
hsea17
Rant over.
hsea17
Likes For Yan:
Quoted: 399 Post(s)
Liked 309 Times
One of the reasons they don't post bike weights is that nobody rides a bone stock bike - you can't unless it at least comes with pedals.
You ever notice that the power tool companies post amp hour capacity for each tool battery next to the price, but never, ever mention the cost per amp hour? It's all hush hush (even though you can do it in your head in 2 seconds). The manufacturers don't want to compete on price, so they keep marketing "features".
Likes For ScottCommutes:
I am potato.
Liked 1,701 Times
I ride a 7L and did not specify the "ultralight" option. Which in reality is different, lighter rear dropouts to accommodate flat-mount brakes and extra large holes inside the frame at the tubing joins. The total saving at $600 extra expense is about 2 ounces. (I have also learned that Dura-Ace shifters are heavy.)
I'm also 85 kilos and generally stronger than average. I have no doubt that there is an extra bit of material in the chain stays that a smaller, less powerful rider on a size 5S wouldn't need.
It does ride like a rocketship. But even at the bleeding edge, someone as big as me would need something in rim brakes to cross that 15lb threshold in steel. I have ridden their 13 pound display bike. It is possible, but I have my doubts about doing so in disc in "as ridden" form.
