Show us your Vintage Touring bikes
#2776
Bikes: Vintage Raleigh and more modern Roberts
Quoted: 57 Post(s)
Liked 162 Times
Goodness, glad you're okay! Lovely bike, interesting to switch to horizontal dropout, makes sense given your needs. I'm wondering about your rear rack. I see it's attached at the dropouts, is there a third attachment point? Otherwise, I'm wondering how the rack doesn't move when loaded up?
Likes For Small cog:
Likes For cjefferds:
#2778
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
Good use of a bottle cage What is used to mount the rear rack to the seat stays? I have a rack like that but couldn't find a decent way to mount it to my bike without scratching the paint.
#2779
Learning To Fly
#2780
Running on plenty
As purchased. A shade small, and some of the drivetrain appears beyond salvation, so might get turned into a moustache bar semi-townie instead.
Likes For familyguy:
#2781
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 614 Times
I often use a piece of rubber or even a couple layers of electrical tape on the contact area to prevent scratching the paint too badly.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
#2782
Groupetto Dragon-Ass
Quoted: 417 Post(s)
Liked 794 Times
Picked this up two weeks ago from the son of the original owner:
1984 ("BB") Cannondale ST400 that looks to have been built up originally as an '85 model with 600EX components.
Then it went through an upgrade ~ '90 with Tricolor 600 to get 700c wheels, click shifting and aero levers.
Still has the '84 EX crank, calipers and FD.
Likes For Chuckk:
Likes For orbeamike:
#2785
Quoted: 331 Post(s)
Liked 333 Times
Taking in the rays then......
Relaxing after the harvest taking some rays with my 1936 Sports when two noisy Americans showed up giving out them negative waves with those Pratt & Whitney radials.
This Robin Hood weighs a ton with those drum brakes front and rear.
Likes For Johno59:
#2787
Quoted: 331 Post(s)
Liked 333 Times
I've since changed the bars. Those 'boy racer' swallow bars just don't suit this kind of bike. By this stage (1950s) Raleigh had bought out all the British marques such as Robin Hood and kept the original badge and some other distinctive accessories but it is really a Raleigh with stupid bits on it. But you're right if it's flat terrain and you hit a pot-hole you barely notice anything. On a modern bike it feels like you've ran over an IED.
Likes For Johno59:
#2788
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 541 Post(s)
Liked 1,048 Times
Likes For Pompiere:
#2789
Running on plenty
#2790
Quoted: 548 Post(s)
Liked 473 Times
I'm curious, how come some bikes came with cantilever brakes instead of side pull brakes, allowing for larger wheels? It makes sense that buyers might prefer a larger tire and yet so many came with side pull brakes which would limit the tire size. Example below is not my bike but found on Pinterest. The frames appear to be similar, same components, except the braking system.
My bike which might allow 30 mm tires at best.
Likes For gthomson:
#2791
Quoted: 1136 Post(s)
Liked 650 Times
The notable exception is the wide-tired 650b hiker bicycles of France from the 30s to the 70s, which is what the bikes in your picture are. These bikes generally required cantilevers or long reach centerpulls for clearance as they had tires 38-42mm in width and almost always had mudguards. By the 80s, most French framebuilders had abandoned 650b in favor of skinnier 700c tires even for touring bikes. There has only been a recent resurgence in interest in these wider tires in the last 20 years or so.
#2792
Bikes: 1957 Motobecane camping bike, 1974 Manufrance Super Course STC, 1977 Peugeot camping bike, 1978 Liberia C15
Quoted: 37 Post(s)
Liked 128 Times
Regarding that picture, the bike on the left seems to be made at a slightly later date in the 1960s (just guessing, looking at the fenders) and might have been made at a different price point. I don't know, but I assume MAFAC canti's were more expensive then Altenburger sidepulls and required a bit more work.
#2793
Quoted: 548 Post(s)
Liked 473 Times
ThanksTenGrainBread, it's interesting how social media can be so misleading. I'm a huge fan of browsing through Pinterest and looking at all those gorgeous bikes and because I see many with both thin tires and thick tires (probably about 50/50) I was just curious if there was a shift towards the bigger tires for tourists, as the trend tends to be the way all bikes are going these days. Or, were they just traditional bikes as you mention above that someone then fitted with the cantilever brake to accommodate wider tires.
#2794
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 766 Post(s)
Liked 1,625 Times
Most tourists riding lightweight bicycles over the last 80 years have simply not seen the need for a touring tire over 25-32mm in width, which most sidepull brakes can handle. So your question is somewhat anachronistic in that you are assuming that wide tires (over 32mm) were always available and preferred for touring, which is not the case. A short review of bikes in this thread show that most came stock with 27" wheels with 1 1/8" or at most 1 1/4" wide tires. No problem for most sidepulls to handle.
Likes For ehcoplex:
#2795
Quoted: 331 Post(s)
Liked 333 Times
Power
I have always found cantilever brakes more powerful. The power is needed to arrest the extra weight held in your panniers. It's for this reason cantilever brakes and drum brakes were used on tandem bikes as only one set of brakes had to slow down two riders rather that a pair for each rider on separate bikes.
There have been cases where carbon rims have melted on tandem bikes going down long steep declines so the ol drum brakes maybe the answer.
I have no idea as how disc brakes feature in this equation. Are they better/more powerful/reliable? My LBS loathes them but I have zero experience.
#2796
Quoted: 1627 Post(s)
Liked 2,706 Times
#2797
"I'm curious, how come some bikes came with cantilever brakes instead of side pull brakes"
Part of it was just fashion/incremental improvement over time. In the 70s, most touring bikes came with center pulls or side pulls. Getting cantilever brakes almost required buying a custom bike from a builder. By the mid-80s, touring bikes with Cantilevers were everywhere. I suspect contemporaneous mountain bikes with cantilevers was not a coincidence.
Likes For pfaustus:
#2799
Bikes: 1979 Trek 412, 2011 Dawes Ultra Galaxy
Quoted: 17 Post(s)
Liked 58 Times
#2800
Quoted: 2587 Post(s)
Liked 3,106 Times
This was a very popular bike in its day. I remember seeing many of them loaded and touring thoughout the the southern US in the 80's. Over-sized aluminum was heralded as the new tech to make touring bikes lighter. I thought they were great looking bikes, but questioned the siffness myself. A great find for you. Congrats and I hope you enjoy!
Yes, Cannondale's aluminum Crit series bikes, the ultra-short-wheelbase racing bikes they sold in the late '80's and early '90's, do ride stiffly---every bit as stiffly as the many steel Italian bikes designed with criterium geometry on offer during the same era..
I rode the top Bianchi racing model, the Specialissima Super Corsa, back then---very fast, but just as unforgiving on rough surfaces as the Cannondale crit bikes.
Of course, the only people who were in a position to compare high-end Italian crit bikes to Cannondale crit bikes were those willing to pay for the expensive frameset, plus the (usually) Campagnolo Super Record gruppo, plus a matching build kit, plus the labor to build it.
So it's fair to guess that the ratio of the number of people who went Italian, despite the trouble and expense, to the number who simply walked into a Cannondale dealership and bought one off the rack, for considerably less money, was something like 1:500.
In any event, the racers who were buying Italian framesets and building them up were mostly stepping up from another racing bike and didn't worry about comfort---they just wanted the lightest, fastest bike available.
(Short wheelbases weren't actually faster, except in terms of being ideal for riding elbow-to-elbow in a peloton, but we didn't know that back then. It wasn't until several years later that the Italians and everyone else went back to using more sensible dimensions for their racing bikes.)
So it's the wheelbase, not the frame material, that determines the smoothness or harshness of the bike's ride. (In the analogy employed by the reviewer of the ST400, that's why limos get stretched.)
Anyone who still wants to argue the point---please go ride, e.g., a (steel) Ciöcc Mockba '80 criterium bike (named for the 1980 Moscow Olympics) for 50 or 100 miles and then a Cannondale Crit series bike and report back.
Here's a road test/bike review of Cannondale's first bike model---the ST400. The reviewer speculates that the biggest hit against the bike might be that it's too versatile---great for loaded and sport touring, but take off the racks and it's great for racing a triathlon---in an era when people expected a given bike to be optimized for only one use case.
Likes For Trakhak:
