Honest opinion piece on disc brakes
#101
Quoted: 20810 Post(s)
Liked 9,456 Times
I get the rim wear argument, but a bit of googling tells me that disc brake pads on average are good for about 800 miles, and a pair of rotors for about 3 disc pads. Basic math is therefore about $150 every 2500 miles (2 rotors plus 6 disc brake pads)? Is this accurate and/or how does this compare to the mileage (and therefore replacement frequency and cost) impacts to rims plus rim brake pads?
#102
Liked 3,174 Times
-YMMV
-YMMV
#103
Quoted: 4081 Post(s)
Liked 7,667 Times
#104
Liked 7,667 Times
Unless painted CF bikes are black, they get hot in the sun, and heat ages plastic.
#105
Quoted: 7163 Post(s)
Liked 11,368 Times
Take your first example. Plastic gasses off then gets brittle in it old age. Unless painted CF bikes are black, they get hot in the sun, and heat ages plastic. Ultra violet light ages plastic also. Put a titanium frame and a CF frame outside in full sun light and weather, and look at them after a year and see which one has the most damage.
Likes For Koyote:
#106
Advanced Slacker
Quoted: 2769 Post(s)
Liked 2,556 Times
![foo](https://www.bikeforums.net/vb/cache/ds.jpg)
Are you talking road biking or mountain biking?
Likes For Kapusta:
#107
The guys with rim brakes in our summer bicycling group don't need a bell to warn pedestrians. All they have to do is grab some brake. The squealing instantly makes pedestrians jump off the multi-purpose path. The sound just screams Wal Mart bike even though their bikes are not big box store bikes. No thanks. I will stick with my hydraulic disk brakes. I don't need a marketing guru to tell me that.
I don't know much about the new hydraulic rim brakes, maybe they are way better but I can't see stopping over 300 lbs going down hill with rim brakes.
#108
Quoted: 3352 Post(s)
Liked 1,056 Times
Likes For rydabent:
#110
Liked 1,056 Times
No need to have a degree. A little bit of common sense and Google is a quick and easy way for anyone to find reliable information from credible sources that contradicts pretty much every one of your ridiculous arguments against CF for use in bicycle frames. If you don't want to ride a CF bike, then don't. I don't care what you choose. Your continual posting of willfully ignorant misinformation, however, is bad for this forum.
I offer this analogy. I help friends work on old cars. The plastic electrical plug are extremely brittle and prone to breakage. Remember the lions part of the weight in a CF bike is plastic.
#111
Quoted: 18596 Post(s)
Liked 16,096 Times
#112
Liked 7,667 Times
I have seen and touched a couple of Wright Bros steel bikes. they are now around 120 years old. Put a set of tires on it and off you would go. Do you honestly think that you could do that in 120 years with a CF bike built today. I say it would be so brittle it would shatter in a thousand pieces when someone tried to get on.
#113
Liked 3,174 Times
I'd want about a decade before the frame starts to have issues.
-YMMV
-YMMV
#114
Quoted: 1956 Post(s)
Liked 2,201 Times
”Here’s your great-great-great-grandpa’s bike.”
”What are those?”
“The Smithsonian says they’re rim brakes. They squeeze the rim with enough force to stop the bike.”
”Eek. I’m not getting near that thing.”
John
#115
Liked 7,667 Times
#116
Habitual User
Quoted: 5120 Post(s)
Liked 8,457 Times
Based on your opinions and conclusions, there's no way a 50+ year-old plastic-handled screwdriver should still be unusable. Yet, I have a bunch of them that I continue to use on a regular basis, and they show no signs of failure any time in the foreseeable future. In fact, I recently used one as a kind of chisel, and hit the end of the handle hard with a framing hammer multiple times. You might be shocked to hear that the handle didn't shatter on impact. Sorry, man. Your plastic analogy fails.
There is actually a current thread on BF that includes info about the ratio of CF fibers to resin/epoxy in a CF matrix for bicycle frames. Not surprisngly, the numbers don't match your guess. There's actually multiple bits of info in that thread that shoot holes in some of your other CF conclusions.
Again...You have zero idea what you're talking about. Please stop. You're only putting your own ignorance on display.
Likes For Eric F:
#117
Take steel for example. Steel rusts. And while aluminum oxidizes as well, especially in the presence of chlorine atoms, steel just rust so much worse. When you combine chlorine with aluminum the chlorine atom does its thing oxidizing the aluminum atoms and then it kinda stops. Thus you need more salt for more corrosion. However with steel the chlorine atom doesn't stop. It jumps to the next atom and the next after that causing a chain reaction rusting the steel which eventually rusts the whole frame apart. And you cannot avoid it. Chlorine is everywhere but especially in salt which is found in sweat. So you sweat on your steel bike once and it's gone. Eventually.
Aluminum on the other hand doesn't have a fatigue limit. So you ride it and eventually it will fall apart. There's no avoiding it. An aluminum frame will fail eventually when it's ridden. That's a fact. So don't be so dumb as to ride an aluminum frame.
Titanium can only be welded in vaccuum. So if your frame does break it's pretty much toast.
Wood might be the way to go. But then there's worms and other pests which eat wood. And mold. You cannot win.
But if we consider plastics, there is in fact more than one. And different plastics have different properties. Not all plastics are UV-sensitive. Nylon is. Polyester not so much. Which is weird because most quality tents are made out of nylon... I wonder why that is? Could it have something to do with UV-protective coatings?
So to assume a carbon frame will suffer from UV-light we must first assume that the epoxy used to form the frame is very UV-sensitive. That's not a given though. But if the epoxy is UV-sensitive, it then needs to be uncoated for the UV-rays to get through. If the frame is painted, well then there's no issue is there? Paint can be reapplied if it chips.
As to the concept of "gassing off", there aren't that many plastics that actually do that. Plastic's stability is actually a major environmental issue. They just won't degrade. But I suppose that can happen with some volatile plastics like those that were made in the early days of plastic. The kind you see in old cars. But to my knowledge the epoxies used in carbon fiber production don't vaporize and are actually very stable even in low pressure environments, like airplane for example. Did you know all modern fighter jet wings and chassis are made out of carbon fiber? Well now you know. And a fighter jet has a service life of more than 40 years or so of far heavier use than a bicycle will ever see.
Now if you do respond to this post, feel free to ignore all of the stuff written above. Just respond to this. If you don't I'll know you're trolling and full of it.
Have you ever seen sailboats? What are they made of? Could it be glass fiber? The stuff that is also bound by an epoxy matrix, ie. plastic. Now do sail boats see much sunlight and therefore UV-light? Do sailboats experience demanding conditions?
The sailboat my inlaws own was made in the early 70's. By your logic since it's almost 50 years old it should have disintegrated by now or at least it should be unusable because of the various methods of plastic degradation. It looks like new.
Likes For elcruxio:
#118
Advanced Slacker
Liked 2,556 Times
My experience with cars is that rusted steel does them in before brittle plastic does.
And how many of those old plastic parts you speak of are modern CF?
You are mistaking a gut feeling for a reasoned argument, here.
#119
Advocatus Diaboli
Quoted: 4822 Post(s)
Liked 1,557 Times
eg.
https://prodifycycling.com/bike-disc-brake-guide/
followed by googling 'how long do bike disc rotors last'
https://www.feedbacksports.com/mecha...ce%20schedule.
The writers may well be just quoting lowest denominator (MTB I suppose?). OTOH, a bit more searching and I'm hard-pressed to find anyone stretching lifespan to 8-10,000 miles.
#120
Liked 3,174 Times
Kinda touches on the life span of CF. Tried looking for a link that I read a long time ago that provided a short & sweet to it all...
https://www.technewsworld.com/story/76172.html
-YMMV
-YMMV
#121
Liked 3,174 Times
"average lifespan of brake pads between 25,000 and 65,000 miles...." "though some people will have brake pads last beyond 80,000 miles...." While it's impossible to give an exact number, the 40,000-mile range is the general mileage to keep in mind when planning for vehicle maintenance...."
That is a rather big gap regarding miles for a set of pads, that is assuming it's referring to the front only. Under normal conditions & with commonly designed purpose; Rear pads do not wear as frequently.
As to clarify the point; The expectations for pad & rotor replacement is a "YMMV" greatly. A logical & common understanding of the system may aid in developing what to expect out of brake pad wear.
-YMMV
-YMMV
#122
Senior member
Quoted: 948 Post(s)
Liked 667 Times
As you like it.![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
General Cycling is delightful come springtime, as nesting season ramps up. Long-time thread watchers know that the Waving Thread is an early arrival -- but a reassuring one, presaging as it does the eruption of song to follow. Its peculiar cry puts the steady drone of the Steel-is-Real, Rim Brakes Are All We Need, and the Asploding Crabon -- all hardy species that have acclimated to northern climes and winter over -- firmly into the background. Typically, the Waver's arrival is shortly followed by the I-Passed-A-Roadie. Then, by around May, all h_ll breaks loose.
#123
Everybody here is somewhat right and somewhat wrong. Materials within any particular category run the full gambit from very long lasting to lasting long enough for the check to clear. Quality of materials and manufacturing processes are the big determining factors on longevity. All materials have their limitations and strong points. Design and manufacturing can make or break any material selection. All long time bike manufactures have designed and made some lemons. Generalities are worthless.
You generally pay for what you get but not always. A $5,000 bike will very likely last longer than a $179.95 Wal Mart bike.
#124
I’m a little Surly
Bikes: Two Cross Checks, Karate Monkey, Disc Trucker, and a VO Randonneur
Quoted: 699 Post(s)
Liked 1,304 Times
The Dead Milkmen had a a great song in the '80s that sums this thread up nice "Takin' R****ds to the Zoo"
