Punctures due to leaky patches: Am I doing it wrong?
Old 07-02-19, 01:49 PM
djb
Quoted: 2740 Post(s)
Liked 974 Times in 797 Posts
i vote for the patch kits that have two little glue tubes in them, more chances of them not drying out.
and once in a while, buying new tubes of glue, worth the few bucks to avoid a dried out one just when you need it.
djb is offline
Old 07-02-19, 02:16 PM
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Best practice is to always keep a virgin tube of glue on the bike, and avoid patching tubes if at all possible until you've accumulated a bunch of punctured tubes at home. Then, if you have to patch a tube on the road (or run out of good spare tubes), immediately patch all of your punctured tubes when you get home, using your recently-opened tube. This maximizes the utility of each tube of glue, and minimizes the chance of being stuck somewhere with a dried-up tube of glue.
You can patch quite a few tubes with one little tube of glue. I still had glue leftover after this batch:
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 07-02-19, 02:41 PM
Quoted: 839 Post(s)
Liked 1,063 Times in 747 Posts
Originally Posted by Chinghis
Of course, the hole is right next to the seam, and was really hard to sand down.
Easiest way to sand a seam is fold the tube so that the seam is on the fold. Makes the seam stand out and simple to sand down to match the surface.
Crankycrank is offline
Likes For Crankycrank:
Old 07-02-19, 04:28 PM
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 794 Post(s)
Liked 508 Times in 322 Posts
Make sure to let the glue dry. Some years ago when I was living in Nigeria we had a young policeman stationed in our compound. I was riding my bike around the local roads, early in the morning only, too hot later and would occasionally get a flat from a wire or nail or something. One day I took a few tubes out to patch them. I had a good pump, and patch kit. I was under the thatched roof near the pool when the policeman came out to see.
Cooler and shady there. I started on the first one and he came closer. He politely asked if he could help. He showed me how he had been taught at the academy. Mark the spot, rough up the area, spread on the glue and WAIT. Like until the glue was really really dry. Then peel the back off the patch and apply. Then press it on really hard with a rounded object like the end of a screwdriver handle or similar. Talcum powder on the tube before reinstalling.
I was glad to have the lesson, I hadn’t been waiting long enough all those years. It was interesting that they taught tube patching at the police academy but if you were to get a flat somewhere it did make sense to be able to take care of it. Over the three years I lived there we had several pleasant patching sessions. I left just when he was taking his exams to be promoted. He passed and as we parted we wished each other well in our new endeavors. And thanks for the lessons.
Joe Bikerider is offline
Likes For Joe Bikerider:
Old 07-02-19, 04:58 PM
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
I like any country where patching a bike tire is part of police training.
Gresp15C is offline
Likes For Gresp15C:
Old 07-02-19, 08:33 PM
djb
thats a cool story.
djb is offline
Old 07-02-19, 08:38 PM
djb
good point, although I tend to do it right away, because if not, I forget and or mix up the tube, so just prefer to do it at home right away.
I have a larger tube of glue, and use it, and leave the unopened ones alone--checking them once in a blue moon to feel if they still feel luiquidy when I squeeze them.--and yes, tend to put in some just bought ones before going on a trip.
Hope you got the spoke caused hole dealt with, ie found the spoke protruding or the misplaced rim tape on that schraeder tube on the right with patch on the inside part.
djb is offline
Old 07-02-19, 08:54 PM
Gotta get organized!
RUSA #7498
Old 07-03-19, 09:31 AM
Recreational Road Cyclist
BCDrums's Avatar
Quoted: 257 Post(s)
Liked 252 Times in 134 Posts
Seams unnecessary
That sounds like a good technique, but I haven't found it necessary to get rid of the raised seam. I do sand the area to remove the release compound, but I put the patch over the seam and haven't had a problem. I burnish the patch with the rounded butt of a screwdriver, and press overnight between two thin wood shims with a spring clamp. Probably overkill, but never fails.
I appreciate the efficiency of patching tubes in batches, but I don't generate enough punctured tubes, so I just do them singly as they occur. I don't like punctures, but I do enjoy patching. It's simple job that works, saves pitching a tube, and I get to huff a little Rema! It's satisfying.
BCDrums is offline
Old 07-03-19, 09:56 AM
djb
chuckle
like what the previous guy answered, I just dont get enough flats to even consider stockpiling holey tubes for mass patching (TOUCH WOOD!)
so its just easier to do it right away.
over many decades, fairly consistent average of maybe one flat per season (TOUCH WOOD!!!)
djb is offline
Old 07-03-19, 10:46 AM
chuckle
That handful in my picture was about 2-3 years in the making. I actually enjoy patching tubes as well, but obviously don't wish for more punctures than I currently get.
RUSA #7498
Old 07-03-19, 10:58 AM
Half way there
Moe Zhoost's Avatar
Quoted: 986 Post(s)
Liked 880 Times in 527 Posts
Same here, just patch over it. I use Rema so YMMV. BTW, it's not really a seam, it's flashing from the vulcanization process.
About glue tubes drying up: I've found that I can extend the useful life of an opened tube by squeezing lightly to get some glue peeking out before I put the cap back on. This forces the air out and keeps the glue fluid longer.
Moe Zhoost is online now
Old 07-03-19, 11:38 AM
djb
absolutely, and for me this was always instinct, because as I spent half of my life in a darkroom, we always would squeeze the bottle of liquid developers to eliminate the air in the bottle, so that the developer would stay stronger for a longer period of time, oxidization and all that.
re glue tubes--sometimes also over time cracks can happen in the tube, drying it out. This is why the small plastic boxes holding a patching kit is good, it helps stop the tube or tubes getting scrunched by other stuff.
djb is offline
Old 07-03-19, 12:48 PM
Quoted: 2604 Post(s)
Liked 1,933 Times in 1,213 Posts
The Fourth is timely, as I've accumulated enough flats that I'm about to dip into new tubes if I don't have a patching party. IIRC I had one early this year, and the one before that was last summer. The "tubes to be repaired" box is a great idea.
pdlamb is offline
Old 07-03-19, 10:38 PM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1908 Post(s)
Liked 574 Times in 339 Posts
I agree that Rema "Tip Top" patch kits are excellent.
But I now buy packages of patches made in China (find then on eBay) and tubes of glue separately (also eBay). As long as it's a vulcanizing rubber cement (not the stuff made for gluing paper together) it should be fine. Always carry at least one unopened tube on the bike. At home I have a 4 oz can of glue, brush in the lid.
rhm is offline
Old 07-04-19, 01:29 PM
smikeybikey's Avatar
Has the material inner tubes are made from changed in recent years because they do seem harder to patch nowadays?
smikeybikey is offline
Old 07-04-19, 01:43 PM
Sophomore Member
Lemond1985's Avatar
Quoted: 1628 Post(s)
Liked 1,059 Times in 633 Posts
Not that I am aware. I would suspect that ingredients in the glues available have been changed to less toxic (and less effective) alternatives. I live in California, and plenty of chemicals have been outlawed here, usually with no notice at all to the consumer. You simply discover that a cleaning product or tire patch glue no longer works as well as it used to.
Lemond1985 is offline
bikebike3
Bicycle Mechanics
13
07-01-18 12:03 PM
morgothaod
General Cycling Discussion
27
05-29-16 03:17 PM
rdtindsm
Bicycle Mechanics
7
07-01-15 04:35 PM
work4bike
Bicycle Mechanics
19
09-19-11 08:03 AM
HardyWeinberg
Bicycle Mechanics
6
05-09-11 01:28 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
