Ruler and Chain Checker are Diverging
#101
Mad bike riding scientist
Quoted: 6271 Post(s)
Liked 4,300 Times
If the rollers have wear, that wear directly impacts chain pitch when wrapped around a sprocket.
Elongated chain pitch is what wears out sprockets prematurely.
If you want to know what the chain has for actual on-sprocket chain pitch, you can't ignore the other source of elongation: The rollers.
You can't measure roller wear by measuring the pins alone.
That is the last time I'm going to explain that to you. The fact that seemingly flip flop between understanding and not understanding what a ruler measures makes communicating with you too frustrating.
Stuart Black
Stuart Black
Likes For cyccommute:
#102
Quoted: 4584 Post(s)
Liked 1,731 Times
I measured the chain wear on one of my bikes today. On the Pedro Chain Checker Plus II, the #3 hook is easily going into links, which indicates a wear rate greater than .75%. However, when I measured the chain wear with a ruler, it only stretched by 1/32 of an inch. Based on these measurements, should I replace the chain immediately? Or, can I get a little bit more life out of my chain?
Your point is not worth considering because it is a trivial point of no consequence.
#103
Liked 4,300 Times
.We can have a debate about whether roller wear is a factor in cog wear, and I am entirely open to being shown to be wrong. Just as I admitted a few posts ago that the new Park tool removes the rollers from the measure. But we can't have a conversation about the topic of roller wear if people don't understand where the parts of the chain are. And that stuff ends up being half the posts.
It is tough having an engineering conversation mixed with remedial topology. Especially when the people that really don't get it are insulting.
Stuart Black
Stuart Black
#104
Liked 1,731 Times
I can post almost any fact about bicycle mechanics and at least two know-nothings will come along to say "I don't know about that." Not opinions or techniques - facts.
So I respectfully disagree with your experience.
#105
Liked 4,300 Times
As have I. The difference is that I seldom made measurements by direct means.
No. Measurements should only be made to the level of accuracy or precision that is needed. If you only need to make a measurement to one decimal place, you don’t need to make the measurement to 5 decimal places. Measuring chain wear to 0.06” is adequate. Measuring to 0.062547” isn’t needed nor will it tell you anything.
Not in my nor most people’s experience. Changing a chain at 0.75% wear with a chain checker won’t result in skipping gears on the cassette in most all cases. Going much beyond that might or might not…it’s not an exact science. And, the fact that it isn’t an exact science is why you don’t need very high precision and accuracy in the measurement.
Good enough is good enough.
Go/No Go gauges were put in place for monkeys.
0.75% is way too much to prevent chainring or cassette wear. Secondly, once wear starts on a chain, it is not linear. So, 0.4% is when my chains get tossed. It can be as little as 4,000 miles or as much as 10,000 miles.
I'll let the rest of you argue about rollers.
Stuart Black
Stuart Black
#106
Liked 4,300 Times
So? One measurement is wrong and one is right. Which one? Tell us.
Stuart Black
Stuart Black
#107
Liked 1,731 Times
You don’t seem to understand how this works. You made the claim that roller wear is important and has to be taken into account. So it is up to you to demonstrate your own point. I have shown you that you are wrong by pointing out that rule measurement and chain checker tool measurement give the same results. If you have evidence to the contrary, by all means present it.
Do I need to quote you? Nope - anyone can go back and read the thread.
At no point have I insulted you. I have patiently explained to you why you are incorrect but I have never been insulting.
#108
Liked 1,731 Times
#109
Quoted: 7114 Post(s)
Liked 11,259 Times
You guys are laboring under the misapprehension that most bf posters are here to learn things; that's why you get in these arguments while trying to 'educate' each other.
Also, bragging about credentials and such exemplifies the "appeal to authority" fallacy -- which only makes a person look weak and insecure. An argument has to stand or fall on its merits, not on the person offering it.
PS: if any method of measuring my chain indicates that it's toast, I replace it.
#111
Liked 1,731 Times
I assume you are in the insult and personal attack business, which is why you make time to post off topic character assassination.
Don't you have a short, slow, flat ride you could be on right now?
#112
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
#113
Expired Member
Quoted: 3783 Post(s)
Liked 5,771 Times
In my experience on the bicycle mechanic subforum, there are few who get as little respect as actual professional bike mechanics.
#114
Liked 1,731 Times
I don't think I'm the one here making insults, personal attacks and character assassinations. What do you all think, folks? BillyD ?
You were being rude and off topic. The thread will be closed and then you can pretend your hands are clean. But I know and you know it was a personal attack and you are unkind.
#115
Liked 1,731 Times
No wonder Qanon got so big. Too bad he can't help you fix your $300 shifter.
#116
Sock Puppet
Liked 863 Times
Nice spin. If this thread is closed, it will be all because of you and your inability to admit you are wrong or control your anger.
#117
Expired Member
Liked 5,771 Times
You miss the point. I'm confident you could replace my chain. I'm not confident anyone posting here has the expertise/ education/equipment to resolve this pin/roller/ruler/tool discussion. You'd think Shimano or KMC have engineers who could explain this but AFAIK nobody has posted any links. Otherwise it's just noodling and anecdotal.
Likes For shelbyfv:
#118
Quoted: 2333 Post(s)
Liked 2,097 Times
Your approach is neither good nor enough. My approach is sufficiently accurate, precise and repeatable. It is not high precision. And, I do not need your silly lectures on significant figures or red herring examples WRT skipping gears. Seriously, you think you know everything. The resolution of all these devices is insufficient. Prove me wrong, find an R & R study. Unless you can do that, don't bother responding.
Likes For GhostRider62:
#119
Liked 1,731 Times
#120
Liked 4,300 Times
Further, the problem with your “facts” is that I disagree that they are, indeed, “facts”. They are at best opinions and speculation. Show some measurements. Show some data. Yes, I can be guilty of speculation…we all are and there is nothing wrong with it… as well but, more often than not, my speculation is backed up by sound scientific principles. The job at which I am actually a professional required me to understand those principles and be ready to back up my ideas, opinion, and speculations with measurements. See below.
You said that roller do not wear at all, then you explained how a ruler will show roller wear, then you said it won't show roller wear, then said that roller wear does contribute an extra amount to pitch elongation, then you circled back.
Captain obvious.
Now, just for giggles, I decided to demonstrate my point. I found 4 chains…a new one, one with <0.5% wear, one with 0.5% wear, and one >0.75% wear. All but the new one were gauged with a Park CC-3.2 chain checker. I then took apart a link and measured the pin thickness and 2 roller thicknesses on each chain.
Here’s the chain tool measurement for each one, followed by a tape measurement. The tape measure was made from 1” to 13” in order to ensure accuracy.
New chain. I didn’t measure it.
The very first thing I noticed was that the tape measurement showed no elongation at <0.5%. I did not hang or stretch the chain but set it on a bench in the same manner each time.
The 0.5% wear chain shows a little elongation but it is less than the 1/16” that would say that it is 0.5% worn. I’d probably still use this chain but it’s starting to get long in tooth.
The third chain was obviously past the 0.75%. There is a gap that I could see through at the end of the tool. This chain I would call severely worn. The tape measurement is a full 1/8” of elongation.
The picture below is just to illustrate how I measured with the tape measure.
An interim conclusion that I would draw is that using a tape measure (or ruler) may not give proper results. But all the above is only prologue.
I took one link from each chain and pulled it apart. I then used a pair of calipers to measure the pin thickness and roller thickness.
New
Roller wall thickness: 1.5mm
Pin diameter: 4mm
0.5% wear (almost)
Roller thickness: 1.5mm
Pin diameter: 4mm at wear point
>0.5 wear
Pin diameter 3.7 mm
>0.75% wear
Roller thickness 1.5mm
Pin diameter: 3.6mm
Each measurement of pin diameter was made at the most worn part of the pin. The picture above is of the <0.5% wear pin. Below is the most worn pin on which you can see obvious grooves.
The most obvious conclusion to draw from the above is that there is no roller wear. I measure each roller at several points around the roller and they all…from the new roller to the roller on the most worn chain…gave a wall thickness measurement of 1.5mm. And I’ll admit that I only used a caliper…and a vernier one at that…while a micrometer might have been better but that still would not have shown that much more wear of the roller. The pin on the worn out chain, on the other hand, was clearly worn and no longer round.
Now, I’ve presented my data. If you disagree, go ahead and present your own.
Stuart Black
Stuart Black
#121
Liked 4,300 Times
I agree
USAGE
- Check the wear of chains accurately, easily and quickly
The Park Tool CC-3.2 is a go/no-go gauge designed to accurately indicate when a chain reaches 0.5% and 0.75% wear (or "stretch"), the points at which most chain manufacturers suggest replacement. The CC-3.2 is long, accurate,
Nope, I don’t know everything. But that doesn’t mean I know nothing.
Stuart Black
Stuart Black
#122
Liked 1,731 Times
Before you object, this is no different than saying you have bearing play. The play could be from the balls, cone or race. They combine to become play. You don't fail to adjust out the play because you know the balls aren't worn.
And the other factor in all this is that the relative wear of different parts of the chain is variable between models. A KMC might have a harder roller than a SRAM. Narrower chains, for instance, tend to have harder pins than wider chains (one of the reasons some newer chains last longer than 8 speed chains). The advantage of measuring at the rollers is that you don't have to guess if you are measuring the worn part or not - you're just measuring the final product that contacts the sprockets.
#123
Liked 4,300 Times
When we refer to "roller wear" or "pin wear", that doesn't mean that the roller or pin are the specific things that are worn, but that the contact points at the roller or pin have worn. For the pins that's the pin itself and the inside holes of the inner cage plates. For the rollers that includes the outside diameter of the inner cage plates, the inside diameter of the rollers and the outside diameter of the rollers were they bear against the sprockets.
I showed your mine. Now it your turn to show me yours. You can speculate all you like but that’s all it is until you show some data. The wall thickness is the same all across the rollers.
Measure something!
Stuart Black
Stuart Black
#124
Depending on what length of chain you are measuring, a few tenth of mm roller wear can be significant.
If the gauge is only 6" = 152.4 mm and your "wear allowance" is 0.5% (153.16mm) then the max total wear you are trying to measure is 0.76mm (~1/32")
In that context adding, or not adding, a few tenth of a mm roller wear IS significant in determining if the chain is done or not, however hardly visible to the naked eye or a tape measure. You need a proper calliper. At least from recollection measuring new vs worn rollers, a worn roller will take up a significant portion of a 1/32" "wear allowance. I shall see if I can find a used roller and post the measurements.
EDIT:
Found a new and a used KMC 10s roller:
OD: New 7.66mm, Used: 7.58mm
Wall thickness: 1.30mm, Used ~1.17mm (but conical and with pronounced hump in the middle that fits in between the worn inner plates.
At first glance this feels like a lot of hoopla for nothing, however the wear in the rollers will add about 0.3 mm to the measurement if measuring between the rollers. - Almost half of your total wear allowance if you consider 0.5% of 6".
Make of it what you will, but Imo, roller wear should be taken into account or excluded all together. Just ignoring it will likely cause you to bin a perfectly fine chain.
(of course measuring a completely shut chain is going to show the same result no matter what method is used, but that's not the point either)
EDIT:
#125
Liked 4,300 Times
Then a chain that measures less than 0.5% with the Park Tool. Again, no difference. Pedros says it is good
For a chain that is over 0.5%, the Pedros would probably fail it. Not a big deal actually. You might loose 200 miles.
The chain that has greater than 0.75% fails with both.
Isolating the rollers makes no real difference.
Just for giggles, I also measured the shoulder on the inside of the inner plate that the roller rolls on. It measured out to 5.3mm on the chain that indicated 0.75% wear. It measured the same 5.3mm on the chain with less than 0.5%. While I was measuring, I measured just the outer edge of the roller on the same two chains. I tried to get as far out on the roller as I could and it was the same thickness as I previously measured. There is no roller wear that I could measure and certainly not enough of a difference in any part of the chain that could explain chain wear except for the changes in the pin diameter.
Stuart Black
Stuart Black
