My first go at road tubeless...inauspicious
#76
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
One more downside of the tubeless compatible wheels was the rims had no spoke hole drillings, to make for a better seal. So if we ever need to replace a spoke nipple.. then what? Of course the provided nipples were custom hex-shaped, requiring a custom tool. Another PITA.
Easton Wheels just uses double threaded nipples. You thread the nipple into the rim, then the spoke into the nipple. It's actually very easy and much less of a hassle than removing the tire and rim strip.
I was quite impressed with that system.
#77
Bikes: bikes
Liked 1,429 Times
Very few people in the P/1/2 races I do use tubulars. Most everyone is on clinchers, usually GP4000s or the Specialized Cottons from what I can see.
#79
I can mount amd remove standard clinchers on my HED rims without use of tools. Getting the tubeless Schwalbe Pro Ones on is a little harder but still no tolls. Removing the tubeless takes a bit more effort requiring a lever.
#80
All tubeless tire/rims combinations do fit tighter than standard tubed clinchers. They have to in order to maintain a seal. They are harder to install - this is basic knowledge.
Didn't know the Ultegra wheels were tubeless compatible before we got them; otherwise we wouldn't have - too much of a hassle installing tires, and especially removing them. Removing heavy-duty wire-bead tires on tubeless rims? Impossible.
Besides: if you need a bike to pick up groceries, or to park outside the pub, then tubed clinchers are the way to go. For high performance riding, tubulars are mandatory.
I really dont know yet whether tubeless offers me an upgrade over riding standard clinchers. I will get improved rolling resistance over my clinchers with butyl tubes, according bicyclerollingresistance.com, but I would get tne same improvement with latex tubes. So flats and ride quality would be the two areas tubeless would offer benefit. We'll see.
HED rims do have spoke holes and use standard nipples. I won't buy factory built wheels like Ultegra. Handbuilt wheels -- either by me or by a pro -- offer wider options and assurance that I know what I am getting.
I knew the HED rims were tubeless when I got em but thats not why I got them. I wanted the wider profile for smoother ride and lower rolling resistance, intending to ride clinchers. They deliver on both fronts even with standard tubed clinchers; a really spectacular riding rim. I got the tubeless tires to try em out to see if the fewer flats and better ride quality they purportedly deliver will make the extra effort to install worth the effort. Time will tell, and I'll either stick with them or go back to clinchers.
#81
Bikes: Salsa Ti Warbird- 2014/ November RAIL52s
Quoted: 67 Post(s)
Two plastic levers and a little chain lube make it a cinch. First place one lever under the bead, put a little chain lube on the rim and bead, place the second lever next to the first and slide. I carry a small bottle of NFS in my tool roll.
#83
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
My question is what about when the tire gets a tiny bit worn out?
In my younger slightly less mature days, I used to head out for a long trip without checking my tire pressure. This would result in a fairly new tire being worn out pretty fast. Or Id brake so hard down hill that I'd wear a spot right through the casing, heck once I could actually see the tube.
With tubless does it take being a little more on the ball with maintenance? Do you need to replaces them ASAP all the time? They just sound slightly less forgiving to me.
#85
Upgrading my engine
Quoted: 125 Post(s)
I've used both Easton EA90 and Shimano Ultegra tubeless wheels. I used the Eastons as both a tubed and tubeless setup. I never felt like tires were more difficult to get on, tube or no tube. If anything, I was surprised how easily my first set of tubeless tires went on. I was thinking they would be tighter so it would be easier to get an air seal.
#86
Upgrading my engine
Quoted: 125 Post(s)
Obviously, you shouldn't be riding your tires down that far, tubeless or not.
#87
Non omnino gravis
#88
BMX Connoisseur
Quoted: 399 Post(s)
Liked 108 Times
I wore out a Hutchinson Fusion 5 pretty far. You can see it here. It didn't have any problem holding air.
#89
I've been running tubeless on my fat bike for about a year without any flats. I've also been running tubeless on my gravel/cross bike for about eight months with no flats. I have 36mm Clement MSOs on the gravel bike which I run at 35-50 PSI depending on the day. I've run the fat tires as low as 4 psi without problems. The Clements are absolutely amazing on the gravel bike: fast rolling, tons of grip, incredible supple ride, terrific durability. I really wish Clement made tubeless road tires.
At this point I'm convinced of the benefit of tubeless, at least at lower PSIs. As I have a set of tubeless-ready Ultegra wheels, I want to give tubeless a try on my road bike. I can only fit 23s and MAYBE 25s on my road bike due to tight clearances. I'm surprised at the fairly terrible selection of tires available. I'm not a fan of Hutchinson tires as I've tried the Atom and really didn't like it.
I'm looking for feedback on:
Maxxis Padrone
Panaracer Race A Evo3
Schwalbe One
The various Bontrager offerings
...any other suggestions people have.
I'd love to fit something like a Compass but as I said, no room in the frame.
All of these options are fairly expensive so I don't want to experiment too much. I'm not racing and I prioritize puncture/cut resistance over a few grams of weight. This will be for 100% pavement riding. I weigh about 150 lbs and want to run around 75-80 psi. I have a compressor and I've done this before a few times so no issues with mounting.
Maxxis Padrone
Schwalbe One
#90
Quoted: 18596 Post(s)
Liked 16,096 Times
#91
Quoted: 686 Post(s)
Liked 5 Times
Maxxis Padrone
Schwalbe One
Maxxis Padrone
Schwalbe One
https://www.universalcycles.com/shop...s.php?id=80182
I used the Clement's on my Mr. Pink with good results. Only reason I'm swapping them out is because the new Dura Ace I put on the bike can't shift the FD with the bigger tires in the way.
I'd also recommend the Schwalbe Pro1, that's what I'm currently using on my cannondale with a lot of success.
Vittoria makes a tubeless Corsa G now that only weighs 205g - I'm curious to try them out next time I need tires.
#93
Clement makes a 32c tubeless tire...it's kind of a road/adventure tire...
#94
Quoted: 686 Post(s)
Liked 5 Times
![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
I love the Pro1s, however, haven't ridden any other options out there. I had a pair of Schwalbe Ultremos and really enjoyed them, so I gave the Pro1s a shot. I usually run them a bit lower than I would with tubes, but when I started trying really low pressures with them, I felt like I was bottoming out on a few hard bumps. That said, the Pro1s have come down dramatically in cost, so I'd definitely look at those over the normal Schwalbe Ones.
(I should also note, I'm running the Pro1s on non tubeless ENVE rims without issue.)
I'm hoping the Vittorias will be more available by the time I need tires again, probably this summer/fall...fingers crossed.
#95
Flyin' under the radar
[thread drift] I assume you're referring to NixFrixShun lube. If so, how do you like it? How does it compare to Rock n' Roll (if you've used it)? Thanks![/thread drift]
#96
Maxxis Padrone
Schwalbe One
Maxxis Padrone
Schwalbe One
I have run Bontrager R2 tubeless, R3 tubeless, and Scwalbe Pro One tubeless in 23 & 25.
The R3s were an improvement in ride quality over the R2s. I did have one R3 that punctured, and somehow the sealant sealed the puncture at the tread, but didn't seal the puncture at the tire lining, so I ended up with a massive sealant bubble -- Trek replaced this tire under warranty. Eventually I punctured and lost so much air I had to pull over to inflate . . . when I did, the CO2 froze the valve stem and the valve stem sheared off. The tire was near the end of its life anyways, so that's when I switched to Pro One's.
Pro One's in 23 were a noticeable improvement in ride quality over the R3s. I'd have to say they're more puncture resistant as well; I never once had to pull over an add air (still running Bontrager TLR sealant). I got about 2500 miles out of my rear tire. I decided to move to 25s and replaced both tires even though the front showed little to no wear, even after 2500 miles. I'm ~190, and I rode these at 85F/90R.
Pro Ones in 25 are awesome. Only slightly wider and ever-so-slightly taller than the 23s. I've ridden these down to 70F/75R in testing . . . I think that was a bit low for my weight as I could feel they weren't rolling as fast vs. 80F/85R.
Comparing R3s vs. Pro One's, it's a no-brainer: Pro One's all the way. Faster tire, more supple, better puncture resistance, and MUCH lower cost: Schwalbe Pro One $38.99
I just purchased 3 of these to qualify for free shipping. Got them to my door in a week for less than what I paid for two Pro One's from Amazon.
#97
Upgrading my engine
Quoted: 125 Post(s)
You may not want Hutchinson, which is understandable (Fusion 5s are garbage, too) but I'm running Hutchinson Intensive tires right now and they are very durable. No flats so far and I think it will get 3,000 miles on the rear. I have 25s, but they're narrow for a 25 and would probably fit.
#98
Quoted: 13 Post(s)
